M9100 XTR
M9100 XTR
Postby Duck! » Thu May 03, 2018 10:29 pm
I'm jumping the gun a little bit here, because nothing has formally been announced yet, but several clues have been appearing recently that the release of the next-generation XTR premium MTB groupset is imminent. Firstly, the timing is right in Shimano's production run schedule. Secondly, over the past couple of weeks Shimano have been publishing social media "Throwback Thursday" posts featuring past generations of XTR - a sure sign that Something New is on the way. Finally, a close dig through the Techdocs product specifications gives some insights into what's coming, without yet revealing any actual new product details.
So, the subtle indications are that it will be built around a 12-sp. system. Not at all surprising given SRAM brought it in with Eagle a couple of years ago. Whether it retains multi-chainring capability like 11-sp. does (current M9000 is the only groupset anywhere that offers a massive 3x11 option; M8000 XT & M7000 SLX offer 2x11, SRAM is dedicated 1x), or is strictly 1x like SRAM is not yet known. It's not inconceivable - but probably unlikely - that like SLX's 1/2x11 & 3x10 mix that M9100 could offer a mix of 11- & 12-sp. options. It also appears that like SRAM, the cassettes will go down to a 10T top gear, which will dictate a change in freewheel body design, because 11T is the smallest that can fit on the standard hub design. Again, whether Shimano swallow their ego and adopt the SRAM XD freewheel body design or do their own thing remains to be seen, although the latter would not surprise me..... (They could also pull out the old Capreo 9T-compatible hub design uprated to XTR-tech, which would give then a top gear edge over Eagle....) What happens at the other end of the cassette is also unknown, but expect similar to Eagle's 50T big sprocket.
I'll fill the details in as they're known, but an official announcement could even be within the next few days - again we're getting into the window where in recent years Shimano have been announcing New Stuff.
MichaelB
Re: M9100 XTR
Postby MichaelB » Fri May 04, 2018 11:07 am
Duck! wrote:
..... It also appears that like SRAM, the cassettes will go down to a 10T top gear, which will dictate a change in freewheel body design, because 11T is the smallest that can fit on the standard hub design. Again, whether Shimano swallow their ego and adopt the SRAM XD freewheel body design or do their own thing remains to be seen, although the latter would not surprise me..... (They could also pull out the old Capreo 9T-compatible hub design uprated to XTR-tech, which would give then a top gear edge over Eagle....) What happens at the other end of the cassette is also unknown, but expect similar to Eagle's 50T big sprocket.
Cheers for this info. Will be interesting to see what comes out.
The thing that really interests me is the freehub design. I can see Shimano doing their own thing, but you'd have to question what would be the point ? That just introduces yet another design standard into the market for what is really a low volume product.
Not that I care about cassettes with more than 34 teeth, but for me, it will be interesting to see what they do re 1x, and how that might translate to the road ....
Standing by to standby :o
Thoglette
Re: M9100 XTR
Postby Thoglette » Fri May 04, 2018 11:43 am
Duck! wrote:(They could also pull out the old Capreo 9T-compatible hub design uprated to XTR-tech
(link added)
Funny, I was thinking the same thing: a bloody obvious move.
Presuming that it's not too expensive to produce, which I believe is what killed the much missed megarange freewheel
MichaelB
Re: M9100 XTR
Postby MichaelB » Fri May 04, 2018 4:23 pm
Well, based on that, it's just a matter of different final sprockets, and a shorter freehub. Only a few extra sprockets to produce, and of that, they would already have the tooling, especially since they have already made it.
Cool. A nice simple solution that means any teeth above 13 are standard, and it's only the 13 tooth and below that are unique to this hub.
Interesting !!!
And it's 135mm spacing already. Even better :D
Re: M9100 XTR
Postby Duck! » Fri May 11, 2018 8:00 pm
My friendly Shimano rep advised me today that May 28th is the date the covers come off this year's New Stuff, and wasn't forthcoming about any further details beyond what little I've already uncovered.
He did however concede that over the last decade or so Shimano HQ have focused heavily on the road side of things, especially R9100 Dura-Ace, and realised they've dropped the ball a little on the MTB side and lost a lot of ground to SRAM, and that although it brought Di2 to the dirt, M9000 wasn't the pinnacle of development that XTR should be, rather like 7900 Dura-Ace was. So although on the face of it Shimano still appear to be playing catch-up, the hint is that we could maybe see something a little bit radical.
mikgit
Re: M9100 XTR
Postby mikgit » Wed May 23, 2018 2:53 pm
i hear its 1x12 (m9100-12) only and 2x11 (m9100-11) still and maybe 3x11 (probably not)
Look 675 Pro Team, Cervelo R3, GT Xizang, GT Zaskar, Scott Spark 710, Yeti ARC, DiamondBack Apex
Re: M9100 XTR
Postby Duck! » Wed May 23, 2018 6:51 pm
We'll find out soon.... apparently the wraps come off on May 25th, which is only a couple of days away. Due to time zone considerations & ensuring no region sees the release before they hit Friday, I suspect we'll see the official news late on Friday night.
I've seen a leaked post from Brazil wich shows a four-pot brake caliper, which I suspect will be the "Trail" option, while the "Race" version will likely continue as a two-pot.
mikgit
Re: M9100 XTR
Postby mikgit » Wed May 23, 2018 9:05 pm
yeah I saw a leaked pic of the specs of the cassette (doesn't make it true, but looks likely)
Re: M9100 XTR
Postby Duck! » Wed May 23, 2018 10:03 pm
If you've seen the same thing I have, which appears to be a screenshot from the Shimano techdocs specifications page, that first appeared on April Fools' Day, so it may or may not be an accurate representation. The thing on it that catches my eye which I find weird is the supposed use of the same chain for both 11- and 12-sp. options.
As I mentioned in the OP, although there are some clues showing in the spec charts, nothing at all specifically relating to M9100 components has been published there.
Re: M9100 XTR
Postby Duck! » Wed May 23, 2018 10:23 pm
This one popped up on Rotorburn t'other day....
mikgit
Re: M9100 XTR
Postby mikgit » Wed May 23, 2018 10:41 pm
Duck! wrote:If you've seen the same thing I have, which appears to be a screenshot from the Shimano techdocs specifications page, that first appeared on April Fools' Day, so it may or may not be an accurate representation. The thing on it that catches my eye which I find weird is the supposed use of the same chain for both 11- and 12-sp. options.
haha could be.
Re: M9100 XTR
Postby Duck! » Fri May 25, 2018 12:48 pm
Officially the wraps come off overnight Aus time (around 2am Eastern I'm told). Had a visit from my friendly Shimano rep this morning, practically bouncing off the walls with excitement, so I got a bit of a sneak peek. :-) Probably the biggest surprise, which the leaks didn't pick up on, is th 2x12 option! :shock:
I haven't yet had a really close look at the rear hub, but it does appear at least superficially to be an evolution of the Capreo hub design; it is quite different to SRAM's XD body. DT Swiss so far are the only manufacturer licensed to produce the hub at this stage, but othrs will probably follow.
MichaelB
Re: M9100 XTR
Postby MichaelB » Fri May 25, 2018 1:51 pm
One of the leaked pis I saw (can't see yours above) was a 4 pot caliper with a smooth polished body - aside from the 12 sp stuff, any changes with the brakes ?
Oh, and are you able to confirm the piston sizes in the 8020 caliper ? I've seen conflicting reports that they are different to the Saint/Zee (but still use the same pad) - is this correct ?
Re: M9100 XTR
Postby Duck! » Fri May 25, 2018 7:12 pm
You probably saw the same pic as I posted above. Slightly to my surprise, there is no 2-pot brake; the 4-pot is the only one on offer. Pads are apparently "similar" to Saint/Zee/XT 4-pot, but the cooling fins appear different. whether ot not they're compatible with those calipers I do not know yet. At this stage I have no details regarding the brakes beyond this, other than that there is yet another iteration of I-Spec integrated shifter mounting.
To the best of my detective work, M820 Saint, M640 Zee and M8020 XT 4-Pot are exactly the same calipers, just printed differently, and the Zee version comes shipped from the factory with non-finned pads.
10speedsemiracer
Re: M9100 XTR
Postby 10speedsemiracer » Fri May 25, 2018 7:54 pm
I always enjoy reading these.
Tks Duck. ..
Mmm, SunTour
Re: M9100 XTR
Postby trailgumby » Fri May 25, 2018 8:01 pm
The 2x12 approach is probably targeting the Euro market which I hear is largely 1x sceptic.
