Shimano BR-R317 pad compatibility
Zippy7
Postby Zippy7 » Wed Dec 20, 2017 10:01 pm
I have Shimano BR-R317 disc brakes, and they came with G01S pads.
I have a couple of spare B01S pads, so I tried a pair in the brakes as they are very similar in size.
They fit, it seems to brake okay, but there is a slight rattle sometimes (presume there is a slight difference in the width)
Can anyone tell me if this would be a serious safety issue, or if its just a noise problem.
Don't want to have a big accident for the sake of a few dollars, but if its just putting up with some noise, then I will prefer to use the pads instead of losing the value.
Cheers.
Successful trades : Rheicel, Je, wgc138, 2ndeffort, celeste boy, rodneycc
10speedsemiracer
Re: Shimano BR-R317 pad compatibility
Postby 10speedsemiracer » Wed Dec 20, 2017 10:12 pm
There is apparently a minor difference in size, the B01S is not as wide and not as tall. Over a prolonged period of time the fore/aft movement (that's what you're hearing) especially under braking could damage or prematurely wear your caliper. The B01S will go into a caliper designed for a G01S but not the other way around, apparently.
Mmm, SunTour
Zippy7
Postby Zippy7 » Thu Dec 21, 2017 6:23 am
Well, it doesn't rattle under braking, but was wondering if it was going to be a serious issue.
I think I'll swap the B01S to the back and keep the G01S in the front and just go harder at the back to wear them out (unless I find a pair of cheap Spyres or HRDs to swap out the 317's)
10speedsemiracer
Postby 10speedsemiracer » Thu Dec 21, 2017 9:17 am
Pad will move back to front inside the caliper under braking, may hear a single clunk while it does this, and has the potential to damage the inside of the caliper.
Mmm, SunTour
Postby Duck! » Thu Dec 21, 2017 7:49 pm
As 10speed says, it's not worth the risk of potential damage to the caliper for the sake of a few dollars. Just use the right pads.
