CNC engraving on C-Delta brakes
• Page 1 of 1
CNC engraving on C-Delta brakesHaving had success with my question about polished aluminium I will ventre into my next problem with restoration of my Chesini X-Uno. I was fortunate to get a NOS C-Delta brake engraved with Chesini. Unfortunately there was only one. I have bought another standard C-Delta and would like to engrave the Chesini name and logo onto the aluminium cover plate. I have tried a number of engravers and they all say no, so now I am chasing a CNC engraver. Has anyone used successfully a CNC engraver in the Brisbane Gold Coast area. If I am not successful I have even thought about doing it myself. I have a small engraver so will try on scrap first. The original which has obviously been routed is a little rough. Alternatively someone may have a Chesini C-Delta brake cover collecting dust and would like to see it on a finished bike.
Re: CNC engraving on C-Delta brakesCyclomondo has had some bits done I believe, beyond his extensive range of decals. I'd contact him.
Kym
All manner of half finished projects and a bit of randonneuring I used to be tech-savvy. Now I'm just tech-weary.
Re: CNC engraving on C-Delta brakesSaw on Ken Evans Instagram that he just had a stem pantographed maybe check there. You have the original which makes the pantographing process much easier...
Re: CNC engraving on C-Delta brakesI think Greg Softley has his work done on his pantograph
Re: CNC engraving on C-Delta brakesA bit out of left field, but try Brisbane Watch Repair Centre at Woolloongabba, they supply equipment to engravers and also do engraving on site.
Re: CNC engraving on C-Delta brakesThere's a group at geebung - name escapes me right now but I'll get back to you.
Re: CNC engraving on C-Delta brakesThanks guys. I am getting dead ends at the moment. Greg Softley cannot do curved surfaces and the C-Delta is curved.
Re: CNC engraving on C-Delta brakesPerfect Perforations
you could think about this company (in USA). It was my Plan B when I was getting the engraving done on the Shockstop master. The replies were prompt and the pricing was sensible, and they seem to know their way around bike parts. Philip Last edited by Clydesdale Scot on Wed Feb 06, 2013 2:38 pm, edited 1 time in total.
Re: CNC engraving on C-Delta brakesThanks, I have sent photos to "Perfect Perforations"
Re: CNC engraving on C-Delta brakesGeorge Hamilton at H.A.B. Engineering in Airport West (Melb) can do copy pantographing. He is a Campagnolo enthusiast, and sympathetic to the restoration cause.
His phone number is 03 9338 7655 Warren
Re: CNC engraving on C-Delta brakesThanks Warren, I should have spoken to you earlier. Expert on Malvern Stars and it would appear everything else in biking.
Re: CNC engraving on C-Delta brakesWhat ever you do don't bloody try to engrave it your self or even let some one else do it by hand.
If it cant be pantoed dont do it, Just put the panto on the front brake and leave the rear plain.
Ditto, I'am a retired hand engraver, I would not touch aluminium with my experience. As far as an engraving metal (by hand) it is CRAP & should only be attempted by a revolving cutter in a mechanical engraver, eg pantograph machine. We used to cut logos , like a Rotary wheel which was quite complicated, but you started large, tracing a paper logo by hand & kept reducing untill the pattern had straight lines, once you had the plastic pattern it could be reproduced over & over. ( I should start up again??)
Re: CNC engraving on C-Delta brakesI'm a machinist and I do CNC engraving. But a one off job on a 3D curved surface would involve laser scanning the surface then generating toolpaths in CAM. Then you would have to jig the part in the correct orientation. If you could find someone capable and interested it would likely be in the range of $300-500.
Re: CNC engraving on C-Delta brakesThanks again guys for your comments and help. I was only joking when I said I'll engrave myself. It has been hard enough painting the bike frame myself with all the fancy line shadowing so I don't want to start a new skill. Warren's friend George Hamilton says he can do it on his panograph so I have sent them to him. I did get a reply from Perfect Perforations in the States and they can do it as well if I supply a tiff file which I can do. Anyway I will see how I go with George. He has old bikes himself so is a sympathetic machinist.
Keep us in the loop
Re: CNC engraving on C-Delta brakes![]() I sent the two plates to George and spoke to him yesterday. He has no problems in copying the logo and Chesini to the blank plate on the left. He did say that the paintwork in the logo and letters may get scratched. This is not a problem for me as I will repaint them. He thought the original Chesini plate was beautiful so I hope I can reproduce the paint detail on the blank plate. Will let you know when I receive them.
Re: CNC engraving on C-Delta brakes![]() Stage 2 completed by George Hamilton in Melbourne. Thanks again to Warren Meade for introducing George to me. Now to replicate the paint job. Base coat, masking, shadow top coat, remove masking, dusting top coat, three clear coats and then painting the lettering by hand. Hope to have it ready for the Gold Coast Retro Ride on the 13th April if the bl....y rain stops by then.
This is so awesome. I think the most difficult part will be keeping the coats so light that the Campy logo still cuts through.
Re: CNC engraving on C-Delta brakesWell I have finished it for the first time. Found that dusting coats are very difficult but because it took so long and I wanted to ride the bike so I accepted what I had done and will redo when I have found some more patience. Have a look at the "Shows us what you got" post for all photos.
[img [/img]
• Page 1 of 1
Who is online |
