Latest Reviews and Articles
Will your next bike be Intelligent? ABS and Smart Bike Tech
Vitus Vitesse EVO Disc Review – Speed Machine indeed!
6 speed groupset question
Postby brit_in_oz » Sat Jan 18, 2014 10:09 pm
On my old repco frame i have Shimano RX100 components with a 26 capacity rear mech. I found a new cassette hard to find so i bought a HG50 12-28, but the top two spockets rub badly and cannot be used really. The rear mech cannot accomadate it, so i was wondering would a 6 speed from a MTB be ok to use, such as a Shimano Tourney RD-TX35 Rear Derailleur 6 speed?
Don't mistake lack of talent for genius
- KGB
Re: 6 speed groupset question
Postby KGB » Sat Jan 18, 2014 10:45 pm
Probably. I'd expect it to work.
The other option is to rebuild your cassette and mix mostly new cogs with the top couple from the old one. Thinking about it, this would be difficult/impossible on a screw on cluster.
Have you tried adjusting the b-screw on the derailleur?
A cheap shimano mtb cluster should cost little enough that its worth a try I guess.
- foo on patrol
Postby foo on patrol » Sat Jan 18, 2014 11:21 pm
So you bought a six speed cluster but you are having trouble with the top two cogs, is that right?
I would think that you have an adjustment problem or there is a spacer missing from those two. More inclined to think adjustment as I don't remember there being any spacer washer on them.
I just had a look at my old Regina and Shimano 600 clusters and the spacing is even all the way through! Are you cross chaining to far?
Foo
Foo
Goal 6000km
Goal 6000km
Postby mitzikatzi » Sat Jan 18, 2014 11:30 pm
brit_in_oz wrote:On my old repco frame i have Shimano RX100 components with a 26 capacity rear mech. I found a new cassette hard to find so i bought a HG50 12-28, but the top two spockets rub badly and cannot be used really. The rear mech cannot accomadate it, so i was wondering would a 6 speed from a MTB be ok to use, such as a Shimano Tourney RD-TX35 Rear Derailleur 6 speed?
My understanding is this will work. It is the shifter that makes it a six speed. Same pull just different amount of positions. In fact any 9 speed Shimano derailleur should also work.
Postby LG » Sun Jan 19, 2014 8:57 am
I have used RX100 rear derailleurs on 28 cog cassettes with no problem at all (52-39 chainrings). There should be enough length in the derailleur for the jockey wheel to fit under the cog. I'd assume the second largest cog on that cassette would be a 24, which is well within the manufacturing specs, so if you're having trouble with it there's likely to be an adjustment problem. If you've swapped out from a smaller cassette, it may be a case of the chain being slightly too short.
LG = Low Gear
- KGB
Postby KGB » Sun Jan 19, 2014 12:24 pm
I was assuming the problem was that the 28t cog was too big for a short cage derailleur - causing the derailleur to basically run against the cog. The B screw is the one that adjusts the angle of the derailleur body against the hanger on the frame. Sometimes cranking this in will give enough clearance to run the bigger cog.
Postby brit_in_oz » Thu Jan 23, 2014 8:52 pm
Thanks for the advice. i should have said the capacity is only 26 which i only found out later. The problem is 90% on the 28 but the 24 isnt perfect. i have been told perhaps its due to the spring tension dropping, but i have adjusted the B tension to the maximum and wont go any further. I have also put a new chain on at the same time so its not that.
- ldrcycles
Postby ldrcycles » Thu Jan 23, 2014 9:26 pm
Weird one, I definitely would have put my money on a too short chain or b screw all the way out. If you can't get the RX100 to play nice then mitzikatzi is right, pretty much any derailleur will work just fine, I just built a bike the other day using a 7 speed shifter with a 9spd Deore, no worries.
- KGB
Postby KGB » Thu Jan 23, 2014 10:09 pm
True, generally speaking the derailleur just does what its told to do by the shifter (unless you go switching brands like from shimano road to sram mtb).
- Cyclocross
- Cycling Brands
- Azzurri
- Bianchi
- BMC
- Campagnolo
- Cannondale
- Cervélo
- Colnago
- Focus
- Fuji
- Garmin
- Giant
- Malvern Star
- Merida
- Scott
- Shimano
- Specialized
- SRAM
- Surly
- Trek
- Custom Builders
- Generic Carbon
- Delete all board cookies
The largest cycling discussion forum in Australia for all things bike; from new riders to seasoned bike nuts, the Australian Cycling Forums are a welcoming community where you can ask questions and talk about the type of bikes and cycling topics you like.
Brought to you by Bicycles Network Australia | © 1999 - 2018 | Powered by phpBB ®
