Help removing remnants of bar tape glue from bars?
janus77
Postby janus77 » Thu Jun 05, 2008 1:55 pm
I removed the old tape from these bars last night, there's a heap of stick schtuff left on them, tried metho and kero.. anyone got any tried and true methods for removing the glue?
janus77
Postby janus77 » Thu Jun 05, 2008 1:57 pm
all I can find on the net is someone saying to use Turps and scrape the stuff off..
hmm, had another idea, maybe eucalyptus oil would be a goer.
m@
Postby m@ » Thu Jun 05, 2008 3:11 pm
You could try a citrus-based cleaner.
Postby familyguy » Thu Jun 05, 2008 3:24 pm
Depends what you're doing...you're not retaping them?
Orange oil, steel wool and a little AutoSol to shine them up if you're doing the dog-c*ck partial tape job for a single speed or something.
Otherwise just scrape it back and tape over it.
challs
Postby challs » Thu Jun 05, 2008 3:25 pm
Eucalyptus oil and a green kitchen scourer - shouldn't be so hard as to scratch the finish of the bars.
Jean
Postby Jean » Thu Jun 05, 2008 3:27 pm
Citrus oil with rag followed by Chux Magic Eraser (I think that is what it's called) should do the job. BUt of you're taping over it again - don't bother.
Matt_Matt
Postby Matt_Matt » Thu Jun 05, 2008 6:08 pm
Head to your local autobarn and pick up some "Prepsol or Prepwash"
It's a liquid hydrocarbon degreaser.
Matt
VIC Mech
Postby VIC Mech » Thu Jun 05, 2008 6:37 pm
Sounds odd I know but you could trynail varish remover and it comes on handy little cloth pads too...so my wife says!
Cheers m'dear, JJ
nzdans
Postby nzdans » Thu Jun 05, 2008 7:46 pm
OK, been doing this one way too many times; Nulon Brake Cleaner from Super Cheap + a decent sized rag-guaranteed. The can of brake cleaner will set you back about $10 (don't bother with the cheaper stuff, it is rubbish), you will use at most 1/4 of a can to do the bars and will find it a great resource to have in the garage for other jobs. Beware it will give some plastics a hard time if rubbed in.
Edit:I should mention, any other quality brake cleaner will also work great. Unless you plan on using the bars sans tape you could always cover the sticky stuff with...
handlebar tape!!?
lisanne
Postby lisanne » Thu Jun 05, 2008 8:11 pm
challs wrote:Eucalyptus oil and a green kitchen scourer - shouldn't be so hard as to scratch the finish of the bars.
+1 for eucalyptus oil it's great at getting left over sticky stuff like that off
531db
Postby 531db » Thu Jun 05, 2008 9:17 pm
plus 2, I use Bosisto's Eucalyptus Spray and Home Brand 'green' scourers.
