Video Camera who uses one?
Pushy
Postby Pushy » Fri Dec 07, 2012 2:14 pm
New 808#16 V2 with D lens helmet mounted on twin led helmet lights (McGivered)
Set exposure to "Light", a compromise for dusk/night ride.
[youtube]http://www.youtube.com/watch?v=eSpc6i0tpDo&feature=player_detailpage[/youtube]
Les
06' Giant TCR C1
08' Colnago CLX
07' Apollo Swift
VW Jetta Diesel 5.5l/100km
Mugglechops
Postby Mugglechops » Fri Dec 07, 2012 10:41 pm
AUbicycles wrote:Did you screw or cabletie?
I copied norbs today. :D Skinny steel frame helps heaps.
[youtube]http://www.youtube.com/watch?v=Pe0aAn6qFFA&feature=share&list=UUv_N2TLz5k6bxiSS9TpUQ_A[/youtube]
I am just waiting for his blog post to see if I can fit it to my MTB.
LM324
Postby LM324 » Sun Dec 09, 2012 11:45 am
I don't know much about cameras.....Can someone please explain to me why (in the sony) it has a 16 megapixel sensor but can only shoot 2mp stills?
norbs
Postby norbs » Sun Dec 09, 2012 3:17 pm
Mugglechops wrote:I am just waiting for his blog post to see if I can fit it to my MTB.
All is revealed!
New on the blog : That View from the Bottom Bracket. (HowTo) http://norbs.tk/bp
Mugglechops
Postby Mugglechops » Mon Dec 10, 2012 1:10 pm
All is revealed!
It works on the MTB, stand by for another video.
higdawg
Postby higdawg » Tue Dec 11, 2012 6:44 pm
How many people have been caught out later reviewing the video rubber necking with a helmet mounted camera?
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Tue Dec 11, 2012 9:05 pm
Mugglechops, is that the Rollbar mount?
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Thu Dec 13, 2012 10:22 am
The Sony Action Cam review is now up on BNA:
How Good is the Sony Action Cam for Capturing Video on a Bike?
Note, in the photo below, I choose to mount the camera up-side-down on the handlebars which keeps it away from the top of the handlebars and out of trouble.
Mugglechops
Postby Mugglechops » Thu Dec 13, 2012 9:27 pm
AUbicycles wrote:Mugglechops, is that the Rollbar mount?
No just the handlebar mount. It was pretty much at the end of it's adjustment.
oxonabike
Postby oxonabike » Fri Dec 14, 2012 11:49 am
A while back I posted about Liquid Image EGO camera, so thought I'd do a bit of an update.
Still very happy with it, and I especially like the method that is used to mount it - it threads onto a standard tripod mount (1/4" gutter bolt thread) so making your own mounts is simple. Photo below shows its permanent mounting on the commuter bike:
The bracket is just an aluminium angle shaped to achieve a decent alignment of the camera. However I was really keen to get hold of a chest mount for use on the roadie and MTB, but it looks as if these are still in 'pre order' stage on the webz. I had heard that the mounting system is compatible with the GoPro stuff, so when the local JB had a special on, I went and purchased one of these to test out the theory.
While remarkably similar in appearance of both the quick release clip, and the rotating clevis there are subtle differences that need to be made for the everything to be fully compatible - but they are simple tasks.
Pictured above is the clip that comes with the EGO. I wanted to fit this straight into the GoPro harness, and all that needed to happen was that a 'poofteenth' had to be shaved from that centre groove - I had a fine sharp chisel in the shed that accomplished this in about two minutes. During a subsequent on bike test, I found that if riding the roadie on the drops, I could not tilt the camera back far enough to get a decent view of the road ahead, so I ended up placing the EGO swivel piece onto the GoPro clip - this required a bit of a fine sanding of the centre tab on the GoPro clevis as this was point something of a mm wider than the matting piece from the EGO - The sanding allowed installation without needing the apply force, and also allows smooth rotation. Below is the camera as mounted on the GoPro Harness:
Other things I have found:
The control buttons can be a bit hit and miss when riding along, the the small screen with the LCD can be difficult to see in some lighting conditions. I have missed some great CC racing action from mis-hitting the buttons, and being unable to read the display to guage the success or otherwise of starting / switching on the camera. I'm getting more used to this now, and tend to only operate the camera when stopped so I can be assured of positive engagement. This is mostly a problem with where it sits on the commuter - won't be such a big deal in the chesty.
Camera tends to get warm, and will do a self preservation shut down if it gets too hot. Have not seen this yet, but with our Tropical summer, I'll be interested to see how this handles the heat and humidity. Mind you, I'm often got a healthy headwind to ride into, so this would contribute to an overall cooling affect.
I seem to need to reformat the SD card from the Camera itself. Deleting files from the computer (and then emptying 'Trash') does not seem to convince the camera that it has spare capacity to record. This might also be due to a Linux system I use. I have successfully done a format of cards from the computer, but these were on small 4 GB cards. My new 16 GB cards seem to insist on being formatted by the camera itself. Anyway, its no biggie - in camera format is a simple manipulation of the control buttons.
When reviewing the footage straight off the camera, I still get a surprise at the clarity of the footage. I have found a good setting in my video software to retain this for various compilations I do, but there is a bit of loss when uploading to youtube.
To finish off, I suppose I should include a couple of random samples from Youtube. First Vid is 5 minutes towards the end of my commute to work in Cairns. Shows the camera performance in various lighting conditions (into sun, shade, shadow, good light etc). Also note that the way the camera is mounted, a lot of frame noise is transmitted to the camera - good for detecting brake applications etc. Second vid is chasing a departing train from its originating terminal in Cairns.
https://www.youtube.com/watch?v=MDVrnoRvW28
https://www.youtube.com/watch?v=z5vBjnAL36U
PS - if anyone can pass on the youtube embedding secrets in the forum, I'd be most happy!
Postby Aushiker » Fri Dec 14, 2012 12:22 pm
oxonabike wrote:PS - if anyone can pass on the youtube embedding secrets in the forum, I'd be most happy!
Thanks for the update. Much appreciated.
As to the embedding issue. Its seems that with the changes to YouTube the links are no longer working consistently with the forum software :(
InTheWoods
Postby InTheWoods » Fri Dec 14, 2012 12:34 pm
I don't know if something has changed, but it always works for me if I used the "long" www.youtube.com type links. The "youtu.be" links don't work.
oxonabike
Postby oxonabike » Fri Dec 14, 2012 2:43 pm
Yes, that is my experience on other forums I inhabit / administer. I tested and previewed those links before posting, but nothing seemed to want to work. Strangely enough, I have had success here on other posts.
Mugglechops
Postby Mugglechops » Fri Dec 14, 2012 3:29 pm
Anyone else had Go Pro issues after firmware update? I used it this morning then turned it off and it wouldn't turn on past the camera icon and wouldn't turn off either. Plus my video footage was a bit jumpy.
The under BB mount on the MTB worked well though.
norbs
Postby norbs » Fri Dec 14, 2012 3:40 pm
Mugglechops wrote:Anyone else had Go Pro issues after firmware update? I used it this morning then turned it off and it wouldn't turn on past the camera icon and wouldn't turn off either. Plus my video footage was a bit jumpy.
/Borat voice - Very nice
Lukeyboy
Postby Lukeyboy » Fri Dec 14, 2012 3:41 pm
Right here. I've had a few niggling issues. Sometimes when I turn it on it will freeze on the video logo screen (like you) or it would record for 10 secs then stop. The 10 second issue seems to only be old data on the memory card which is rare but the freezing icon I don't know why. I tend to notice it does it alot more with 32gb cards but then again there have been times where it just instantly works.
On the plus side the update has done wonders for the video quality on standard (not using protune). It cut down from 30 minute files to 18 minute files but the quality is worth it imo.
Postby Aushiker » Fri Dec 14, 2012 6:45 pm
InTheWoods wrote:
I don't know if something has changed, but it always works for me if I used the "long" http://www.youtube.com type links. The "youtu.be" links don't work.
Are you replacing the youtu.be with www.youtube.com yourself as YouTube is longer providing the long link option which worked before.
The YouTube interface has changed recently and hence some features related to sharing have changed.
InTheWoods
Postby InTheWoods » Fri Dec 14, 2012 9:14 pm
Aushiker wrote:
Are you replacing the youtu.be with http://www.youtube.com yourself as YouTube is longer providing the long link option which worked before.
You're right, it has just changed. Seems you can still get the full youtube.com url just from your browser's address bar though.
Postby Aushiker » Sat Dec 15, 2012 12:55 am
I know I am right :)
I tried the URL yesterday and it didn't work with the partiuclary video. Seems a bit hit and miss.
Baalzamon
Postby Baalzamon » Mon Dec 17, 2012 4:40 pm
So I grabbed a filter to filter out direct sunlight hitting my gopro on my commutes. Got the lense off and wasn't aware that the glass lense had landed in my lap off my desk somehow. Stood up and there it goes to the ground with a crack on the side of it :evil: Took a few test photos and the crack wasn't evident in the photos, ok looking good. 4hrs of video and no sign of crack in video, but I can still see it. I'm going to see if I can replace the lense, or if I have to get a new housing. Water may ingress thru that crack now, oh well at least it's summer.
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Mon Dec 17, 2012 11:55 pm
For the lense on the GoPro waterproof casing you can buy replacement lenses. I got myself a few as a backup.
norbs
Postby norbs » Tue Dec 18, 2012 10:01 am
AUbicycles wrote:For the lense on the GoPro waterproof casing you can buy replacement lenses. I got myself a few as a backup.
It is literally a 3 minute job to change them out.
Postby Aushiker » Fri Dec 21, 2012 7:35 pm
Founder of GoPro now a billionaire apparently ...
An infusion of cash into GoPro, the wearable action-camera company, makes its founder, Nicholas Woodman, a billionaire.
That’s according to an article today on Forbes.com, which cites a $200 million investment by Hon Hai Precision Industry Co., the world’s largest electronics manufacturing company, as pushing the value of the company to $2.25 billion.
Since Woodman owns more than 50% of GoPro, the Forbes article cites, his net worth is ostensibly more than $1 billion. This makes the 36-year-old surfing junkie likely the richest man in the entire outdoors world.
Source: GearJunkie.com
herzog
Postby herzog » Fri Dec 21, 2012 7:42 pm
Well done to him you have to say.
How did the Canons and Sonys of the world miss this boat so badly that a little guy steps up and creates a billion dollar business from nothing?
elStado
Postby elStado » Fri Dec 21, 2012 11:15 pm
herzog wrote:Well done to him you have to say.
+1
There are still so many opportunities out there for people who are willing to think outside of the box.
Users browsing this forum: LateStarter, rolandp
