Identify Bike Chain / Gears
bm187
Postby bm187 » Wed May 15, 2013 2:53 pm
Hey there,
I'm attempting to restore my fathers old bike and it is in need of a new chain. Can anyone identify the gear structure and chain type needed to replace this one!?
Seems there are 5 gears on the back with a derailleur and 2 gears on the front.
Pics below – Thanks!
Mozzar
Re: Identify Bike Chain / Gears
Postby Mozzar » Thu May 16, 2013 2:46 pm
Doesn't matter what brand the chain is as long as it is suitable for 5 speed and you must remember that your chain and cluster should be kept as a matched set or you might have problems with a slipping chain. I would sugest getting a new chain and cluster.
Most 7 speed chains these days are suitable for 5 speed anyway but you might waht to check that it is suitable before buying.
zero
Postby zero » Thu May 16, 2013 3:14 pm
Mozzar wrote:Doesn't matter what brand the chain is as long as it is suitable for 5 speed and you must remember that your chain and cluster should be kept as a matched set or you might have problems with a slipping chain. I would sugest getting a new chain and cluster.
I'd be suprised to find he needs a new freewheel. I usually get 3 chains per cluster, and 9 speed cassettes with vaguely modern profiling wear far faster than thick old 5 speed freewheel sprockets.
ironhanglider
Postby ironhanglider » Thu May 16, 2013 5:17 pm
I wouldn't be surprised though it will depend on wear.
On the other hand there is a good chance that the gear levers are not indexed, so it is likely that he could get a 7 speed cluster which are more commonly available, cheap and shift better too.
Cameron
Postby singlespeedscott » Thu May 16, 2013 10:17 pm
Your dads old bike is running a Suntour Cyclone drivetrain that would indicate a 6 speed freewheel. I would go to the Ribblecycles.com and buy this:
http://www.ribblecycles.co.uk/sp/road-t ... 0000000000
A great chain that will last along time.
Users browsing this forum: danse, Google [Bot]
