26x1.95 tyre help
Kerosene-Tin
26x1.95 tyre help
Postby Kerosene-Tin » Mon Oct 08, 2018 12:35 pm
So, I seem to have a thing with buying bikes that have odd less common tyre size
My recumbent 2.3 metre long bus of a thing has 2 rear 26x1.95 tyres, only ones driven though. Not sure if theres enough space for a bigger wheel
Im trying to get some great hard wearing tyres with liner built in. The bike itself is an engineer built monster. Longest and largest bike ive ever owned
All I can find are kenda brand cheapys
Currently fitted with lizard brand tyres front and back, the logo matches lizard skin products yet I cant find these exact ones online - leading me to believe theyve been on for some years
Shes an older machine thats been sitting idle for some years, parking brake removed along with the motor, before I hit the road given its sheer size, any help on finding some good tyres would be great
Also has a front 20x1.90 but that seems more common
Re: 26x1.95 tyre help
Postby Duck! » Mon Oct 08, 2018 2:10 pm
1.95" is just one of many widths available for bog-standard 26" wheels. Wider than 1.75" is really the domain of MTB, so road oriented tyres will be uncommon, but you should be able to get road cimmute/touring type tyres between 1.5 & 1.75" easily enough. You'll likely need new tubes to fit in the smaller tyres.
10speedsemiracer
Postby 10speedsemiracer » Mon Oct 08, 2018 3:17 pm
If you wanted to stay with 1.95, I've fitted these Vittoria Evolution tyres to someone's hardtail as part of a commuter-ization/refurbishment process...
https://www.vittoria.com/ap/evolution-city-and-beyond.html
rolled well, relatively inexpensive at the time, and seem quite tough (they've been on there for over a year..no flats)
Mmm, SunTour
MattyK
Postby MattyK » Mon Oct 08, 2018 5:23 pm
If there's a good gap around and above the tyres, you should have no problem upsizing a few mm.
Plenty of options:
https://www.bikebug.com/tyres-tubes-urb ... 1_696.html
Kerosene-Tin
Postby Kerosene-Tin » Tue Oct 09, 2018 5:08 am
Thanks for the replies :)
Some very good choices there, some with built in liners so ill give them a go, after running solid tyres on my wheelchair for over 25 years the prospect of using pneumatic tires is a bit daunting, hopefully some of these choices will reduce flats along with that blue goop stuff in the tubes, im not incapable of changing a tyre easily. I just hate too :)
Thanks for the help
Postby singlespeedscott » Tue Oct 09, 2018 5:32 am
Given the size of your trike I’m guessing puncture resistance is high on your list. If so I’d being looking at the 26” touring tyres from Schwalbe
Kerosene-Tin
Postby Kerosene-Tin » Tue Oct 09, 2018 6:58 am
Size is definately a factor, as are spare chains and a hub drive if they fail, amazing bike thats got me back being active.. But nothing short of a flatbed is going to get it home if it cant
Still, it only cost me 215 plus 260 shipping. Im way ahead
Ill be buying a good set of tyres plus a spare set folded
