How a TT should be ridden
foo on patrol
Postby foo on patrol » Sat Jul 24, 2010 5:43 pm
I head an interesting quote on the TDF last nigh!!
I think it was from Schlecks or Contadors' father. Your legs should be jelly, if you have ridden a time trial to your best!
In other words, you should not be able to stand for at least 5mins.
This has always, been my line of thought!!!You should be putting everything into it, if it is a final or equivalent to a final, because you will only know then, what is required for a 100% effort. :idea:
Foo
Ps. This is differrent to a Tri event.
Goal 6000km
sogood
Re: How a TT should be ridden
Postby sogood » Sat Jul 24, 2010 6:34 pm
foo on patrol wrote:Ps. This is differrent to a Tri event.
Not really. In tri, you should melt to the ground at the finish line too. :mrgreen:
Missy24
Postby Missy24 » Sat Jul 24, 2010 6:46 pm
prefferably at the end of the run
sogood
Postby sogood » Sat Jul 24, 2010 6:55 pm
There's only one finish line for the whole race I trust. :wink:
foo on patrol
Postby foo on patrol » Sat Jul 24, 2010 7:31 pm
Yes, that was the reason for my statement! No good burning yourself out, in one stage, to only burn out,in the final run!
For a Tri, you would need to know your strongest leg then, capitalise on it, to your benefit then, work on your weakness! :idea:
Foo
Goal 6000km
Missy24
Postby Missy24 » Sat Jul 24, 2010 8:27 pm
Exactly
BarryTas
Postby BarryTas » Mon Jul 26, 2010 12:37 pm
the key it to be consistant, same cadence and same HR all the way, but try to finish a bit harder, you should not be able to sprint at the end.
therefore doing latic threshold training is good
when do we stop for coffee???
Peacewise
Postby Peacewise » Sat Feb 05, 2011 9:56 pm
TT, yep I agree put it all out there, make the legs jelly, break the heart, gasp for air. TTing is all about suffering in my opinion.
Keep flexing, spinning, rolling, coasting, pushing, pulling, drafting, sprinting, time trialling, touring, climbing, descending, hot dogging, crit-ing, racing, weaving, dodging, dropping, tanking, chasing... but most of all - just keep f'ing riding!
