Convert SS to Fixed?
KetoPirate
Postby KetoPirate » Mon Jan 25, 2016 4:08 pm
Hi all
I bough a cheap single speed bike and took the crappy brakes off it. Is there a simple way to conver the single speed wheel to a fixed? Or do i have to replace the whole rear rim?
KGB
Re: Convert SS to Fixed?
Postby KGB » Tue Jan 26, 2016 8:12 am
It's quite easy to remove the ss cog but will require a specific tool. Threading on the fixed cog can be done by hand BUT to tighten it properly you either need a chain whip tool or you really need to Stomp on the pedals hard (ideally while clipped in). Your biggest problem is that there most likely won't be a lockring thread on the hub. I don't use a lockring when racing on the track but on the street I'd say it's a good idea to have it on there as a safety measure to stop the cog unwinding in emergency situations.
Post a pic of the hub and we'll be able to tell you more.
In short: its easy but may require tools you don't have.
KetoPirate
Postby KetoPirate » Tue Jan 26, 2016 12:36 pm
Thanks KGB
I managed to get the single speed free wheel cog off. It was just the standard threaded type. I ordered this: https://www.velogear.com.au/bike-parts/ ... ilver.html
Hopefully it fits. After a bit of research i found out about the "suicide hub" and plan to use red loctite and rotafix it on. Will keep the front brake just in case.
If anyone knows where I can get a fixed 170mm symmetrical fat bike hub i will just build a fixed rear for it but will use the death trap method for now :P
mikesbytes
Postby mikesbytes » Tue Jan 26, 2016 2:27 pm
That cog will almost certainly fit there's only one screw-on standard. There's a small chance that your chain line may be out, so check it once you have everything together.
And make sure you use a lock ring
hartleymartin
Postby hartleymartin » Mon Oct 30, 2017 9:41 pm
You can use a bottom-brace lock-ring on a threaded rear hub - it is the same diameter and thread. This used to be called a "suicide hub" as the lock ring can unthread. proper fixed gear hubs have a left-hand threaded locking which will tighten as the sprocket loosens.
Martin Christopher Hartley
