My first spill!!
Low Racer
My first spill!!
Postby Low Racer » Sat Jul 12, 2008 11:12 am
Hi,
Went out today and was doing well until I decided to take a gravel shortcut. Mistake!! The front skinny tyre dug into the gravels and I am gone. Was probably doing between 10 - 15km/hr. Had taken same route without problem in past.
Gravel rashes to my hip and leg. Surprisingly only minor rashes on my elbow. Checked the bike and apart from some scratches, nothing serious.
I will be taking that road slowly next time or probably best just to avoid it.
Chong
Uba Tracker
Postby Uba Tracker » Sat Jul 12, 2008 12:11 pm
Owwww, sorry to hear about the buster :( , look at the bright side if you were on a DF you'd have had a lot further to fall. :) Out with the Dettol and Band Aids.
A bad day's riding beats a good day's work everytime
Kalgrm
Postby Kalgrm » Sat Jul 12, 2008 12:22 pm
Ouch. I always get timid on dirt or dirt covered roads when I'm on the 'bent, and now you will be too.
Graeme
froodh
Postby froodh » Sat Jul 12, 2008 2:18 pm
I second Uba's sentiment. When I lived in Sydney, I went riding on my DF road bike around Coogee, going down Moverly Rd at >40 kmph, got my front tyre stuck in the crack between the asphalt and the concreted-over tram tracks. I went flying over the handle bars, and got knocked unconscious. People in the car behind me managed not to run me over, dragged me off the road and used my mobile phone to call an ambulance - taken off to Prince of Wales hospital emergency under observation for concussion and had scrapes all down the left side of my body - still have the scar on my shoulder and the other scars show up if I have too much alcohol to drink! Had chiro treatment for months after to correct my neck & back getting all bent out of shape. The bike was fine - it didn't have as far to fall as I did, but I sold it and got a mountain bike instead to have wider tyres. 10 years later, my bad back resulting from this accident is now why I decided to get a 'bent :D
Low Racer
Postby Low Racer » Sat Jul 12, 2008 3:44 pm
Hi guys,
Thanks. Sorry to hear of your accident which still trouble you to this day. Do you wear helmet back then?
Unfortunately what we love to do can be dangerous or even life threatening, so take care out there and have fun.
recumbenteer
Postby recumbenteer » Sat Jul 12, 2008 4:00 pm
I ride a Trike :wink:
but I've also managed to get intimately aquainted with the groud....at speed :shock:
:arrow: got gravel rash whilst still cleated in....LOL
and the trike was only 4hrs old :oops:
http://rvvelonaut.blogspot.com.au/
Speedwell GTS Deluxe
Bates Royal Star
CoolCruza
Rotovelo
froodh
Postby froodh » Sat Jul 12, 2008 8:59 pm
Wouldn't be here to tell the tale if I wasn't wearing a helmet. Cracked the helmet, scratched my glasses and tore the shirt I was wearing. Had to get a new helmet & new glasses.
Freddyflatfoot
Rolling a trike?
Postby Freddyflatfoot » Sat Jul 12, 2008 10:25 pm
Sorry to hear about your spill, and glad you're ok!
Even roadies don't like taking their skinny tyres off the bitumen, so methinks you're a brave man! Gravel can be dodgy at the best of times.
On another note, I let a friend ride my trike yesterday, and he did something I haven't done, he rolled it! Not sure how he did it, but it seems like he was riding in the middle of the road, quickly moved to one side, and then just as quickly turned the other way to execute a U turn. Seems, he 'unbalanced' the trike and put her on its side.
Good thing he wasn't hurt, but i think it shocked him a bit! He must've thought it was a go-cart, or is on rails or something! ;)
Cheers!
Rob
Homebuilt trike, with electric assist
26"/20" trike, "Goanna"
SWB recumbent, 700C/451 , "Kookaburra", homebuilt.
FWD project (Cyclone).
Optima Raptor
rog on a bike
Postby rog on a bike » Sat Jul 12, 2008 11:28 pm
Must be the day for it. On the MTB today with new egg beater pedals went to hop over a log. Yep measured my length on top of said log.
Funny how your feet always come out of the pedals when you hit the ground! That part really sux!
A bit of Betadine and a roll on the bent tomorrow should fix it.
Rog
EVERY HILL HAS A CREST. GETTING THERE BEFORE THE HEART ATTACK IS THE TRICK.
Storm
Postby Storm » Sun Jul 13, 2008 12:14 am
Occasionally I come off my DF's but hardly ever, maybe it's because of the stand on pedals and put bike under you thing whereas on my SWB I have fallen three times so far, first was going slow turning left onto a main road with not enough speed so I fell to the side, second was quite a bit quicker while turning a corner and avoiding a car I locked the rear brakes and the back wheel slid out from under me in a split second, third was the same as lowracer I ran off a paved path while cornering and hit some of the soft edge sand and the bike just fell.
None of these falls would have occurred on a DF but by them happening I now have more experience and learned how to better ride a bent
1. concentrate on balance more while also checking for traffic 2. use the front brake more than the back and avoid using the back brake when leaning
3. avoid soft dirt like the plague and if you do need to cross any be extra careful not to lean.
Chong you will also be more aware now.
~~~~ ~ @_,~,- -_-’o,~~~ ~ @_,~,- -_-’o,
~~~ ~ (*)\____/(*)~~~ ~ (*)\____/(*)
Low Racer
Postby Low Racer » Sun Jul 13, 2008 9:42 am
Hi Storm,
The fish tailing on the SWB scares me. I rarely use the rear brake unless I am coming to a halt in straight line or reducing my speed coming down the hill in straight. Otherwise, it is front disc brake all the time.
The gravel rash made sleeping so uncomfortable and didn't get a good night sleep at all. A slight movement and a rub on the doona make sure you know the rashes are there. I don't like covering it up as it might become moist. Should I be covering it up?
Chong
Kalgrm
Postby Kalgrm » Sun Jul 13, 2008 11:13 am
You should be treating the "rash" as a burn. There is a microfibre adhesive bandage available for applying over such wounds: ask your pharmacist about them. I can't remember the name at the moment.
Graeme
Low Racer
Postby Low Racer » Sun Jul 13, 2008 12:57 pm
Hi Graeme,
The irony in your advice is I am a pharmacist, but not very good when it comes to looking after myself. There are few in the market i.e bactigras, micropore etc. I can actually get some from work.
Chong
Kalgrm
Postby Kalgrm » Sun Jul 13, 2008 1:42 pm
D'oh! :lol:
Freddyflatfoot
Postby Freddyflatfoot » Sun Jul 13, 2008 2:50 pm
So does a pharmacist know about first aid? I wonder!
With braking, it becomes a little difficult when you are swapping between a trike, and a SWB!
On the trike, I *only* use the front brakes! lol!
But I guess coz I'm used to applying both brakes fairly evenly on the trike, I try and use both F and R when on the SWB, mostly out of habit, but tend to have the emphasis on the F brake.
I was always taught to use both brakes together, with the emphasis on the front, maybe that's what (mostly!) keeps me out of trouble?
Cheers!
Rob
Optima Raptor
Uba Tracker
Postby Uba Tracker » Sun Jul 13, 2008 3:02 pm
Kalgrm wrote:D'oh! :lol:
Hehehehe.........had to be done.
Harry
