Speed wobbles
Speed wobbles
Postby Al Kidder » Tue Apr 16, 2024 12:47 pm
The bike is good, and faster than the old one with a carbon frame and alloy wheels, but I'm finding it scary on descents.
It seems to be verging on wheel wobbles above 50 and I'm touching the brakes when I get to 60.
The whole front end has a light feeling to it.
Does that have something to do with wider tyres, 28mm, instead of the 23mm I've been on since Adam was a boy?
I tried moving the saddle forward to put more weight on the front with no effect, so what should I do?
Is it possible that the wheel is slightly out of balance? Also, I notice that the rim is assymetric in cross section. Why?
Re: Speed wobbles
Postby Andy01 » Tue Apr 16, 2024 6:15 pm
The last tyres I replaced (Schwalbe Almotion) were shocking until I just blasted them with my garage compressor (I tried a couple of times with the track pump first) to maximum rated pressure - then they popped into the bead like a firecracker going off.
- DavidS
Re: Speed wobbles
Postby DavidS » Tue Apr 16, 2024 8:28 pm
DS
Re: Speed wobbles
Postby blizzard » Tue Apr 16, 2024 10:06 pm
Rims are sometimes made asymmetrical to even out spoke tension between the drive and non drive side of the wheel.
- Thoglette
Re: Speed wobbles
Postby Thoglette » Tue Apr 16, 2024 10:37 pm
The standard list
1. Check tyre pressures (and seating)
This is the #1 cause if “emergent” wobbles, along with badly loaded luggage
2. Check skewers are tight & wheels are straight
3. Check for play in wheel bearings (grab the rim - can you wiggle it?
4. Check for play in the headset (usually accompanied by brake judder)
5. Check your weight distribution/grip/frame stiffness
The last is where we start to get into maths that’s almost indistinguishable from magic: a magic combination of flex and weight and energy just wants to shimmy. (Have you seen “The World’s Fastest Indian?)
There’s a few good articles out there on how this happens. I’ll see what’s in my bookmarks..,,
Ah, start here and then read the Jobst Brandt too
- Dodgy-Knee
Re: Speed wobbles
Postby Dodgy-Knee » Wed Apr 17, 2024 7:05 am
Re: Speed wobbles
Postby Mr Purple » Wed Apr 17, 2024 9:30 am
This is my bet as well.Andy01 wrote: ↑Tue Apr 16, 2024 6:15 pmJust a complete guess - has the tyre been mounted concentrically to the rim ?
When I upgraded my old bike I was suffering shocking speed wobbles down Cootha at about 60km/hr. Turned out the front tyre hadn't beaded concentrically to the rim.
Very easy to check for as well - just check the bead is even all the way around.
- foo on patrol
Re: Speed wobbles
Postby foo on patrol » Thu Apr 18, 2024 2:17 am
Foo
Goal 6000km
- antigee
- Location: just off the Yarra Trail but not lurking in the bushes
Re: Speed wobbles
Postby antigee » Thu Apr 18, 2024 4:55 pm
Most tyres seem to have a thin line of rubber just back from the rim edge and all the way around the circumference...when mounting tyres I check that this maintains a constant distance from/on/just under the wheel rim all the way round and is same both sidesMr Purple wrote: ↑Wed Apr 17, 2024 9:30 amThis is my bet as well.Andy01 wrote: ↑Tue Apr 16, 2024 6:15 pmJust a complete guess - has the tyre been mounted concentrically to the rim ?
I did once have a tyre (reputable mnfr can't remember who) that had a twist and lumpy bit in the construction and rode horribly...took it back and the mechanic gave me a box of them to look thru saying something along the lines of "throw the faulty ones in a pile...we get lots"
Re: Speed wobbles
Postby CmdrBiggles » Thu Apr 18, 2024 7:11 pm
Re: Speed wobbles
Postby Al Kidder » Fri Apr 26, 2024 4:24 pm
Let me tell you, when you do go, that must be among the best ways. Absolutely zero pain or symptoms leading up to it. All I knew was that I woke up on the floor 1/2 an hour later after falling off my chair with no warning feeling dizzy and sick, so if I hadn't woken it would have been an easy death.
Still, I managed to have fun in the hospital next day when I deliberately got the heart rate monitor to go off by moving from sitting with a pulse of 40-45 to lying down and dropping it to 37 so all the nice nurses came rushing into the room as the alarm went nuts.
The cardiologists expected that stenting would be in order, but the angiogram found no major blockage, so I reckon I've got nothing more than a pulled muscle which should recover over time.
And I'm not going to be as dumb (I hope) as the guy who came and joined the ward on Sunday evening who was fat, already had stents, yet had gone in for the bike leg of the Wollongong triathlon despite feeling sick before it started. He had another stent on Tuesday.
- foo on patrol
Re: Speed wobbles
Postby foo on patrol » Fri Apr 26, 2024 7:56 pm
Foo
Goal 6000km
- g-boaf
Re: Speed wobbles
Postby blizzard » Sat Apr 27, 2024 9:38 am
