The Fleet.
The Fleet.
Postby bychosis » Sat Apr 28, 2018 7:13 am
As they are lower on the priority list I've had these for a while, not doing much.
Cyclops from council cleanup. When found it had been hacked a bit. The saddle was in two bits held together by some shelving steel and duct tape. The stem was half cut through, like with a hacksaw, and bars missing. Replaced the bars with some that I widened and switched the saddle from the Skywagen below after repairing the original saddle. As the guard and sissy bar were painted already I painted the bars etc to match and added the chainguard. Think I need to paint the seatpost now.
This Skywagen was off ebay, with another. It came with the saddle above, but when I repaired it figured it would suit a ratty style better so switched it in. The saddle was repaired from two rusty bits, split across the middle. Chose hessian because cheap, and I didn't have any Mexican blankets around. I also used a spoke to hold the back guard in place as the stays were gone. The sissy bar had a couple of suitable holes on position for that. Otherwise, except tyres (scrounged), this is in 'as purchased' condition. I rode it to work once for a laugh.
Might fill in the back of the seat one day, I've got a few large reflectors to whack on there.
Thirdly, a 16".
Not the original banana seat, it didn't come with one. No idea what they were thinking with the brandingon this. It's not for a BMX and what self respecting 16" sized rider is ging to want to have baby land stamped on their bike!
2 more to come after some more paint and fender construction.
10speedsemiracer
Re: The Fleet.
Postby 10speedsemiracer » Sat Apr 28, 2018 8:30 am
Nice
Mmm, SunTour
Re: The Fleet.
Postby bychosis » Sun Apr 29, 2018 7:41 pm
Rode these this afternoon. Total investment $50 (blue)+$40 (black) -$15 (sold a basket off the blue one). The blue is an Electra cruiser and a lot better ride than the Black Mambo one. Will tidy up the black one and move it on and plan to make some mudguards for the blue one to improve the look.
Re: The Fleet.
Postby bychosis » Wed May 09, 2018 12:40 pm
When I picked up the cruisers above I got some Google on and discovered a whole world of cruisers and mods that are done. Keen to try a little building, as opposed to assembling, I joined up the Rat Rod Bikes forum. They have 'build offs' where people all over the world build 'Rat Rod' bikes which then get voted on by forum members. Not much in the way of prizes (a bare frame if you are in the US), just enjoyment of building bikes. Some of them are pretty wild - chopped, stretched, hacked. Some are more tame - just assembled and painted.
I joined up as I've always enjoyed the Rat Rod style of build and now have a cheap black Mambo cruiser suited for the task. I've also entered this years Build Off to give me a deadline to finish my project! Here's a link to the build threads: http://www.ratrodbikes.com/forum/index.php?forums/build-off-13-build-journals.164/
Starting with:
it's a bit rusty on the surface, so needs some treatment:
With the idea of removing the front brake for clean lines, I got to cutting:
Re: The Fleet.
Postby bychosis » Wed May 09, 2018 12:48 pm
After I cut off the brake lugs, I decided to change the plan and create some triple clamp forks so I could increase the rake a bit on the front. Haven't got to building the forks yet, need to purchase some welding consumables.
Kinda like this:
Also decided that because the starting point was rusty and the paint needed to come off, I'd continue that theme. Removed the paint:
and once removed I dabbed on a bit of dilute acid/copper solution and over night the almost bare metal went to:
Once the 'paint' has cured I'll pinstripe a bit and clear coat it.
Re: The Fleet.
Postby bychosis » Fri May 18, 2018 12:57 pm
I need the steerer tube to make new forks. No turning back now.
A mock up of the forks to come. Yes, that is MDF and No, I wont be riding it in this condition :D The kids don't need a safety net around the trampoline so I got some tubing cheap.
Will also be pushing the seat back a bit. (welding still to come)
Scored some white-wall tyres by buying another cruiser, switching the wheels and reselling. $0 whitewalls. Looking something like this:
