Oxalic Acid- will it damage my paint?
magilla0_2
Re: Oxalic Acid- will it damage my paint?
Postby magilla0_2 » Sat Jun 21, 2014 9:53 pm
When I was an apprentice painter we used Oxalic acid to remove water stains from timber prior to varnishing.
I still remember the burning eyes, running nose and !! BAN ME NOW FOR SWEARING !! dry reaching cough that used to come from sanding the product off again.
Be careful eh ?
Imwit
Postby Imwit » Sat Jun 21, 2014 10:03 pm
Thanks for doing that Philip. The red guard looks great.
Next question.. Anyone prepared to test it on old style transfers? :D
Postby Clydesdale Scot » Sun Jun 22, 2014 8:20 am
magilla0_2 wrote:When I was an apprentice painter we used Oxalic acid to remove water stains from timber prior to varnishing.
I still remember the burning eyes, running nose and superfantastic dry reaching cough that used to come from sanding the product off again.
Be careful eh ?
days before Safety Data Sheets?
I bought a tin in the 1990s to use to bleach timber after chemically stripping it, prior to staining and finishing. It is in a powdered form and concentrated.
I use the same precautions as I would with any chemicals (Roundup etc).
However in doing this demonstration last week, I had no skin contact with the acid, either in the concentrated dry form or after dilution in the water at ANY time.
It was only after each piece had been soaked and rinsed in fresh water were they handled.
Postby Clydesdale Scot » Mon Jun 30, 2014 7:27 pm
I used the same procedure on some chrome rims for one of the staff at the LBS
the state of the rims
Imagechromerimsbeforelarge_zps86055b63 by philip.knight, on Flickr
into the makeshift bath
Imagerimssoaking_zps82aef33f by philip.knight, on Flickr
and after the soak (24 hours) and lightly rubbed with an old green kitchen scourer
ImageChromerimsafterlarge_zpsb1a0c4b2 by philip.knight, on Flickr
the fluid under the last image is the excess Penetrene I used inside the rim walls to disperse the water and deter rusting.
The bath was then used for a 24 hour soak of the two Bullock mudguards (one partially done in the test earlier in the thread). These have now been removed from the bath, rinsed and drying.
Last edited by Clydesdale Scot on Tue Dec 31, 2019 8:53 am, edited 1 time in total.
tooslowtorace
Postby tooslowtorace » Wed Jul 02, 2014 12:11 pm
Where does one get oxalic acid?
HappyHumber
Postby HappyHumber » Wed Jul 02, 2014 12:54 pm
tooslowtorace wrote:Where does one get oxalic acid?
Hardware stores. Sometimes primarily labelled "Wood bleach". Sold in the paint/surface prep section.
Postby Clydesdale Scot » Wed Jul 02, 2014 6:18 pm
In Bunnings and Masters as "Diggers Rust and Stain Cleaner".
But the concentration they use is way in excess of that which I use!
They are looking for instant effects, with bike parts it is usual to go slowly.
by going slower, it is easier to deal, and you can check on the progress and decide when it is time for a bush down and another soak; or when it is done.
And it is good for steel, not aluminium.
geoff_tewierik
Postby geoff_tewierik » Wed Jul 02, 2014 7:45 pm
Worth using on this type of rusted eyelet situation? Or will it pooch the anodised rims?
Postby Clydesdale Scot » Wed Jul 02, 2014 8:02 pm
the conventional wisdom is to keep oxalic acid away from aluminium and anodised finishes. eg this thread
simon.young
Postby simon.young » Fri Jul 04, 2014 7:37 pm
Thanks for posting this thread and keeping us upto date.... I'm getting ready to dunk a 70s kid dragster to do some testing....
But I was also wondering about rust converter http://www.supercheapauto.com.au/online ... 5818#Cross on paint chips that have rusted. eg on the seat stay in this pic. Will it damage the paint or discolour it?
I guess I really need to test . Maybe on that old dragster.... Has anyone tried something like this? any tips?
commando
Postby commando » Sat Jul 05, 2014 10:34 pm
Don't look for it in the paint section at Bunnings, the Diggers Rust and Stain Cleaner is in the building area with all the concrete and stone prep/cleaning supplies. The 2kg container for $27 should last you a looooooooong while.
Postby find_bruce » Sun Jul 06, 2014 10:29 am
The supercheap rust converter you linked to is phosphoric acid, just like most of the rust converters. Diggers Rust & Stain Cleaner is oxalic acid. I am not about to enter into the religious debates about the relative merits.
Postby Clydesdale Scot » Sun Jul 06, 2014 12:23 pm
from what I have seen through searches, the action on rust is similar: oxalic acid/phosphoric acid/acetic acid
for those few spots on the frame, I would treat the spots rather than a full bath.
Imwit
Postby Imwit » Wed Sep 24, 2014 10:51 pm
Tried a little test.
Had some deck cleaner.
67 ml oxalic acid per 1L cleaner.
Used 250 ml to get 17 ml oxalic acid ( nearly Philip's 20 ml - 4 teaspoons).
Real rusty roadster seat stays in 5L water for 20 hours. (Bottom half immersed)
No real reaction seen.
Before
After
So at about $3 per 250 ml do I bother trying again with more cleaner or just get some crystals?
Postby Clydesdale Scot » Thu Sep 25, 2014 7:46 am
I suggest a longer soak, a lower concentration is a slower process
I have previously soaked some items for a week. Check once a day, brush off any of the yellow deposits.
yugyug
Postby yugyug » Thu Sep 25, 2014 9:14 am
I'm a beginner with this kind if stuff, but I've been using the phosphoric rust converter to treat spot rust in paint chips, and I have not noticed any effect on the paint. I just dab it in lightly and let it set in, wipe off excess.
simon.young
Postby simon.young » Fri Sep 26, 2014 2:07 pm
Imwit wrote:Tried a little test.
Before
After
I got this at Mitre 10 store in Hobart $27 i think. Used 50g with 3.5 litres of water
In 24hrs it looked like this
Gave it a scrub:
Maybe I little heavy handed with the amount, but I need to find out reaction times. It was quick. But that was a free rusty 70s dragster from the curb.
Next I'll try the frame...
For parts that I care about, I will use a weaker concentration, and let it sit for a few days.
I assume the black marks are where the rust ate through the chrome plating?
Imwit
Postby Imwit » Fri Oct 03, 2014 10:05 pm
Trial no 2 was more successful.
Still using the deck cleaner but taking Philip's advise, used a greater concentration (approx 25 ml OA for 5 L water) and over 7 days. Only the bottom part immersed.
Before..
And after..
Wiped off every day before and after work.
Most of the cleaning seemed to be done after a few days but interestingly didn't see the yellow spots appearing until the last few days. They were still coming up but only in a couple of places.
So anyway, the deck cleaner works but is more expensive (and may take longer)
Postby Clydesdale Scot » Sat Oct 04, 2014 7:06 am
That is an impressive result. There is a surprising amount of paint left hidden behind the rust.
The process gives the best results and no mechanical damage to the surface.
I cringe when I see ebay sellers say the rust can be easily removed with steel wool. It might, but you risk taking the surface coating with the action.
LG
Postby LG » Sat Oct 04, 2014 2:55 pm
simon.young wrote:Maybe I little heavy handed with the amount, but I need to find out reaction times. It was quick. But that was a free rusty 70s dragster from the curb.
The black marks are generally where the chrome was so badly corroded small patches have either flaked off or the rust just bubbled up through the chrome leaving a small gap. Sadly following a rust treatment these patches of bare metal will corrode again unless treated. I've found sometimes these patches of steel turn black, other times they seem to simply look like steel.
My trick for small patches on an otherwise clean frame is to soak a piece of rag in the oxalic mix then place it against the frame and hold in place with glad wrap.
LG = Low Gear
gazo
Postby gazo » Mon Oct 27, 2014 7:44 am
I have been using Citric Acid with great success - it's cheap, you can buy 75g in the baking section at Woolies; mix 25g with a few inches of water in the bottom of a bucket, leave your bits to soak overnight, and voila. Just wipe off and rinse with water.
Best of all, it's non-toxic. You can put your hands in it, don't need to worry about splashes or rubber gloves or kids and animals. I don't know why anyone would touch Oxalic Acid.
Postby Clydesdale Scot » Mon Oct 27, 2014 8:11 am
gazo wrote:.. leave your bits to soak overnight, and voila.
I wouldn't be leaving my bits in it. :shock:
And if you follow this safety advice you should also wear protective gloves, protective clothing, and keep kids and animals well away.
Just like I do with Oxalic acid. And I don't touch oxalic acid. I use appropriate equipment.
gazo
Postby gazo » Mon Oct 27, 2014 11:49 am
Clydesdale Scot wrote: And if you follow this safety advice you should also wear protective gloves, protective clothing, and keep kids and animals well away.
Um, that safety advice is for Oxalic acid.
Another good thing about Citric Acid - you can sprinkle it on your fish or chicken roast. :P
Postby Clydesdale Scot » Mon Oct 27, 2014 5:50 pm
as you like having things served up on a plate Citric Acid
but given your concerns about oxalic acid, you had better keep spinach, cabbage, broccoli, brussel sprouts, parsley off the plate
The reason I started the thread was to document the use of weak oxalic acid to remove rust and establish if there is any detrimental impact on old paint.
There is ample material on the internet as to other forms of rust removal. Oxalic acid is commonly used and so the quantities to be used are well documented.
I have had a large container of oxalic acid in powdered form for over 20 years, and it will last me my lifetime (and no, I don't plan on consuming any to hasten my early demise). Ingredients used in food preparation are kept in the kitchen; cleaners and oils etc for working with and the cleaning of bikes are kept in the garage. I am just old fashioned there. My ultrasonic cleaner, vacuum pump, dremel and air compressor are also not used for food preparation either but for bikes.
The only blurred line is found with my dirty fingerprints on the bottle of liquid detergent kept in the kitchen. This is irrefutable evidence that I use it to clean my hands after working on my bikes. And to ally any concerns, I do not use the dishwasher detergent, nor do I consume the dishwasher detergent, or sprinkle it anywhere but into the dishwasher dispenser. I use my ultrasonic cleaner for cleaning bike parts, I do not use the dishwasher.
My wax chain lube is used for lubing chains. I am very unadventurous.
I have once used a BBQ to dry a leather saddle. That use is a matter of public record.
My apparent intolerance with people wasting my time is not listed as an acute hazard/symptom of exposure to oxalic acid.
Postby munga » Mon Oct 27, 2014 7:23 pm
spactose intolerant.
Users browsing this forum: WyvernRH
