Swapping BOA for shoe laces
uad782
Postby uad782 » Mon Jul 09, 2018 8:15 am
Hi Everyone,
I recently bought a second hand pair of shoes that fit nicely. However they are very difficult to get into as the boa system doesn’t open very far. I have a high arch.
Has anyone ever swapped a boa for laces or maybe lengthened the boa.
mikgit
Re: Swapping BOA for shoe laces
Postby mikgit » Thu Jul 12, 2018 6:01 pm
don't know if this would help, but Salamon (at least used to) sell replacement laces for their trail shoes that the laces are like boa's but they end in a pull strap/toggle thing. You cut them to fit. Might be able to make them fit.
Look 675 Pro Team, Cervelo R3, GT Xizang, GT Zaskar, Scott Spark 710, Yeti ARC, DiamondBack Apex
uad782
Postby uad782 » Thu Jul 12, 2018 9:48 pm
Thanks!
jackthelad
Postby jackthelad » Fri Jul 13, 2018 12:16 am
Boa loaces, only work with Boa laces
they are an integrated system , with proprietary parts ...
just have to get used to the fit is all
SantaCruz HighTower LT
SantaCruz Blur XC Carbon
Kona Kula Supreme
Ribble Rd Bike
mikgit
Postby mikgit » Fri Jul 13, 2018 1:20 am
jackthelad wrote:Boa loaces, only work with Boa laces
Guy wants to ditch the Boa off the shoe and just thread something through the holes and tie it, could use string or metal wire or Cinderellla's hair, would matter if there is no Boa on the shoe, just a bunch of holes.
eeksll
Postby eeksll » Fri Jul 13, 2018 6:47 pm
i have seen boa repair kits e.g these on fleabay
find the distributor of your shoe brand and see if they have a repair kit? guessing its going to be very expensive
or see if you can take the boa system cap off and maybe you could replace the wire for some other longer wire
uad782
Postby uad782 » Fri Jul 13, 2018 7:18 pm
Thanks everyone,
I managed to get the boa cap off and then I undid the wire. The shoe is still a bit too tight :(
I am amazed at how short the boa cable was, unless it was modified by the previous owner.
CKinnard
Postby CKinnard » Fri Jul 13, 2018 8:16 pm
previous owner could have cut the wire.
you could just go buy narrow gauge fishing line, and cut a longer piece.
It works.
Users browsing this forum: Cosh, Thoglette
