GT Traffic 2.0
Confusedtraffic
GT Traffic 2.0
Postby Confusedtraffic » Sun May 22, 2011 8:58 am
Hi All,
After a little advice.
I have had a GT Traffic 2 for a little under 12 months now. I have been having consistent problem with breaking spokes near the hub. I am on the heavier side at about 118kgs. My riding is all on baike paths, no gutter hopping or anything like that. My ride is just over 20kms each way to work & back doing 2-3 times per week.
I am looking for options to counter breaking spokes all the time that are costing me between $15 - $30 each time. I tried to fix two myself, 1 successfully, 2nd, well, let's say did not turn out so well.
Options so far I have considered:
Continue with repairs $15-$30 each time,
Complete rebuild with better spokes & rim, $270-$300 quoted,
Buy new bike without internal hub so increases options to rebuild, or change wheel.
Any advice would be greatly appreciated.
zero
Re: GT Traffic 2.0
Postby zero » Mon May 23, 2011 12:19 pm
I've had wheels rebuilt to interrupt repeated breakages of spokes. It does generally work as a properly hand tensioned wheel with good components is usually stronger than a machine tensioned wheel. I presume you are only breaking spokes on the rear wheel ? if so, I wouldn't bother getting the front rebuilt. How many spokes is your internal gear hub drilled for ?
I'd also get the bike serviced every 3-4 months or so to make sure they are trued reasonably often, or learn to check and true the wheels yourself, and consider (rim and clearances allowing), running a wider rear tire. You might be able to fit a 700x48 for more cushioning.
just4tehhalibut
Re: GT Traffic 2.0
Postby just4tehhalibut » Sat Jun 04, 2011 3:39 am
zero wrote:I've had wheels rebuilt to interrupt repeated breakages of spokes. It does generally work as a properly hand tensioned wheel with good components is usually stronger than a machine tensioned wheel.
What also can be a factor, a cause of your broken spokes, is that you are replacing spokes. Once you start replacing spokes in a wheel you start introducing dissimilar spokes and creating problems from this with differences in tension, flex and other characteristics. So, yes, at some point it is better to just get someone to respoke the whole wheel, all new spokes and from the same box, all hand-tensioned. Or do it yourself.
If you're paying out $15-$30 a pop, even thinking of shelling out for a new wheel, why not instead use that to invest in some wheelbuilding and truing tools and DIY it? All you need really is a flat-bladed screwdriver, a spoke key and truing stand (or an old fork in a bench vice with a cable tie on the fork as a rim guide would do). You may already have the tools to remove a cassette from the hub, normally just a freewheel remover and a chain whip.What you learn at home reading the Sheldon Brown website and other sources and practicing there will help you on the road, besides knowing how to do quick adjustments to the spokes and keeping the wheel true, the quick road-side check, can prevent spoke breakage.
Users browsing this forum: Tequestra
