Wheel Builders in Sydney?
hartleymartin
Postby hartleymartin » Sun Oct 22, 2017 9:56 pm
Hi Everyone! Long time, no post.
I am looking to obtain a set of Velocity Atlas 650B (584mm BSD) rims and have them laced up on touring hubs somewhere in Sydney. I would much appreciate some help with getting a set of good touring wheels made (for a clydesdale class rider!)
Martin Christopher Hartley
Re: Wheel Builders in Sydney?
Postby familyguy » Mon Oct 23, 2017 8:44 am
Ben at Cicli Spirito: https://www.spirito.com.au/ Not real local to you though.
hartleymartin
Postby hartleymartin » Mon Oct 23, 2017 2:00 pm
As long as it is somewhere in Sydney I can get to it by train/bicycle.
queequeg
Postby queequeg » Mon Oct 23, 2017 5:22 pm
hartleymartin wrote:As long as it is somewhere in Sydney I can get to it by train/bicycle.
Ben is 2 minutes walk from St Leonard’s station.
hartleymartin
Postby hartleymartin » Tue Oct 24, 2017 2:58 am
Well, I've got to be committed to the new 650B wheels now, as I have paid for the Tektro R559 brakes, and bought 3x 650B Marathon Plus Tyres. Just have to find a supplier for the Velocity Atlas 650B rims and make a final decision on the hubs. Do I stick with threaded freewheel hubs or move to a 130mm cassette freehub? The bicycle frame I have is spaced at 126mm so I could spring the 130mm hub into it, but not a 135mm one.
Thoglette
Postby Thoglette » Tue Oct 24, 2017 2:24 pm
hartleymartin wrote: Do I stick with threaded freewheel hubs or move to a 130mm cassette freehub?
Image According to Sheldon Brown, with 7 cogs or less freewheels are strong enough but 8/9/10 is asking for problems. The other challenge is getting the gearing you want: 10 and 11 teeth are pretty much freehub only propositions, especially if you want to mix them with 30+ teeth cogs.
Right now the only reason I'd go freewheel is if you've an accessory (e.g. a drum brake) you really want to mount on the other side of a flip-flop hub OR you've got some beautiful vintage piece OR you're going single speed.
If you want gears, then a decent rebuildable freehub with lots of spokes (36) and 8/9/10 Shimano cassette compatibility is where I'd start: e.g. vintage 105 or Ultegra. Second choice would be sealed bearing numbers from V-O or similar bespoke suppliers.
hartleymartin
Postby hartleymartin » Tue Oct 24, 2017 11:49 pm
I am running a 6-speed cluster, so I think freewheel should be okay then.
My cluster is a 14-17-20-24-28-32 6-speed from IRD - I wish that last one was a 34-tooth sprocket though!
Testing386
Postby Testing386 » Fri Nov 03, 2017 2:27 pm
I've used Omafiets in Redfern for many wheel builds. Great crew and a short walk from the station.
Users browsing this forum: foo on patrol, jasonc, Rawshack, sonjaneufeld, uart
