Oppy C5 cable routing
CAAK
Postby CAAK » Sat Aug 24, 2013 3:13 pm
Build under construction.
C5 2011ish model. Can you educate me on best way to route front derailleur cable?
Photo would be helpful.
Also do you run gear cable outter all the way through frame?
If not are special large ferrals required at the holes into head tube?
Thanks.
Re: Oppy C5 cable routing
Postby familyguy » Wed Aug 28, 2013 8:41 pm
Inners run all the way through, from shifter to below the BB junction. Put a ferrule on the BB end.
ACT SC600
Postby ACT SC600 » Mon Sep 02, 2013 10:13 am
CAAK wrote:Build under construction.
Thanks.
Andrew.. I have 2 oppy C5s - plus I'm located in the ACT... Let me know if you want to have a look
Cheers chris
