Convert 135mm Thru Axle to QR?
fpstroy
Postby fpstroy » Sun Aug 12, 2018 9:03 pm
I ordered the below wheels believing they were QR.
Fulcrum Racing Sport 700c DB 6-Bolt Wheelset 2016
http://www.chainreactioncycles.com/au/e ... prod171493
Turns out the rear was thru axle and only the front was QR doh!
Anyone know where I can get a conversion kit to make the rear 135mm QR?
Found nuke proof make a kit but its out of stock
http://www.chainreactioncycles.com/au/e ... -prod34779
10speedsemiracer
Re: Convert 135mm Thru Axle to QR?
Postby 10speedsemiracer » Mon Aug 13, 2018 12:17 am
Wheels Mfg ? On mbl so no linkages sorry.
Mmm, SunTour
Postby RonK » Mon Aug 13, 2018 12:12 pm
fpstroy wrote:I ordered the below wheels believing they were QR.
I did exactly the reverse with a set of Fulcrum Red Power wheels recently - I wanted thru axles both ends. It was simply a matter of changing the end caps on the front hub.
fpstroy
Postby fpstroy » Mon Aug 13, 2018 2:03 pm
RonK wrote:I did exactly the reverse with a set of Fulcrum Red Power wheels recently - I wanted thru axles both ends. It was simply a matter of changing the end caps on the front hub.
Hi RenK this gives me some hope, any idea where I can buy the end caps?
The wheels didn't come with any additional ones.
Postby RonK » Mon Aug 13, 2018 10:39 pm
Trying to remember. I will have the QR end caps somewhere. I will try to find them. But I'm not sure if they will fit your hub.
fpstroy
Postby fpstroy » Tue Aug 14, 2018 12:39 pm
RonK wrote:Trying to remember. I will have the QR end caps somewhere. I will try to find them. But I'm not sure if they will fit your hub.
Thanks for the offer RonK let us know how you go.
I went to the local bike shop apparently the end caps are on back order from distributor. ~2 weeks before I can order them.. Ill see if I can get some quicker online. Sounds like they will be about $50 + freight from LBS.
I got the part number KITFCRAQR..
Users browsing this forum: septuagenarian
