Xplora
Postby Xplora » Wed Feb 22, 2012 9:32 am
I adjusted my shimano cable disc brakes (so miserably easy it is embarrassing, check Youtube :oops: )
I put a new bolt into my Topeak rack (I have GOT to tighten those more regularly)
I moved my seat post and tightened it (ped tried hard to get mowed down, I missed them but shanked the post :shock: )
I put some oil on the chain with my toddler's help
All in one night!
What are your lameduck mechanic moments?
HappyHumber
Postby HappyHumber » Wed Feb 22, 2012 10:37 am
Xplora wrote:I put a new bolt into my Topeak rack (I have GOT to tighten those more regularly)
Discovering loctite ;)
- Kym
PawPaw
Postby PawPaw » Wed Feb 22, 2012 11:32 am
release the tension from my torque wrench springs when not using.
store bikes with the derailleur springs unloaded.
replace cables and housings at the same time, no matter how pretty housings look on the outside.
use sram aluminium cable housing caps, rather than plastic which the cable bites into.
apply electrical tape to the rim valve holes to protect the valve from shear stress.
coat my tubes and tire inner surface with johnsons baby powder to reduce friction
give my sti mechs a monthly shot of wd-40
re-seat my head set bearings every 5000k to prevent divots developing in one spot.
occasionally swap front and rear brake pads, and left and right cleats to share the wear.
use loctite on bidon cage bolts - never had one shake loose since doing it
rkelsen
Postby rkelsen » Wed Feb 22, 2012 11:36 am
Or Nyloc nuts.
Postby munga » Wed Feb 22, 2012 1:16 pm
divots = brinelling.
simonn
Postby simonn » Wed Feb 22, 2012 1:38 pm
Or Nyloc nuts.
Or grease.
drubie
Postby drubie » Wed Feb 22, 2012 10:40 pm
My "I'm a champion bike mechanic" moment: discovering cable cutters. Only now I've worn mine out and have no idea how to sharpen them :cry:
Postby trailgumby » Wed Feb 22, 2012 10:58 pm
Finally buying a torque wrench... after nearly stripping the thread on the axle retaining bolt on my original 2004 vintage Lefty :oops:
"I will not tighten past 15Nm"
HappyHumber
Postby HappyHumber » Wed Feb 22, 2012 11:48 pm
Mount your tyres with the most obvious branding centered above the valve hole. It helps you visually locate the valve a smidgeenth quicker (depending on what visual noise is behind the wheel) and also when you're changing a flat it also gives you a loose guide where in relation to the branding the cause of the puncture is in the tyre - eg. assuming you've pulled the tube and it's quite obviously got a hole at 4 o'clock (the valve at midnight) you know to look there first for anything obvious in the tyre.
If not at 4 o'lock try 8 in case you've unwittingly flipped the tube over in pulling it out. If it's not obvious by this method - then back to a more closer & all round inspection.
Whilst this idea it won't feed the starving; it makes things a tad easier and a habit I got into.
- Kym
silentbutdeadly
Postby silentbutdeadly » Thu Feb 23, 2012 10:35 am
My lameduck mechanic moments typically happen every Friday after lunch when I finally get the chance to fix something on one or more bikes from the previous week...not sure what's on this weeks list but there's still a day to go...although there's some spoke tensions to check and a thorn resistant tube to get rid of.....but a tip? Yes a tip....
Before installation fill a new MTB tube with 50mL of Stans Sealant and 20mL of Slime Tyre (not Tube) Sealant. The Stan's goes off fast and the rubber particles in the Slime Tyre sealant helps clog up the hole. Tiny weight penalty for a big win. Cheaper and more effective than a Slime tube - even seems to work on high pressure roadie tubes (just use half the amount suggested above).
Xplora
Postby Xplora » Thu Mar 15, 2012 12:28 pm
Another brilliant moment last night! Woot!
I've bought a bracket from Bunnings to mount my magicshine front light, and got my SKS P35 all sorted out on the front. Looks the business! :mrgreen:
notwal
Postby notwal » Thu Mar 15, 2012 7:56 pm
Check that your new shifter cable is actually shifting gears before you cut it. :oops:
For those stubborn hard to fit tyres try a bit of soapy water on the rim.
judged, insulted, gone
notwal
Postby notwal » Thu Mar 15, 2012 8:01 pm
drubie wrote:My "I'm a champion bike mechanic" moment: discovering cable cutters. Only now I've worn mine out and have no idea how to sharpen them :cry:
Time you got a Dremel drubie.
gururug
Postby gururug » Thu Mar 15, 2012 10:12 pm
Converted multispeed to singlespeed ( shortened chain ) to get me home when i mangled a rear derailer riding over a plastic bag. Thank god I had a quicklink.
moreegolfer
Postby moreegolfer » Thu Mar 15, 2012 10:18 pm
Xplora wrote:Another brilliant moment last night! Woot!
Have you got a pic Xplora?
nayfen
Postby nayfen » Thu Mar 15, 2012 10:23 pm
the most useful tool in my champion workshop is;
www.youtube.com
philip
Postby philip » Fri Mar 16, 2012 8:19 am
Got an extremely stuck carbon seat post out of an aluminium frame. LBS wasn't able to get it out (I'm not sure they tried all that hard though). Seat post was already busted so I ended up drilling a hole through it, sticking a rod through to use as leverage to twist. Got it to twist a tiny bit then putting WD40 in and twisting got it out without too much trouble.
WyvernRH
Postby WyvernRH » Fri Mar 16, 2012 8:55 pm
[quote="HappyHumber" Discovering loctite ;)[/quote]
Finding out there are lots of different grades/types of Loctite... :P
Postby toolonglegs » Fri Mar 16, 2012 9:06 pm
Yeah use stud lock instead of blue :P .
Philip... get a spoke....tape a long strip of wet and dry to the spoke and wrap it around the spoke a few times. Put it in a drill and run it up and down the seat tube and it will remove any corrosion but won't take any metal off. Steel wool is better on a long shaft with a slot in it...but it can be a bit hard to get out if it falls off.
Big_Red
Postby Big_Red » Thu Mar 22, 2012 12:31 pm
My "I'm a champion bike mechanic moment" was replacing the brake & rear derailleur cables last night as i'd noticed them starting to fray/rust. Brakes were still hopeless & noisy, just as they were before i changed the cable. So i whipped out the front & rear disc pads and rubbed them across a light file to remove the glazing. Popped them back in the brake assembly, giving myself a nice blood blister when the pliers slipped while resetting the split pin retainer and reset the pads to just off the disc. Tested the bike out and promply endo'd the bike in testing the front brakes. At least now they lock up each wheel very easily and are nearly silent. Quite chuffed!
teak81
Postby teak81 » Thu Mar 22, 2012 6:12 pm
That made me laugh mate. "promptly endod the bike" good job on the brakes. :lol:
2011 Malvernstar xcs 1.0
2012 Oppy a5
2011 fm 015
Postby find_bruce » Sun Sep 02, 2012 9:42 am
Quite chuffed with myself yesterday, managed to repair my brother's brake lever that I stuffed when I borrowed it.
The olive nut had seized & the hex broke off while trying to undo it, but I was able to drill the end of the hose out & remove the nut with an ezy out. Installed new olive & nut.
The tricky part was installing the circlip- I have circlip pliers but the points were too big. Fortunately I am am experienced bodger & used a pair of fine screwdrivers.
edit: should have added that the only thing that needed doing originally was replacing the circlip :)
jaseyjase
Postby jaseyjase » Mon Sep 03, 2012 2:59 pm
Use pliers to pull gear cables before you pinch bolt them, the extra few mm you get instead of using your fingers helps with cable tension.
Now i can shift into my big rings properly :oops:
bigfriendlyvegan
Postby bigfriendlyvegan » Mon Sep 03, 2012 4:39 pm
jaseyjase wrote:Use pliers to pull gear cables before you pinch bolt them, the extra few mm you get instead of using your fingers helps with cable tension.
Use a third hand tool. Much better than pliers for this sort of job - in fact, it's the right tool for this sort of job, pliers aren't.
jaseyjase
Postby jaseyjase » Mon Sep 03, 2012 6:41 pm
yep, in my next order basket.
**edit**
i should add though, while i was you tubing installation, i came across what looked like a promo vid from SRAM about installing FORCE and they just used pliers to pull the cable, no third hand tool.
Users browsing this forum: Google [Bot], septuagenarian
