How much does a Giant defy alliance 1 weigh
Giantrider1997
Postby Giantrider1997 » Sun Feb 12, 2012 7:42 pm
I am trying to work out what parts i should upgrade for racing. Appreciate any help:)
:D
MREJ
Postby MREJ » Mon Feb 13, 2012 7:17 am
A change of wheels often makes the biggest difference, but I suggest just starting racing first. You've got a nice bike already and just as good as many others I've seen doing well at club races. Of course, people change parts and bikes all the time looking for what are mostly small incremental improvements. You'd almost certainly get more improvement to begin with from coming to grips with tactics and tight bunch riding and from increased "match fitness"; as that comes, you'll be in a better position to consider any changes to your bike.
2016 S-Works Tarmac, 2014 Wabi Lightning SE, 2012 Felt F75, 2011 Genesis Equilibrium 20, ancient Avanti Pista track bike
Giantrider1997
Re: How much does a Giant defy alliance 1 weigh
Postby Giantrider1997 » Mon Feb 13, 2012 6:35 pm
i currently have r500 wheels what should i replace them with around the same price or a few hundred dollars more?
JV911
Postby JV911 » Tue Feb 14, 2012 1:41 pm
Giantrider1997 wrote:I am trying to work out what parts i should upgrade for racing. Appreciate any help:)
:D
tyres and engine
<---LACC--->
<---BMC SLR01--->
toppity
Postby toppity » Tue Feb 14, 2012 2:58 pm
Giantrider1997 wrote:i currently have r500 wheels what should i replace them with around the same price or a few hundred dollars more?
You know what, I can finally recommend these without fear. I've had a set of RS80 Shimano wheels for 18 months now and have done nearly 10k on them. I'm a big bloke and have only just had to have the spokes retensioned. Can't fault them and I've done o.k. in a few races with them as well.
not too expensive if you want to take the risk of buying them overseas (warranty issues would always concern me)
http://www.ribblecycles.co.uk/sp/road-t ... HIMWHFR385
Giantrider1997
Postby Giantrider1997 » Fri Feb 17, 2012 5:04 pm
what about something from mavic?
ozdavo
Postby ozdavo » Sat Feb 18, 2012 12:02 am
Pro-Lite Bracciano as good or better than wheels twice the price, half kilo lighter than the R500's.
Look up some reviews.
Combine them with light weight tubes and good tyres (like Conti GP4000S) and you have a good, cheap race wheel set.
Giantrider1997
Postby Giantrider1997 » Sat Feb 18, 2012 9:02 pm
Apparently the braking is not very effective on the rims of the pro lites. Have u had braking problems?
MREJ
Postby MREJ » Sun Feb 19, 2012 12:40 pm
If you still want an answer to your original question, you could look on the Giant site for France. It shows bike weights, unlike the Australian site.
Giantrider1997
Postby Giantrider1997 » Sun Feb 19, 2012 10:00 pm
What would you suggest as a cheap carbon wheel option around 40-50mm?
AndrewBurns
Postby AndrewBurns » Sun Feb 19, 2012 10:06 pm
Giantrider1997 wrote:What would you suggest as a cheap carbon wheel option around 40-50mm?
I got a pair of mavic cosmic carbone SL's for under $1000 from Ribble. They're on the heavier side but very robust with their aluminium rims and steel spokes. Aluminium rims mean no concerns about heat build-up with constant braking and no need to change brake pads if you want to swap wheels (which I do as I don't train on them). For a bit more you can get full carbon clinchers or tubs from campy, pro-lite, shimano and a bunch of other brands, depends what floats your boat.
jacks1071
Postby jacks1071 » Mon Feb 20, 2012 5:12 pm
Giantrider1997 wrote:Apparently the braking is not very effective on the rims of the pro lites. Have u had braking problems?
I've never had anyone, ever complain about braking on any of the Pro-Lite wheels.
If you want to improve the power and reduce the wear on the braking surface, you can use the Pro-Lite pads but this is definitely not necessary - they will work great with any pads.
Users browsing this forum: Robski2
