27.5 wheel recommendations
Postby hills60 » Fri Mar 17, 2017 11:00 am
Hi all. Have a Giant Trance 27.5 with PX-C 2 alloy rims and have just discovered the rear has a fairly extensive split running down the middle. Only 30 months old, run fairly low pressures (tubed), and don't do jumps etc so a little disappointed. Anyway, questions are
1. Should I just go get an OEM replacement or is this opportunity to get something better / lighter / tubeless etc. and
2. If the latter, what would people recommend?
Re: 27.5 wheel recommendations
Postby mikgit » Fri Mar 17, 2017 7:03 pm
you probably won't be able to get an OEM rim/wheel, and why would you want to replace like for like after not he best experience?
DO you just want a rim, or a whole new wheel, or a wheelset? How much do you want to spend
Look 675 Pro Team, Cervelo R3, GT Xizang, GT Zaskar, Scott Spark 710, Yeti ARC, DiamondBack Apex
Postby Duck! » Fri Mar 17, 2017 11:00 pm
Get something better; the P-XC series wheels are pretty ordinary.
Postby silentbutdeadly » Wed Mar 22, 2017 1:47 pm
Option 1b...without a doubt.
On a Trance I would pick something like this http://linksports.com.au/spank-oozy-tra ... e-wheelset or go with a custom wheel based on the same rim and a Hope hubset. For a budget hub that is still better than the Giant OE hub you have go with the Novatec F&R D771/772 pair on Cycling Deal for $135.
