eBay prices on the rise, good time to sell old junk?
- WyvernRH
Re: eBay prices on the rise, good time to sell old junk?
Postby WyvernRH » Thu May 02, 2013 8:27 pm
Well Oria made some damn good tubing.... but... this isn't it... it is the lowest grade they made, not even cro-mo. I can't think offhand of an equivalent modern Reynolds grade down that far, 500 possibly?
I am very surprised that Pinarello made anything out of that tubing, I always thought it was a top company like De Rosa?
- singlespeedscott
Postby singlespeedscott » Thu May 02, 2013 8:42 pm
- Rob74
Postby Rob74 » Thu May 02, 2013 8:47 pm
Rob
- singlespeedscott
Postby singlespeedscott » Fri May 03, 2013 12:29 am
Nice.sunho wrote:lennie
I'm about $350 dollars away from buying this...........
if i miss out within the next 6 days then i hope someone here gets it....
- frailer5
Postby frailer5 » Fri May 03, 2013 8:57 am
Postby LG » Fri May 03, 2013 11:07 am
Very nice bike there.
Postby feelthewheel » Fri May 03, 2013 5:24 pm
Methinks we'll see this listed again (I will bet due to a non-payer). The final price seems a bit unrealistic, even for such a nice bicycle.LG wrote:This seemed to go quite well http://www.ebay.com.au/itm/vintage-Navy ... true&rt=nc" onclick="window.open(this.href);return false;
- grantw
Postby grantw » Fri May 03, 2013 6:03 pm
Yes I do. Happily pay more for it too.pentlandexile wrote: By the way does anyone else wish Bicycle Quarterly was printed in colour?
Postby xerlex » Fri May 03, 2013 9:11 pm
http://www.ebay.com.au/itm/Classic-shim ... 43bb53f4a7" onclick="window.open(this.href);return false;
I didn't really need it so I only put $25 on it.
- munga
Postby munga » Fri May 03, 2013 9:31 pm
- LugNut
Postby LugNut » Sun May 05, 2013 11:09 pm
Optimistic starting price, but check out that derailleur I read on Disraeli that Suntour invented the three jockey wheel derailleur to solve the issue of chain slap on bicycles with a wide gear range, and according to the author, it worked beautifully. It suffered at the hands of Suntour's marketing team ( ), and eventually they were forced to succumb to market pressures and replace it with the less effective long cage derailleur.
A nice bike with a full set of touring braze ons. you don't come across a lot of Nishikis that arn't rebranded as Repcos.
There is also a small lowish end Bridgestone mountain bike on gumtree NSW, well worth the $29 asking price.
Bridgestone MB-5
- grantw
Postby grantw » Mon May 06, 2013 9:30 am
- Bob_TAS
Postby Bob_TAS » Mon May 06, 2013 9:52 am
That isn't you, is it LG?
Interesting use of Gumtree
I want to find this bike now!
Postby Bobbybobson » Mon May 06, 2013 7:29 pm
Oh my size!!!!Dan wrote:Big, reasonably priced De Rosa
Postby LG » Mon May 06, 2013 7:43 pm
Well, I'm forever the optimist . I don't think it's overly optimistic though, the 8 speed 105 & 600 gear is good quality stuff, similarly the better Giant frames are highly underrated. Time will tell. It does say negotiable, and the degree to which it's negotiable is ... I guess... up for negotiation.
- Bob_TAS
Postby Bob_TAS » Mon May 06, 2013 8:10 pm
It's a fair price mate, I'm just too much of a bargain hunter
Postby wqlava1 » Mon May 06, 2013 8:42 pm
And while forum user LG is being mentioned regarding steel Giants, a Giant Kronos (probably just a Kronos GS), , interesting for a couple of things. First, you would never carry stuff for long with a top rear rack mount like that. But secondly, I have recently put together a 62cm 1997 Kronos that I got from forum user Rustguard 3 years back. It takes a 27.2mm seatpost, so must be reasonable Cr Mo. They only have top tubes on the shorter end of the spectrum (62x57, 59x56) so fit me fine. It was nice and light so I got another Kronos in the next size down, 59cm, the other day. What's different is that it has a tight fitting Tiogo steel 27.0mm seatpost. It came with original spec RSX STI, RSX triple 46/36/26 cranks and RSX brakes so looked like it was not the lower spec Kronos GS model like the one advertised - but it looks like Giant played around with spec a bit. On BikePedia.com the 94 to 96 Kronos models were made of heavier but still good tube with 26.4 and 26.8 seat posts, and the 98 model changed to aluminium. It's interesting that the RSX A410 front derailleur as supplied on a couple of years of the Giant Kronos is recommended by various of the French revival sites associated with Velo Orange as being good for STI shifting with a smaller large chainring in the mid-forties teeth and a big range down to a small third ring or even for wide range 2 rings.
- munga
Postby munga » Tue May 07, 2013 7:53 am
wqlava1 wrote:Another optimist...over 2 or 3x what I'd expect for my similar bike, which is not for sale. Although it's got a Superbe Pro RD that isn't very well on display because the gears are cross-chained on the small circles, and has a beautiful simple fork shape. Anyone know what the fork is called?
fork crown looks to be a cinelli SCA
http://velobase.com/ViewFramePart.aspx? ... dd8a5e94d4" onclick="window.open(this.href);return false;
Postby wqlava1 » Tue May 07, 2013 11:28 am
I looked them up and there was comment from Jobst Brandt about having had that type of fork fail, as well as a long thread on Velocipede Salon. Failures seem to occur either because it is hard to get the solder into the crack between the internal lug and the fork leg tube, or because the lug finishes square and creates stress at that point. Note that the Cinelli SCA lug that you pointed to on velobase.com is cut away at the sides and does not finish square, but that some others that have copied the style do. I still like the look of sloping shouldered fork crowns, but I'll happily keep to the externally lugged one on my Velosmith for now.munga wrote:wqlava1 wrote:Another optimist...over 2 or 3x what I'd expect for my similar bike, which is not for sale. Although it's got a Superbe Pro RD that isn't very well on display because the gears are cross-chained on the small circles, and has a beautiful simple fork shape. Anyone know what the fork is called?
- munga
Postby jools » Tue May 07, 2013 2:00 pm
No-names
and something a bit older...
Super Elliott Frame
- QuangVuong
Postby QuangVuong » Tue May 07, 2013 6:45 pm
http://www.ebay.com.au/itm/GIANT-CFR-Ca ... 4173142d6a" onclick="window.open(this.href);return false;
- LugNut
Postby LugNut » Wed May 08, 2013 1:03 am
Full Ultegra group set and $8 worth of scrap aluminum, you beauty!QuangVuong wrote:Giant CFR with 6500 stuff
Just winding you up...
