Gates belt drive - ShimanoSG-700Alfine compatibility?
polydexta
Postby polydexta » Fri Jan 25, 2013 11:28 am
Does anyone know if a Gates belt drive setup can be used to drive the Shimano Alfine 700 or the Rohloff 14 speed?
Re: Gates belt drive - ShimanoSG-700Alfine compatibility?
Postby il padrone » Fri Jan 25, 2013 2:03 pm
Some discussion from the Thorn Forum about this, and more specifically a response from a manufacturer. It seems that with a Rohloff, to retain their very valuable worldwide warranty, you'd need the conversion to be done by Rohloff and using a frame that would meet their specs for rigidity.
Probably cheaper and easier to get a bike that is already designed for it. There are such, but most are sold out of Europe and will cost $$$$.
Tout Terrain Silk Road
<too big image removed>
Retrofitting to the Alfine 11 I know little about, but it may be an easier task :?
Sparx
Postby Sparx » Fri Jan 25, 2013 2:07 pm
I have an Avanti Inc 3 which has an Alfine 11 speed hub and Gates CDX belt drive
polydexta
Postby polydexta » Sat Jan 26, 2013 7:42 am
Thanks for the tips. Great places to start.
Postby find_bruce » Sat Jan 26, 2013 10:22 am
Fitting a belt drive to an Alfine 8 or 11 is reported to be fairly straight forward.
A Di2 (electronic shifting) Alfine is much more problematic, although apparently it is possible, at least if you have access to a machine shop.
AUbicycles
Site Admin
Site Admin
Postby AUbicycles » Sat Jan 26, 2013 4:38 pm
Agree with il padrone, working with a frame designed for a carbon drive will save time and money.
outnabike
Postby outnabike » Sat Jan 26, 2013 6:36 pm
Hi polydexta,
This company seems to have some clues on installation.
http://www.stkildacycles.com.au/gates-belt-drive-
http://www.stkildacycles.com.au/rohloff
Crawf
Postby Crawf » Sat Jan 26, 2013 9:22 pm
polydexta wrote:Does anyone know if a Gates belt drive setup can be used to drive the Shimano Alfine 700 or the Rohloff 14 speed?
Yes straight fit, 3 spline, fits on as you would with a normal chained sprocket.
WestcoastPete
Postby WestcoastPete » Sat Jan 26, 2013 10:06 pm
St Kilda Cycles built my touring bike up with a Rohloff and Gates Belt Drive. It's a modified Charge Duster. I love it. I'd get the Center Trak if I were doing it again, but the extra 2mm width of the belt might cause problems on a modified frame.
http://www.crazyguyonabike.com/doc/page ... 85919&v=LC
