BB and Cassette Removal
foo on patrol
Postby foo on patrol » Sat Aug 17, 2013 3:38 am
Tell me knowledgeable people, is this all I need to remove my BB (Rotor Q) and to put on and take off my cassettes? :? :oops:
http://www.wiggle.com.au/lezyne-external-bottom-bracket-and-cassette-tool/
Foo
Goal 6000km
}SkOrPn--7
Re: BB and Cassette Removal
Postby }SkOrPn--7 » Sat Aug 17, 2013 9:24 am
Nope your going to need a spanner or I hate to shake your hand...... :D
You will need a chain whip as well that suits your cassette something like below.
http://www.wiggle.com.au/lifeline-professional-7-11-speed-chain-whip/
foo on patrol
Postby foo on patrol » Sat Aug 17, 2013 1:36 pm
So I could just use a claw hammer and chain to do the same as this? :)
Foo
Goal 6000km
Postby bychosis » Sat Aug 17, 2013 10:18 pm
Is possible without chain whip, just harder. I've used a rag wrapped around the cassette a couple of times. If you dont want to shell out for a chain whip they aren't hard to make. A bit of flat bar, a drill, some chain and a chain breaker. Copy the design from a pic on the net. Mine is home made a works fine, but would be nicer with an 'ergonomic' grip, rather than a thin flat piece of steel.
GAV!N
Postby GAV!N » Mon Aug 19, 2013 3:03 pm
It's worth just shelling out for a cheap tool kit such as - http://www.ebay.com.au/itm/321131130118 ... 1131130118
Then you can change cassette's, chains, cranks etc easily at home and keep your bike in good shape without forking out for a bike shop to do it. Yeah it's a cheap tool kit, and yeah the bike shops might not be happy that I'm not giving them business, but hey, I'm a tightass and I'm not going to throw money away for no reason :lol:
foo on patrol
Postby foo on patrol » Mon Aug 19, 2013 6:06 pm
Thanks Gaven, I will check out that site when I get home Friday. :)
Foo
Goal 6000km
ironhanglider
Postby ironhanglider » Mon Aug 19, 2013 6:46 pm
BTW Foo, the tool you linked, has a 32mm head.
This is the same size as old style headset spanners which you might have. It is a bit bigger than the standard 12" shifter can handle from memory.
Cameron
Postby Duck! » Mon Aug 19, 2013 8:28 pm
ironhanglider wrote:BTW Foo, the tool you linked, has a 32mm head.
Cameron
Almost. A 12" shifter will open to 35mm, which is fine for a 1" threaded headset, which has 32mm nuts (but you still need a headset spanner for the lower one).
1 1/8" threaded headsets have 36mm nuts, which obviously the shifter won't quite open enough for.
foo on patrol
Postby foo on patrol » Tue Aug 20, 2013 7:57 am
My bottom bracket is Rotor Q not one you can put a shifter on. Idon't know what it is called in todays lingo :oops:
Foo
Goal 6000km
ironhanglider
Postby ironhanglider » Tue Aug 20, 2013 3:45 pm
foo on patrol wrote:My bottom bracket is Rotor Q not one you can put a shifter on. Idon't know what it is called in todays lingo :oops:
Foo
You'll need something to turn the tool though.
Cameron
foo on patrol
Postby foo on patrol » Wed Aug 21, 2013 6:48 am
foo on patrol wrote:My bottom bracket is Rotor Q not one you can put a shifter on. Idon't know what it is called in todays lingo :)
Foo
Cameron
I have that well and truly covered, the one advantage of driving trucks, I have a good tool kit. :(
Foo
Goal 6000km
