Fixie on Brands Exclusive
swaz
Postby swaz » Fri Aug 06, 2010 4:11 pm
Disclaimer- I do not in anyway work for this mob!
Unfortunately you have to join to see it but they are selling these
Technical Specifications:
• FRAME: Model- Chappelli Frame - 700C, Material- High Tensile Steel, Specs- ¢31.8/31.8/34.9 SEAT TUBE 27.2; 540mm, 560mm or 580mm
• FORK: Model- Chappelli Fork - 700C, Material- High Tensile Steel, Specs- ¢25.4x28.6X176 mm
• HANDLE BAR: Model- Riser handlebar, Material- Alloy, Specs- ¢:22.2mm W: 560mm
• HANDLE STEM: Model- Classic 7 style, Material- Alloy, Specs- ¢25.4 EXT:100mm L:150mm R:-10D
• GRIP: Model- Leather, Material- Leather, Specs- Hand stitched with Chappelli logo
• HEAD PARTS: Model- CC-800, Material- St. Steel, Specs- ¢:25.4 x 34 x 30 H:37.5
• B.B PARTS: Model- NECO Sealed bottom bracket, Material- St. Steel
• CHAINWHEEL: Model- Lasco 165mm Single Speed Crank, Material- Alloy/Steel, Specs- 1/2inch x 1/8inch x 46Tx160mm
• BRAKE: Model- Radius side pull calipher RC-459, Material- Alloy
• BRAKE LEVER: Model- Radius, Material- Alloy
• FREEWHEEL: Model- GW, Material- St. Steel, Specs- 18T
• CHAIN: Model- KMC, Material- St. Steel, Specs- 98 Links
• RIMS: Model- Chappelli 42mm Deep Alloy Rims, Material- Alloy, Specs- 13G x 36H, 700C French Valve
• FRONT HUB: Model- KT - High Flange, Loose Ball, Material- Alloy, Specs- 13G x 36H 3/8inch x 100 x 140 , (Not quick release)
• REAR HUB: Model- KT - High Flange, Loose Ball, Material- Alloy, Specs- 13G x 36H 3/8inch x 110 x 150 1/S
• REAR HUB: Model- Shimano - 3 Speed Nexus, Material- Alloy, Specs- 3 Speed internal hub (not coaster or drum brakes)
• SPOKE Material- St. Steel, Specs- 13G F/ 282 R/ 280
• TYRE: Model- CST Maxima Tyres, Material- Rubber, Specs- 700C x 28C
• TUBE Material- Rubber, Specs- 700C x 28C, French valve nipple
• SADDLE Material- Synthetic leather
• SEAT POST Material- Alloy, Specs- 27.2x300mm
• PEDAL Material- St. Steel, Specs- 9/16inch
price is $450 including delivery.
I am by no means a cycling novice. But I am a fixie/SS n00b. Is this a good buy? I have an old steel frame in my shed with some classic Shimano parts. All I would need are some wheels, chain and cog and I am good to go. Wondering if this was a great bike, I'd buy this instead.
MichaelB
Re: Fixie on Brands Exclusive
Postby MichaelB » Fri Aug 06, 2010 4:23 pm
Do a search on Chapelli on this forum, and you'll see.
swaz
Postby swaz » Fri Aug 06, 2010 4:30 pm
embarrassingly I didnt even think of that :oops:
swaz
Postby swaz » Fri Aug 06, 2010 4:54 pm
Thanks for the suggestion. I did a bit of searching. Being compared to a K-Mart bike doesn't make me want to spend $450 on one.
Back to the original idea of doing up the old steed!
brauluver
Postby brauluver » Fri Aug 06, 2010 5:22 pm
swaz wrote:Back to the original idea of doing up the old steed!
Good move!
