Another help identify thread **please**
- bychosis
Postby bychosis » Thu Jul 11, 2013 9:07 pm
Picked it up today. It has no markings other than serial no on the BB and a couple of marks under the head/top tube lug. The dérailleurs appear to be early 80s, suntour arx(google says). Other than that I'm a bit new to identifying other parts. Once I pull it apart ill test the frame weight to help work out if it isn't gaspipe. The frame seems to have detailing indicative of being decent.
Some pics, appears I forgot to take a pic of the whole thing.
Head tube
Head tube lug markings
Bottom bracket
Serial no
Chrome fork and brakes with red detailing, like the headset detailing.
Brake bridge
Seat stays
Also the rear dropouts are forged with screws in the ends and the bottle cage mounts have little diamond shapes around them.
If it is a decent frame and the right size I'll keep it, if not ill keep the parts and on sell as was the plan when I bid.
- ldrcycles
Re: Another help identify thread **please**
Postby ldrcycles » Thu Jul 11, 2013 9:17 pm
- bychosis
Postby bychosis » Thu Jul 11, 2013 10:51 pm
Suntour arx front derailleur dated 1985
Suntour a-5000 rear derailleur dated 1986
SR 'custom' cranks, 170mm
Formos brake calipers and levers
Seat post is larger than the 25.8 out of a steel dunger frame, but my calipers are missing and the seat post isn't stamped so not sure what diameter. The 25.8 almost fell in.
Edit: and I popped a set of 700c wheels in and they fit without adjusting the brakes. and fixed trial seatpost size 25.4-25.8
- P!N20
Postby P!N20 » Fri Jul 12, 2013 10:40 am
Any identifiers on the dropouts? Screws in the ends are pretty standard for cast dropouts.
- pentlandexile
Postby pentlandexile » Fri Jul 12, 2013 5:03 pm
- bychosis
Postby bychosis » Fri Jul 12, 2013 5:45 pm
- Kermit TF
Postby Kermit TF » Fri Jul 12, 2013 7:22 pm
Frame looks kuwahara-ish. Give it a few hours , and you should have an answer from Zi experts...
I can confirm, its not an apollo
- pentlandexile
Postby pentlandexile » Fri Jul 12, 2013 7:50 pm
Yeah, that's them. Cool piece of kit.bychosis wrote:The levers say suntour symmetric. Doesn't mention arx on them.
- HappyHumber
Postby HappyHumber » Fri Jul 12, 2013 8:14 pm
I think those diamond bridge mounts with the triangular cutouts were a standard Tange component from the period - albeit one of their nicer ones. I personally have had them on a couple of Ricardo Nouvo frames.Kermit TF wrote:The brake bridge is a standout....I know Ive seen it before
- bychosis
Postby bychosis » Sat Jul 13, 2013 7:01 pm
Checked the size and got a little disappointed thinking it I would be too big. Tested it by popping some wheels on and throwing a leg over. Seems to fit OK but not a lot of seatpost showing.
Now the big question is whether I fix(ie) it, or move it on. As pictured it weighed 10.6kg, 700g less than my hi-ten tubed Fixie so the frame appears to be not too heavy, but not super light.
Pic of the bike with some spare wheels on.
Rear dropout
- WyvernRH
Postby WyvernRH » Sun Jul 14, 2013 8:45 am
If the saddle is set for you in the picture then that is about right for the bike's period. People did not have 9" of seat post sticking out back then. A general guide I was given was if you could grasp the post with your fist under the saddle you were right. Pretty unscientific and generalist but you get the idea of the expected look.bychosis wrote: Checked the size and got a little disappointed thinking it I would be too big. Tested it by popping some wheels on and throwing a leg over. Seems to fit OK but not a lot of seatpost showing.
Postby rustychisel » Mon Jul 15, 2013 8:54 pm
Rough, looks like evidence of a sheared and rewelded seat tube at the BB junction then repaint. The weld appears ropey, or is that merely the image? If it broke it'll break again. Mine did. I'll further assume the champagne colour of rear stays is original paint, and the silver a new coat...?
Can you tell us more?
- bychosis
Postby bychosis » Mon Jul 15, 2013 10:16 pm
The seat tube joint at the bottom bracket does look different to the other joints, but doesn't look like a weld. Can't see any difference in the paint there, but might see if i can rub it back when i clean up the frame to closer inspect. The champagne paint is on top of the silver.
While we are identifying stuff what is the thing on the lower part of the seat stay on the drive side for? An see it hiding in the rear dropout pic just below where the cable passes the seat stay
- WyvernRH
Postby WyvernRH » Mon Jul 15, 2013 10:44 pm
That's a chain hanger braze-on to hang the chain on (surprisingly ) when you remove the rear wheel for punctures and the like.bychosis wrote:While we are identifying stuff what is the thing on the lower part of the seat stay on the drive side for? An see it hiding in the rear dropout pic just below where the cable passes the seat stay
Generally only found on better class frames AFAIK?
- bychosis
Postby bychosis » Tue Jul 16, 2013 9:43 am
More internetting (mostly in the ricardo appreciation thread) points me away from ricardo based on the serial number. All the ricardo numbers I have spotted start with L-number-letter. This frame appears to have serial number T5092107. Long serial number points me away from custom frame, but happy to be proven wrong there.
The other unhelpful thing about the frame is that the groupset seems to be of low-average quality on a frame with some fancier features. Of course this could be due to lots of reasons.
Have decided that this frame will become my fixie. No frame mods though 'just in case' for later.
- Velo13
Postby Velo13 » Tue Jul 16, 2013 10:40 am
Tange #5 or 900 is a reasonable guess.
If you feel it fits, clean it up, and ride it!
- bychosis
Postby bychosis » Thu Jul 18, 2013 11:05 am
Time for painting.
- bychosis
Postby bychosis » Mon Oct 07, 2013 9:02 pm
Postby scratchman » Sat Oct 12, 2013 8:09 pm
thanks for that, have seen those many times, always wondered what their purpose wasWyvernRH wrote: That's a chain hanger braze-on to hang the chain on (surprisingly ) when you remove the rear wheel for punctures and the like.
