Some information here (wheelpro.co.uk)find_bruce wrote:If you are making your own tensiometer why wouldn't you copy the jobst brandt design?
Wheel building
- Thoglette
Re: Wheel building
Postby Thoglette » Sat Jun 04, 2016 11:40 am
Re: Wheel building
Postby Lurkin » Sat Jun 04, 2016 9:16 pm
I've seen others on the internet which don't actually attach to the truing stand, rather have magnetic bases etc to stand alone with. Just wondering if anyones used one of these cheaper equivalents rather than the Park tool version.
- QuangVuong
Re: Wheel building
Postby QuangVuong » Sun Jun 05, 2016 12:44 am
Its only been a thought. Actual planning starts in a couple weeks time when I've some time.Thoglette wrote:Some information here (wheelpro.co.uk)find_bruce wrote:If you are making your own tensiometer why wouldn't you copy the jobst brandt design?
I have a late 1930s truing stand. It works as a basic truing stand. But I will also be modifying it to take dual dial gauges for lateral and axial truing.Lurkin wrote:Not as a tensiometer, but as an indicator for where its out on the truing stand. Like these: http://www.parktool.com/product/dial-in ... nds-ts-2di
Looking at the Park gauges, all I see are 2 standard dial gauges with a ±0 scale, and bearings on the tips, along with the mounting system. I certainly wouldn't pay the $200 for it. I'll see how I go with my home made version.
Re: Wheel building
Postby Lurkin » Sun Jun 05, 2016 4:36 pm
Re: Wheel building
Postby ianganderton » Wed Jun 08, 2016 4:10 pm
http://m.pinkbike.com/u/theminsta/blog/ ... -rims.html
Basically an asymmetric rim means you have even spoke tension which you will all know means a stronger and more reliable
So I've always used hope hubs (Mtb) and their flanges are different diameters to allow the use of same length spokes but spoke tension is normal as in its asymmetric.
What are your thoughts folks?
I haven't built one yet so haven't answered a lot of the questions I have. First one would be do the spoke calculators cope with the offset?
I need to get my head round the hub options
- Duck!
Re: Wheel building
Postby Duck! » Wed Jun 08, 2016 11:05 pm
E.g. if the spoke bed in the rim is 4mm off to the left (arbitrary figure for example only), if you increase the right centre-to-flange distance and decrease the left centre-to-flange distance by 4mm, you'll get the same triangulation points for the calculator to work from.
- find_bruce
- Moderator
Re: Wheel building
Postby find_bruce » Thu Jun 09, 2016 6:45 am
Re: Wheel building
Postby hedgehog » Wed Jun 15, 2016 9:38 pm
will increase spoke angle =stronger wheel, rear wheal.
increased flange diameter on left side front disk
brake wheel,increase spoke angle =stronger wheel.
in my opinion.
- barefoot
Re: Wheel building
Postby barefoot » Thu Jun 30, 2016 9:02 pm
Rim is offset to the disc side at the front, and to the cassette side on the rear.
That allows equal length, near-equal tension spokes. 32 spokes 3x makes them rather bombproof wheels (in the grand scheme of $200 1750g disc wheelsets ).
I broke a rear spoke once when I hit a quarter brick (or something similar) in a race... didn't notice until a few people mentioned that the wheel had a bit of a wobble next group ride. Other than that... they see a heap of tarmac (16k km on that bike now... although I've used a different rear wheel for some of it), more than a little bit of dirt road, and the odd bit of singletrack if it happens to be in the way when I'm out for a "road" ride
Another benefit of symmetrical spoke length is that you just need to buy one bundle of spokes per wheel, which is handy when some of the cheaper spoke vendors sell them in bundles of 32.
tim
- coffeeandwine
Re: Wheel building
Postby coffeeandwine » Thu Jul 28, 2016 12:45 pm
Hubs: White Industries T11 (20/24)
Rims: HED Belgium C2 clincher
Spokes: Sapim CX-Ray (radial, 2x)
I realise this a fairly popular build combination, and there will be people out there with experience on which spoke lengths work.
My calculations:
280mm (Front, radial)
282mm (DS, 2x)
287.1mm (NDS, 2x) Should I run with 286 or 288?
I would appreciate any advice or shared experience.
Merida 903 from the LBS; Diesel engine
Re: Wheel building
Postby geoff_tewierik » Thu Jul 28, 2016 1:04 pm
I get from here https://leonard.io/edd/coffeeandwine wrote:Building my next set of wheels up for my niece and just after some confirmation on spoke length ( I have made a few mistakes in the past, so wanted to get it right first time). Components:
My calculations:
282mm (DS, 2x)
Front: 279.5 - go with 280
Rear DS: 282.7 - go with 282
Rear NDS: 288.2 - go with 288
Here http://www.prowheelbuilder.com/spokelengthcalculator gives similar numbers.
- Duck!
Re: Wheel building
Postby Duck! » Thu Jul 28, 2016 1:08 pm
- biker jk
Re: Wheel building
Postby biker jk » Thu Jul 28, 2016 1:10 pm
Yes I just used the leonard calculator to get the same result. A bit concerning is that the non-drive side spoke tension will be just 40% of the drive side. So even at 130kgf for the drive side spokes that would leave the non-drive side at just 52 kgf.geoff_tewierik wrote:I get from here https://leonard.io/edd/coffeeandwine wrote:Building my next set of wheels up for my niece and just after some confirmation on spoke length ( I have made a few mistakes in the past, so wanted to get it right first time). Components:
My calculations:
282mm (DS, 2x)
Re: Wheel building
Postby human909 » Thu Jul 28, 2016 5:59 pm
That is to be expected due to dishing.biker jk wrote:Yes I just used the leonard calculator to get the same result. A bit concerning is that the non-drive side spoke tension will be just 40% of the drive side. So even at 130kgf for the drive side spokes that would leave the non-drive side at just 52 kgf.
{Rear wheel on RIGHT}
http://cyclingtips.com/2015/08/the-scie ... e-tension/
- biker jk
Re: Wheel building
Postby biker jk » Thu Jul 28, 2016 6:06 pm
I know about dishing, so thanks for pointing out the obvious. My point is that the hub chosen has a geometry which produces a quite low non-drive to drive side tension ratio of 40%. Of course, the move to 11-speed hubs did see a sharp fall in this ratio but some hubs do better than others. Offset rims also help in this regard.human909 wrote:That is to be expected due to dishing.biker jk wrote:Yes I just used the leonard calculator to get the same result. A bit concerning is that the non-drive side spoke tension will be just 40% of the drive side. So even at 130kgf for the drive side spokes that would leave the non-drive side at just 52 kgf.
- coffeeandwine
Re: Wheel building
Postby coffeeandwine » Thu Jul 28, 2016 10:17 pm
- biker jk
Re: Wheel building
Postby biker jk » Sat Jan 06, 2018 2:29 pm
After a bit of research I choose the AForce Al33 rim. It's toroidal with brake track width of 24.2mm, maximum width of 26.2mm and internal width of 19.6mm. It's been tested as aero as a Zipp 303 across the most commonly experienced yaw angles.
A little cost cutting with the hubs given I had a strict budget, so I went with BHS hubs. Spokes are Sapim CX-Ray and nipples are brass Polyax.
The wheelset built up nicely thanks to the excellent rims. Front was built 20 hole radial, with spoke tension just under 100kgf. Rear was built 24 hole triplet with 16 drive side spokes laced 3 x and 8 non-drive side spokes laced radially. This provided double the spoke tension on the non-drive side compared to the usual 2 x lacing. Drive side spoke tension averaged just over 115kgf and non-drive side 100kgf. All spokes were within 10% of average tension. Total weight is 1530 grams without rim tape.
I'm running a 23mm tyre on the front which is measuring around 24.5mm on the rim, in order to preserve the aero properties of the wheel. The rear is finished but awaiting rim tape and a tyre.
- MichaelB
Re: Wheel building
Postby MichaelB » Mon Jan 08, 2018 4:28 pm
Looking at building a new set (prob around the 40-50mm depth carbon rims) and c/lock disc hub (Novatech due to budget) and interested in trying to understand a bit more re this type of build vs the std 3x on both sides.
- queequeg
Re: Wheel building
Postby queequeg » Mon Jan 08, 2018 5:03 pm
You are not going to be able to do triplet lacing for a disc wheel, as the disc side of the wheel can't have radial lacing.MichaelB wrote:Can you elaborate a bit more re the 'triplet' lacing and suitability for disc rear wheels ?
- biker jk
Re: Wheel building
Postby biker jk » Mon Jan 08, 2018 5:04 pm
Triplet lacing and disc brakes aren't compatible. Moreover, you don't have the dishing issue on a rear disc brake wheel.MichaelB wrote:Can you elaborate a bit more re the 'triplet' lacing and suitability for disc rear wheels ?
- MichaelB
Re: Wheel building
Postby Patt0 » Tue Jan 09, 2018 9:38 am
- biker jk
Re: Wheel building
Postby biker jk » Tue Jan 09, 2018 9:59 am
Yes the rim was drilled for 16:8 lacing. The spoke holes are not centred so you have two drive side spoke holes on the right side of the rim followed by one non-drive side spoke hole on the left side of the rim.Patt0 wrote:Was the rim drilled for 16:8 lacing? Could a 32H hub be used for 16:8? Or is it better to get a 16:8 hub?
I guess you could use a 32 hole hub for 16:8 lacing. My only concern would be the non-drive side flange to centre distance. Some argue you need it to be larger to achieve the same lateral stiffness with fewer non-drive side spokes in a 16:8 lacing.
- queequeg
Re: Wheel building
Postby queequeg » Tue Jan 09, 2018 11:31 am
I was always under the impression that you should fill every hole on the hub flange, as skipping holes means you are potentially putting undue stress on a hub that was not designed for that usage. Also, keep in mind that not all hubs support radial lacing, so you would have the added issue of the radial lacing on the side where you skip holes putting even higher stress on the hub flange, and it may well have a catastrophic failure when you least expect it.Patt0 wrote:Was the rim drilled for 16:8 lacing? Could a 32H hub be used for 16:8? Or is it better to get a 16:8 hub?
Bottom line, always buy a hub that is appropriate for the lacing pattern you are going to use.
Re: Wheel building
Postby Patt0 » Tue Jan 09, 2018 12:17 pm
Thanks. Sound advice.queequeg wrote:I was always under the impression that you should fill every hole on the hub flange, as skipping holes means you are potentially putting undue stress on a hub that was not designed for that usage. Also, keep in mind that not all hubs support radial lacing, so you would have the added issue of the radial lacing on the side where you skip holes putting even higher stress on the hub flange, and it may well have a catastrophic failure when you least expect it.Patt0 wrote:Was the rim drilled for 16:8 lacing? Could a 32H hub be used for 16:8? Or is it better to get a 16:8 hub?
