Crazy tight freewheel
Mickey1980
Postby Mickey1980 » Wed May 02, 2018 10:27 pm
Hello, everyone.
I am changing a 6sp freewheel to a 7sp freewheel on my kid's bike. The only problem I can't take the old one off. I know it might be tight, but to that degree...? I have tried to hold a wheel while applying a breaker bar with the removal tool. Also tried to put the removal tool in the vice and rotate the wheel. Didn't work - had concerns of breaking spokes at the rim when holding the wheel. The wheel is 20' only, so not a lot of leveragee.
Any other tricks out there to remove it without damage to the wheel?
PS trying to unscrew counter clockwise.
Thoglette
Re: Crazy tight freewheel
Postby Thoglette » Wed May 02, 2018 10:54 pm
You're doing most of what Sheldon recommends.
Leave a tyre & tube on.
Put a skewer in (or do up the nut) to retain the removal tool.
Mount the tool in the bench vice.
HEAVE on the wheel. Hard! Eventually it will let go.
Or you'll have to take the freewheel apart and cut the core from the wheel. :-)
I've had not much luck in trying to get penetrating oil into these threads.
10speedsemiracer
Postby 10speedsemiracer » Wed May 02, 2018 10:56 pm
With a tyre mounted on the rim, have the wheel vertically against a wall and the ground simultaneously and wedge it in with your leg near a corner, so that when you lean on the breaker bar your direction of rotation is forcing the wheel/tyre into the wall.
I've found that having the breaker bar near vertical (about 11 o'clock), and pushing towards the wall and down, usually breaks a freewheel loose.
Mmm, SunTour
Postby Duck! » Wed May 02, 2018 11:06 pm
Mickey1980 wrote: Also tried to put the removal tool in the vice and rotate the wheel. Didn't work - had concerns of breaking spokes at the rim when holding the wheel. The wheel is 20' only, so not a lot of leveragee.
A 20-foot wheel would have a shedload of leverage..... ;-) I suspect you mean20".
I find this to be the most successful. You will need a lot of grunt, but the spokes will handle it. I've only ever had problems with breaking spokes when the wheel already has several broken. Keep the tyre on to give you more grip on the wheel, but make sure it's firmly inflated so it doesn't slip on the rim, which can rip the valve stem out of the tube.
Mickey1980
Postby Mickey1980 » Wed May 02, 2018 11:52 pm
Thanks, everyone!
Putting the wheel against the wall and pushing hard with the bar made it in the end! I wonder who could tighten it up to that extreme in a kid's bike!?
ValleyForge
Postby ValleyForge » Fri May 04, 2018 8:23 pm
Mickey1980 wrote:Thanks, everyone!
Boofheads who don't lube threads.
Ha ha ha! Cookies on dowels.
MelodyWheels
Postby MelodyWheels » Sat May 05, 2018 8:25 am
If you're throwing away the freewheel anyway, I've had a lot of success with destructive freewheel removal.
ironhanglider
Postby ironhanglider » Sat May 05, 2018 6:40 pm
I'm so tough I removed a freewheel from a tandem hub!
Cameron
Postby find_bruce » Sat May 05, 2018 6:46 pm
ironhanglider wrote:I'm so tough I removed a freewheel from a tandem hub!
Cameron
Did it take 2 of you ? :D
10speedsemiracer
Postby 10speedsemiracer » Sat May 05, 2018 6:56 pm
Cameron
Hasta la Vista...baby
Last edited by 10speedsemiracer on Sun May 06, 2018 11:05 pm, edited 1 time in total.
Mmm, SunTour
ironhanglider
Postby ironhanglider » Sun May 06, 2018 10:20 pm
Cameron
I could have certainly used a hand. I thought I was going to rip the vice from the workbench. I put enough torque into it to lift one of the bench legs 15cm off the floor before the freewheel finally broke free.
What was worse, was that after all that there was a crack in the hub so I couldn't use it anyway.
Cameron.
Users browsing this forum: jusforfun, MattyK
