Quick Road Bike conversion
Postby GJM » Mon Nov 16, 2015 11:25 am
Apologies if this has been done to death.
Unexpectedly, I have a TT race to do in a few weeks time. It's a 15km TT.
I'm set up for mountain (road) climbing, not for TT-ing.
I have a good spare road bike though.
I don't want to buy a whole new TT bike. I want to convert my existing spare road bike.
What should I do? What tri bars should I buy?
And are TT bars simply clip ons (to existing bar), or is there also the option of replacing the entire handlebar with a purpose-built all in one?
I'm new to all this.
Re: Quick Road Bike conversion
Postby dalai47 » Mon Nov 16, 2015 4:41 pm
Get some clip on aerobars (integrated time trial bars means new brake levers plus gear shifters and cables plus expensive bars), making sure your bar extensions within the necessary UCI regulations and practice riding the aerobars at speed. If you haven't ridden aerobars before I would suggest riding the road bike and I.A.B's for this year and set up properly for next year.
If you still want to try aerobars, extension bend will depend on preference (straight or ski) and if you have room to slam your stem will determine which model, As some aerobars sit high above the tops of your bars which means you will be still sitting high whilst on the extensions...
- Derny Driver
Postby Derny Driver » Mon Nov 16, 2015 5:43 pm
My son is a very good TTer and he uses his road bike for them. He goes so good on the roady that i have no intention of buying him a TT bike even though he races every weekend.
Its very simple to set your road bike up, and very effective.
3 things to do.
1. Put on some clip on aerobars. Get the ones which are almost straight, and clip them close to your stem, centre of bars. I got mine for free by asking at my LBS, he rummaged through some drawers of parts and gave me a pair. Disregard the hype and dont pay big dollars, they are just 2 pieces of aluminium with pads on them.
2. Take the spacers from under your handlebars out and put them on top, ie lower the bars on the stem if you can.
3. Slide your seat fully forward on the rails and raise the seatpost about 5mm.
Have a few practise rides in the new forward position before the race.
Hers is my son on the roady, you can see its a very good position. He had fastest time in this TT.
Postby GJM » Mon Nov 16, 2015 8:14 pm
Thanks DD and D47. Much appreciated.
Postby dalai47 » Mon Nov 16, 2015 8:52 pm
But it takes time to get used to producing power on the aerobars, so definitely look at get a set and use them. Just probably a bit late for this TT...
- nickobec
Postby nickobec » Tue Nov 17, 2015 2:37 pm
as the race is only a "few" weeks away, do as DD & D47 suggested, get a pair of clip ons, lower the bars if you can, move your seat forward and up (the rule of thumb is 1cm forward 5mm up) and practice as much as possible.
From my expereince learning to ride TTs and TT bikes. Assuming a flat there and back course, if you can't get in at least 4 or 5 practice sessions (ie flat out 15km efforts) in, you are unlikely to be any faster on a bike with aerobars than your regular road bike. After 8 to 10 efforts, you will be faster.
If it is twisty and/or climbing and descending course, it will take a lot longer. I have race one course a dozen times in the past couple of years and I am as fast on my road bike as my TT bike, as I ride harder on descent (ie don't panic and keep pedaling at 60kph+ on descending a rough road surface), faster through the hotdog corners and it is no different on the climb.So if this race is on a similar circuit, my advice use your road bike
- KGB
Postby KGB » Tue Nov 17, 2015 4:12 pm
Postby GJM » Tue Nov 17, 2015 5:29 pm
I'm going to trial clip-ons but if it looks as though it's just not going to work this time around, and I'm better off just riding my normal road bike without clip-ons ... is there any value in still lowering the handlebars / bringing the seat forward / raising the seat ... or is that something you'd only do when clip-on bars are in place?
- Derny Driver
Postby Derny Driver » Tue Nov 17, 2015 5:55 pm
- Derny Driver
Postby Derny Driver » Tue Nov 17, 2015 6:10 pm
Reminds me of a little anecdote ...my dad was mechanic for 11 years of the Commonwealth Bank Classic in the 90's, he looked after some incredible gods of international cycling. At the end of each tour he would come home and give me something special that the riders gave him out of appreciation for his help. Over the years I got a helmet belonging to Jan Ulrich, shoes off Jeremy Hunt, yellow jersey off Cesary Zamana (tour winner), points jersey off Declan Lonergan, sprint jersey off Raimondas Rumsas etcGJM wrote:Fantastic advice, thank you. All the above is extremely helpful.
Anyway I remember Rumsas winning about 5 stages one year and then it came to the final TT in Canberra. The Polish team only had one beat up bike each so my dad spotted a girl riding around on her bike which had some spinachi bars on it about an hour before the TT started. He offered her a Polish jersey in exchange for a loan of the spinachi bars. She agreed. Dad put the bars on, dropped the stem, raised the seat and brought it forward...and Rumsas won the TT.
- KGB
Postby KGB » Wed Nov 18, 2015 12:08 pm
- nickobec
Postby nickobec » Wed Nov 18, 2015 12:52 pm
I would not even drop the bars, I would try to bend the elbows as much as possible, to get my torso lower and better aero. And practice that as much as possible before the race.
Postby GJM » Thu Nov 19, 2015 4:37 pm
At this stage I'd be surprised if I didn't race on my standard road bike.
Basically, you guys are right
- nickobec
Postby nickobec » Thu Nov 19, 2015 8:21 pm
YepGJM wrote:Basically, you guys are right
Actually having same issue after 6 months away from TT bike. I am putting put out 20 watts more and keeping my heart rate a couple of beats lower on my road bike for the same speed as my TT bike.
Postby you cannot be sirrus » Thu Dec 03, 2015 9:03 am
Postby you cannot be sirrus » Fri Dec 11, 2015 8:21 pm
