Need help choosing tubular tyres
Chaderotti
Postby Chaderotti » Wed Dec 08, 2010 2:46 pm
I ride on an indoor, wooden track.
I have no idea what I should be looking for.
Should I just go with Conti Sprinters for about 50 bucks each, or go up to Dugast cottons for about 87 bucks each? Or should I go in between?
And rim cement, should I get Conti tub cement which is 'specialised' for carbon rims?
Princess
Mistress = Pinarello Opera, Ultegra SL
Mistress #2 = Drag Bluebird
foo on patrol
Re: Need help choosing tubular tyres
Postby foo on patrol » Wed Dec 08, 2010 7:48 pm
Can't help you this time Chad. :wink:
What about silks? :)
Goal 6000km
tallywhacker
Postby tallywhacker » Thu Dec 09, 2010 11:21 am
go on a tuesday night and speak to Brian or have a look at what other people are using. Personally I've been happy with Tufo S3 pros and their extreme tape on a set of Araya r50s.
rennie
Postby rennie » Sun Dec 19, 2010 6:49 pm
Conti Sprinters are fine for me.
alex
Postby alex » Wed Dec 22, 2010 5:11 pm
for indoors, vittoria evo pista
if i get killed while out on my bike i dont want a 'memorial ride' by random punters i have never met.
Chaderotti
Postby Chaderotti » Sat Jan 15, 2011 10:49 pm
I eventually chose a pair of Sonderklasse's and tape
Princess
foo on patrol
Postby foo on patrol » Sun Jan 16, 2011 7:13 am
And what? :?
Goal 6000km
Chaderotti
Postby Chaderotti » Sun Jan 16, 2011 1:36 pm
nnnooottthinnnngggggggg :D
Princess
foo on patrol
Postby foo on patrol » Sun Jan 16, 2011 2:11 pm
:P :P
Goal 6000km
toppity
Postby toppity » Sun Jan 16, 2011 10:09 pm
Chaderotti wrote:I eventually chose a pair of Sonderklasse's and tape
I've got these on my new Basso. Can't wait to give them a go.
I've also just snagged a set of Campy Record Cranks for it as well. :mrgreen:
Chaderotti
Postby Chaderotti » Tue Jan 18, 2011 8:22 pm
taped a rim, put the tyre on (backing still on) and I noticed that this particular Sonderklasse has a horrendous bump around the valve hole. I thought these were a 70-80 dollar tyre not a 20 dollar duct-tape jobby
Princess
foo on patrol
Postby foo on patrol » Tue Jan 18, 2011 8:33 pm
I never saw one that didn't have a bit of a lumpy bumpy thing around the valve stem Chad! :wink:
Goal 6000km
Chaderotti
Postby Chaderotti » Tue Jan 18, 2011 9:06 pm
Is there a chance it'll roll off around this area?
Because of the bulge it's not completely in contact with the tape.
Speaking of tape, I'll probably glue my front tyre just to spice things up.
Princess
foo on patrol
Postby foo on patrol » Wed Jan 19, 2011 5:49 am
Hey Chad, the amount of bulge was from the start and finish of all the stitching, around the valve base and my rims had a little bit of a countersunk area. Where the valve went through and was never a problem as far as rolling off went.
I have to be honest and say, I haven't seen what the rims of today are like as far as the countersunk area of the valve goes.
Did you put the tub on prior to gluing to see if there was a bump at the valve area when pumped up, while spinning the wheel?
Foo
Goal 6000km
Chaderotti
Postby Chaderotti » Wed Jan 19, 2011 1:28 pm
Yeah I did see a bump before hand, the area either side of the valve doesn't make good contact with the rim.
I think what I'll do is tear off the tyre, and maybe put clamps or something either side of the tyre to make the area's either side of the tyre come in contact with the rim.
Princess
foo on patrol
Postby foo on patrol » Wed Jan 19, 2011 7:29 pm
You would need to be real careful doing that, because you could rupture the tube. :(
Don't suppose you could throw up a pic, so that I can see it?
Does your valve stem have a thread so that you can screw it down?
Goal 6000km
Chaderotti
Postby Chaderotti » Wed Jan 19, 2011 11:07 pm
I eventually tore the tyre off. In hindsight the tape was most probably adequate. I bought Conti cement and that damn stuff goes tacky in about 3 seconds flat.
I put a thin, even layer on the rear wheel (completely messed up the front) and barely had enough for the tyre. It's sitting at the moment, probably mount it up in half an hour.
Princess
alex
Postby alex » Tue Jan 25, 2011 11:22 am
i highly doubt you would roll a tyre at the valve, because the valve would be holding the tyre on the rim better than glue would when lateral forces come into play
toppertee
Postby toppertee » Sat Apr 23, 2011 5:10 pm
You will probley find the valve hole is a little on the small side,
Just remove the tubular and increase the dia of the hole to aprox 12mm in the rim.
Should be no lump under the tubular then. I had the same issue on my tubs and this fixed the problem.
