gears skipping under load
gregcampbell
Postby gregcampbell » Tue Jan 23, 2018 7:07 pm
Why do my high ratio gears slip when I'm out of the saddle, but behave perfectly in the saddle?
ColinOldnCranky
Re: gears skipping under load
Postby ColinOldnCranky » Tue Jan 23, 2018 9:02 pm
Have you changed your chain recently? Or, failing that, your rear cluster?
Postby RonK » Tue Jan 23, 2018 9:24 pm
Most likey your chain and cassette is worn out.
Also a new chain on a worn cassette will often slip.
Postby Duck! » Tue Jan 23, 2018 10:40 pm
You're putting more load through when standing, uncovering issues with excessively or unevenly worn components.
If you tend to use those gears less than the mid- & lower-range gears, those sprockets will be less worn, and the worn chain will not mesh nicely. You may also notice a rumbly, gritty sensation when riding those gears while seated; the chain isn't meshing well, but in that position you're not overloading the chain/sprocket interface to cause it to slip.
Nate
Postby Nate » Wed Jan 24, 2018 12:48 pm
as above worn components...
or.... does it click or make noises when not under load?
if its clicking when not under load, then the deraileur could be *slightly* out of alignment, which on high gears could be caused by a frayed shifter cable.
Open the brakes up, apply brakes & have a look inside to check that too.
kb
Postby kb » Wed Jan 24, 2018 1:11 pm
Nate wrote:as above worn components...
Alignment issues can also be caused by improper cable path in the cable clamp (there’s a clear park tools video on it somewhere - I’ll chase it up if I remember)
rowdyflat
Postby rowdyflat » Wed Jan 24, 2018 1:42 pm
if they are jumping higher then prolly derailleur cable slt stretched turn doodah anticlockwise.
jumping everywhere bent derailleur hanger ?
