Newbie checking in!
Newbie checking in!
Postby peterngit » Sun Oct 13, 2013 9:46 am
Currently stuck with a $79 bike =) but yeh will invest in a better one if i enjoy ridding.
I've been reading around an the optimal pedal rate is around 90 rpm but i was wondering what is the name of the tool? i can only seem to find a odometer to measure the overall speed
EDIT: i found the device name while this post was waiting for approval =)
- g-boaf
Re: Newbie checking in!
Postby g-boaf » Sun Oct 13, 2013 5:27 pm
90rpm is a good cadence, even 100rpm is good too. I used to mash the pedals - but I've tried to avoid doing that. It's much easier if you ride with a fast cadence (the RPM of pedal spinning) - and eventually you find that even if you are doing 30km/h, you can quite easily build up more speed quickly. It also puts less strain on your knees and other muscles too, from my own experiences.
I had a few injuries of recent - one of the Adductor Magnus, and the other was a knee issue. I got back into it too quickly and didn't help the recovery. Low cadence hurt them more than fast spinning, especially the knee. I'm recovered now - but will be aware of it.
Postby peterngit » Sun Oct 13, 2013 6:09 pm
awww injury sucks no matter what you are doing, hope it doesn't happen again =)
Im planning to buy a buy a better bike from here to Christmas, would you guys know any decent bike stores to look out for? around Liverpool, casual, Preston are would be great! pretty much looking forward to a end of year sale (no idea when). I am probably aiming for a budget of around 400-800 dollars.
Oooo lol and my first ride i tracked only 2.8k and i was tired =p
- nomadicsoul
Postby nomadicsoul » Sun Oct 13, 2013 9:19 pm
- g-boaf
Postby g-boaf » Sun Oct 13, 2013 10:14 pm
Giant Sydney are very good (down the end of Clarence Street near Town Hall) but they are very far away from you. The staff there are very cool.
- Tornado
Postby Tornado » Mon Oct 14, 2013 12:30 am
2015 Specialized Tarmac
2012 Avanti Giro3
Postby peterngit » Mon Oct 14, 2013 8:20 am
Do bikes go on sales? and if so any idea when?
oh yeh and im more looking for the drop down handle bars with blifters =) would be cool if i didn't have to mod the bike
Found two bikes
http://www.this link is broken/Cell-2013-Blade-Road-Bike" onclick="window.open(this.href);return false;
http://www.trekbikes.com/au/en/bikes/ro ... series/1_2" onclick="window.open(this.href);return false;
good or bad idea? hmm cell 2013 is currently on sale, only 59.5cm frame left how sure if that is a good fit im 175cm tall =) (are cell bikes always on sale or should i take it now before all stocks are gone)
- g-boaf
Postby g-boaf » Mon Oct 14, 2013 2:42 pm
You need something around a 54cm - go to a bike store and try them out.
Postby peterngit » Mon Oct 14, 2013 8:45 pm
- g-boaf
Postby g-boaf » Mon Oct 14, 2013 9:37 pm
Or otherwise, buy at TdF time.
- wombatK
Postby wombatK » Mon Oct 14, 2013 11:04 pm
There's more to good fit than just checking your height and in-seam (as used in Cell's chart). The Competitive Cyclist Fit Calculator is an excellent tool which you can use to "self-measure".peterngit wrote:Yep! checked the cell's height chart so 54cm is what i would need im looking forward to the cell blade but the new models will be coming in next month, only that is that is comes with a toe cage not clipless =)
It will give you a range of top-tube and seat-tube length recommendations, which you need to check against
the bike frame specs.
Unfortunately, Cells' website doesn't publish the critical frame dimensions for the cheaper bikes - you might have to go into the shop to check it, or try ringing to ask them.
And also, with Cells chart, what they mean by "59 cm" frame can be different on other brand bikes - there is no agreed standard amongst bicycle manufacturers about
how they actually make that particular measurement (e.g. from center of crank v's from top of crank etc.,.). And the "59 cm" doesn't give you any information about the
top tube length.
Most of Cell's (and other brands) or road-bikes don't include decent pedals in the price - it's a trick to keep the sticker price down. You'll probably want to replace the cheap pedals
on the Blade with something better quality before too long.
Postby peterngit » Tue Oct 15, 2013 9:10 pm
Postby peterngit » Wed Oct 16, 2013 4:09 pm
http://www.reidcycles.com.au/bicycles/r ... l4dqFCkxvg" onclick="window.open(this.href);return false; cost only $20 more. weight still in 9.xxkg? i also looks hotter =)) 27 gears same (blade is 9)
actually http://www.this link is broken/Cell-2013-S ... gory=12632" onclick="window.open(this.href);return false; looks better and a level up from blade =)
Postby peterngit » Thu Oct 17, 2013 9:29 pm
http://www.this link is broken/Cell-2013-T ... gory=12632" onclick="window.open(this.href);return false; - Cell 2013 Team
about 400g litter fitting with 105 group set under 300 more then the swift, farrk is it worth the jump guys?
- im_no_pro
Postby im_no_pro » Thu Oct 17, 2013 10:45 pm
Sent from my GT-I9210T using Tapatalk
- g-boaf
Postby g-boaf » Fri Oct 18, 2013 10:24 am
(can I get him to buy it??)
Postby peterngit » Fri Oct 18, 2013 11:48 am
EDIT: next little jump is carbon frame, about 800 grams lighter = under 9kg O.O keeping my hands of that =))
hmm does bikes usually comes with holes to mount water bottles?
- im_no_pro
Postby im_no_pro » Fri Oct 18, 2013 12:23 pm
- wombatK
Postby wombatK » Fri Oct 18, 2013 8:40 pm
Your speakin to someone who bought a Cell Blade to start with over 5 years ago, and kinda regretted not spendingpeterngit wrote:Weird it doesn't let me edit any more, i have no idea why the more i look the more i want to jump up a notch in the bike
a few extra bucks for the Team - mainly due to better wheels and smoother shifting on 105 levers.
However, I'm not so keen to recommend the current Team model. From the photos, it looks like the cables exit from
the STI levers under the handlebar wrap, and no cable adjuster has been provided inline with the cables. Yep, it
looks cool. But...
While there's an adjuster at the RD, there's none for the Front (FD).
But my experience is that the FD cable is the one that cops most strain and tends to need tension adjustment
It's a fiddly adjustment to get just right - you really need to operate the levers under full loads to check if its
right. So the best way to do it is on the bike, using a conveniently located cable adjuster.
It would be a show stopper for me if there wasn't a barrel adjuster at the lever, or an inline adjuster somewhere
in reach.
Curiously, Cells' cheaper Tiagra model appears to have the barrel adjusters (and cables not wrapped). So I'd stop
the "upgrade" process at that model. Or look fro an 105 based bike that has more sensible adjusters provided.
Postby peterngit » Sat Oct 19, 2013 9:58 am
- RonK
Postby RonK » Sat Oct 19, 2013 10:35 am
Not a great strategy - the experience of riding a $79 bike is more likely to put you off cycling for life.peterngit wrote:Currently stuck with a $79 bike =) but yeh will invest in a better one if i enjoy ridding.
Postby Zcootz » Sat Oct 19, 2013 11:12 am
+1 To that. My first bike was a $100 special that lasted a week. Don't forget to consider a second hand bike, take a bike savvy friend along and you can get better bang for your $$$$ that way. Just picked up a sweet second hand Kona Sutra for touring for under a third of new price. About 1000km later the only money I need to spend is $30 for some gel pads and new bar tape. It even shines like a new bikeRonK wrote:Not a great strategy - the experience of riding a $79 bike is more likely to put you off cycling for life.peterngit wrote:Currently stuck with a $79 bike =) but yeh will invest in a better one if i enjoy ridding.
- wombatK
Postby wombatK » Sat Oct 19, 2013 12:22 pm
Doesn't look like it from the photos, which aren't very detailed. Photos on website can be different to what you get.peterngit wrote:For the FD barrel adjuster isn't that the one in front of the headset above the wheel?
You ought to go look in the shop, or ask Cell. Trouble is, it's presently showing as out of stock on website, so might
be unobtainable anyway.
Postby peterngit » Sat Oct 19, 2013 2:20 pm
Postby Homo Suburbiensis » Sat Oct 19, 2013 4:52 pm
I only registered to reply to the above post because it is wrong.wombatK wrote:Your speakin to someone who bought a Cell Blade to start with over 5 years ago, and kinda regretted not spendingpeterngit wrote:Weird it doesn't let me edit any more, i have no idea why the more i look the more i want to jump up a notch in the bike
looks cool. But...
in reach.
And that is why people who have only ridden high end bikes with fancy Di2 or internal cable routing should not comment on lower end bikes. Haha
If you didn't know, the barrel adjuster is located on the down tube, right behind the head tube/fork. They are the two black things you see there.
Most other big brands do this as well.
For example:
Specialised
http://www.specialized.com/au/en-au/bik ... llez-sport" onclick="window.open(this.href);return false;
Trek
http://www.trekbikes.com/au/en/bikes/ro ... 2_compact/#" onclick="window.open(this.href);return false;
Merida
http://www.merida.com.au/2013-bikes/roa ... e-903.html" onclick="window.open(this.href);return false;
and a google search comes up with this discussion http://www.cyclingweekly.cc/forum/tech- ... sters-6501" onclick="window.open(this.href);return false; . Apparently they are good to use while racing.
BTW the some 2014 Cell bikes road bikes are on display at the bike and lifestyle show. They look awesome!
