Where to buy cheap short crankset
cyclingnolycra
Re: Where to buy cheap short crankset
Postby cyclingnolycra » Sat Sep 01, 2018 11:45 am
I'd love to try shorter cranks too (i'm 175cm, using 172.5mm cranks) but it's just too expensive to go and try by buying... and I have no problems at the moment. People like to point out that Quintana is short and uses similar cranks but he normally is out of the saddle for big efforts where I think the crank length doesn't matter as much.
I suspect for anyone shorter the crank length starts to matter even more (as in, their default cranks will be way too long for them)
vosadrian
Postby vosadrian » Sun Sep 02, 2018 10:12 am
Thanks again for the info!
Yeah, the short cranks is an experiment. I doubt it could make anything worse, and it may make things better, so just a couple hundred dollars and some time to fiddle to lose really.
I have also just fitted a SMP (blaster) saddle. I am going to experiment with nose down angle on that to twist the pelvis forward.
foo on patrol
Postby foo on patrol » Sun Sep 02, 2018 5:03 pm
Shorter = spin easier. :idea:
Foo
Goal 6000km
vosadrian
Postby vosadrian » Wed Sep 12, 2018 10:55 am
Just a quickie....
If I want to run hollowtech cranks on my Specialized Venge 2012 which I believe is OSBB, I think I need a conversion bottom bracket. I note that Specialized appears to use Praxis Works BB when using Hollowtech cranks. Also they seem to be a quality product. Is that the best option for me or should I consider something else?
Cheers!
Users browsing this forum: lewie15
