Giant Cypress Suspension Forks question.
tekapo
Postby tekapo » Fri Aug 23, 2013 6:33 pm
I am playing around with the forks on a Giant Cypress. The fork is a Suntour NEX4610
http://www.srsuntour-cycling.com/dstore ... html?sid=1
Now, there are two nuts and threaded bolts at the bottom of the forks. What are these nuts for? and How tight/torque applied should they be? I checked them for tightness, and tried to tighten them up, but it seems to go on for ever. I am guessing they are some sort of pretension/adjustment nut???
Any ideas? Suggestions?
Thanks in advance.
Re: Giant Cypress Suspension Forks question.
Postby Mulger bill » Fri Aug 23, 2013 8:00 pm
Not familiar with them but it is possible that they are what stops the lowers falling off.
Have you dug around in THIS page?
tekapo
Postby tekapo » Fri Aug 23, 2013 9:18 pm
Mulger bill wrote:Not familiar with them but it is possible that they are what stops the lowers falling off.
Thanks, found the exploded diagram in their workshop book, I think it adjusts the preload on the rebound rubber as well as holding everything in. That's why there doesn't seem to be a bottom when I was tightening the nut. Although when I took the nut off earlier, it doesn't seem to come off, maybe something else is holding it as well.
Now I guess I just play around with the preload to adjust the rebound? Would it be correct to say that a higher pretension = stronger rebound? Anyways, right now the nut is probably tighter by about 1-2mm than what it as previously, I'll have a ride and see if I can feel any difference.
Postby Duck! » Sat Aug 24, 2013 12:24 am
No, the preload adjustment only alters the compression rate of the spring. The fork in the Cypress is a pretty basic setup, and doesn't have rebound adjustment of any sort; even with minimal preload on the spring it'll still kick back pretty hard.
The bolts/nuts on the tips do simply hold the whole thing together, but you need something with a really long extension to get to the other end of the bolts deep inside the fork to stop them spinning.
