Efficiency gain with cleats / shoes?
Postby Downhill » Thu Oct 07, 2010 1:28 am
Can anyone tell me what the actual gain in efficiency or power is when using cleats, in quantitative terms? Assuming a level road, good conditions and proper pedaling technique, is it 2%? 5%? more? What's the average increase in speed or reduction in energy expenditure? I've trawled the net but couldn't find any specific references.
2010 Oppy C6
Re: Efficiency gain with cleats / shoes?
Postby Chaderotti » Thu Oct 07, 2010 1:53 am
Power output is much higher, maybe upwards of 40% compared to soft runners and platform pedals.
Mistress = Pinarello Opera, Ultegra SL
Mistress #2 = Drag Bluebird
- drubie
Postby drubie » Thu Oct 07, 2010 8:21 am
In practice, the security of knowing your foot isn't going to slip off the pedal is good for some extra mental power i.e you have the confidence to push harder.
- sogood
Postby sogood » Thu Oct 07, 2010 9:06 am
You'd be on dope if you achieved 40% gain in power output out of your legs. Efficiency gain per OP is what can change here. Even then, 40% is out of this world.Chaderotti wrote:Power output is much higher, maybe upwards of 40% compared to soft runners and platform pedals.
Postby waynohh » Thu Oct 07, 2010 9:25 am
- jules21
Postby jules21 » Thu Oct 07, 2010 9:42 am
- m@
Postby m@ » Thu Oct 07, 2010 9:53 am
- ghettro
Postby ghettro » Thu Oct 07, 2010 11:18 am
- queequeg
Postby queequeg » Thu Oct 07, 2010 11:30 am
When it is wet, my feet don't slip off the pedals and then rip all the skin off my shins (Ouch!). That's why I went to cleats and some decent shoes. It also means, as others have stated, that I can use my legs through the whole pedal stroke and not just for the "push" bit, so it smooths out the ride.Downhill wrote:Hi,
I am not even going to try and quantify it with a percentage as it would be fairly negligible.
- Nate
Postby Nate » Thu Oct 07, 2010 11:44 am
The quesiton needs better wording i think...Downhill wrote:Hi,
A cleat instead of a pedal will make zero difference in efficiency, as they all transfer the same amount of force to the crank.
However what you might be getting at is will you be quicker if you starting using cleats rather than pedals...
the answer is undoubetly yes, cleats enable you to not only push down (like pedals), but pull up, push forward & back etc...
So you can apply more power.
If you switch to cleats there'll be minimum benefit until you build up your muscles, but when you do its a huge difference.
When i use shoes on my pedals without cleats its laughable... the motion is so jerky due to the lack of power throughout the pedals revolution.
Hope that answers the q?
As for a % gain - its going to vary between person so much... for short peak periods maybe as high as 40% more power output?
- sogood
Postby sogood » Thu Oct 07, 2010 11:59 am
My understanding of efficiency is one that relates to energy/power loss. So the fixed connection b/n shoes and crank will improve efficiency. Whereas power is in the biological system (human body), that won't change. No?Nate wrote:A cleat instead of a pedal will make zero difference in efficiency, as they all transfer the same amount of force to the crank.
- JV911
- brades68
Postby brades68 » Thu Oct 07, 2010 1:10 pm
Gold!ghettro wrote:14.56% give or take 0.012% usually.
n + 1 = Felt TK3 (track - woohoo)
- Chops
Postby Chops » Thu Oct 07, 2010 1:24 pm
I'd say it has more to do with power delivery.Nate wrote:The quesiton needs better wording i think...Downhill wrote:Hi,
It's impossible to generate anymore power than what you already have in your legs, but it isn't in terms in terms of delivery.
I liken it to having a 1000hp engine, with crap tyres. You can generate any more power you want, but it isn't going to make a hell of a lot of difference unless you can get it down.
For me, they made a big difference on hills, under accleration and in sprints. Not so much at cruising speed.
Postby maicoboy » Thu Oct 07, 2010 7:09 pm
- mikesbytes
Postby mikesbytes » Thu Oct 07, 2010 8:19 pm
- foo on patrol
Postby foo on patrol » Thu Oct 07, 2010 8:53 pm
Goal 6000km
Postby Robdog » Thu Oct 07, 2010 9:16 pm
201x S-Works Shiv
2009 Avanti Cadent Team
- trailgumby
Postby trailgumby » Thu Oct 07, 2010 10:09 pm
+1, I just can't do it. Riding without being clipped in just feels wrong at so many levels. Even on the spin bikes at the gym.Robdog wrote:Riding without cleats just feels weird after I've used them exclusively for 9 months
Postby Downhill » Thu Oct 07, 2010 11:06 pm
The average torque applied during one full revolution would be higher if more muscles are brought into play. It would also be higher if any muscle set can deliver power throughout more of the pedal cycle. So the real question is, what would be the percentage increase in average torque, per pedal cycle, for an experienced cyclist, when attached to the pedals as opposed to using hard soled shoes?
Or if you prefer - how minutes would NOT being clipped on add to a 2 hour ride?
2010 Oppy C6
Postby Downhill » Thu Oct 07, 2010 11:09 pm
If your average speed was 20 km hr then that would be 15%.foo on patrol wrote:It was worth 3kmh on my mountain bike!
2010 Oppy C6
Postby Downhill » Thu Oct 07, 2010 11:39 pm
Your body might still use the same total energy to cover a set distance, but if you can use more muscles then you can burn that energy faster. That means more power. Just like the difference between a 4 cylinder and a V8. Theoretically, more power = greater speed = better times. The question is how much better?jules21 wrote:the gain is minor for endurance riding. cleats allow you to use more muscles by applying pedal force throughout the entire pedal stroke. this month's BV mag has a good diagram of which muscles you use during the pedal stroke. at the end of the day, your body still uses roughly the same total energy - but cleats just mean different muscle groups are sharing the load, which is a gain.
2010 Oppy C6
- casual_cyclist
Postby casual_cyclist » Fri Oct 08, 2010 8:33 am
Haha! Not true. I gottem. I don't use em. I have lovely shimano SPD shoes which I can't use I had to go back to clips and strapsmikesbytes wrote:Once you have cleats/shoes you never go back
As someone who rode for years with sneakers, clips and straps and recently tried cleats/shoes, I can make some observations:
1) for me, SPD shoes were more comfortable - I get cramps on long rides with sneakers (soft sole)
2) I did notice a small efficiency gain but nothing like 40%, without any measurements I would estimate less than 5% - however, I already pedal circles with my clips and straps so others may see a bigger efficiency gain
3) overall I liked the shoes better than sneakers. They have a number of advantages including an efficiency gain but I also found them more comfortable and didn't cramp on long rides (a disadvantage is hot spots which other members have reported)
Unfortunately, I am knock kneed and out of the box these shoes forced my knees together and resulted in severe shin splints after 3 rides (I could barely walk). I need my shoes set up by a specialist who can rectify biomechanical problems with wedges etc. My feet need to be at a different angle for me to pedal without doing damage.
So, having used both, for my long rides 50km-300km+ I would prefer to use cleats/shoes. For my daily commute of 9km I wouldn't bother. I like them but not that much.
Postby thejester » Fri Oct 08, 2010 8:43 am
When you first start using cleats you notice the difference when you get tired. You are locked in, no moving for comfort sake. VERY quickly, just about everyone that uses cleats comes to love them, see a difference in averages. Your pedaling stroke becomes more consistent, you start to tweak the way you pedal (stroking back as well as pushing down)and more efficiency appears.
Sure this efficiency can be found using flat pedals, but you need to think about it to achieve it. Cleats seem to make it happen more naturally and I think that is because you are locked in, you think more about it initially. You realise you can draw the pedal back, which does work the muscles differently.
I often, particularly after a burst of power pedaling ( I would like to say sprinting,but this would be insulting to the "God of thunder") I consciously adjust the way I way I pedal to ease muscle fatigue.
I love my cleats... as do millions of other fitness cyclists.
Depending on the MTB riding I am doing I will swap cleats for flat pedals, but when I'm on the road its "cleats all the way baby!!!"
Giant CRX4 - Black Ghost
Shogun Trailbreaker3
I need a dualie
Postby thejester » Fri Oct 08, 2010 8:51 am
It took me some adjusting to get my cleats correctly positioned. I too suffer knee problems, have done since I was 12, and my legs bow out. But now my cleats are adjusted properly I have no knee pain at all when I ride, in fact it has helped correct the problem I have had since I was 12.
I need a dualie
- Cycling Brands
- Cannondale
- Garmin
- Giant
- Shimano
- Trek
- All times are UTC+11:00
