Living with a velomobile
Re: Living with a velomobile
Postby Vicfarmer3 » Sat Sep 18, 2021 2:05 pm
vicfarmer3
Postby opik_bidin » Thu Sep 23, 2021 10:36 pm
ask here:Vicfarmer3 wrote: ↑Sat Sep 18, 2021 2:05 pmAny one have a velomobile for sale? Possibly a Mango.
vicfarmer3
https://www.facebook.com/groups/OzHPV
https://www.facebook.com/groups/1868550136802056
Postby Gwheel21 » Wed Oct 20, 2021 11:53 pm
I apologise if it has been asked somewhere before.
Postby Rhubarb » Thu Oct 21, 2021 7:54 am
Gwheel21 wrote: ↑Wed Oct 20, 2021 11:53 pmHi guys, just a quick question or few. Is it any harder to get a rotovelo up a hill than a normal bike? Does the body position hinder output much? Is it worthwhile trying to use one almost daily for the normal grind sorta stuff or are they good but cumbersome in daily practice?
Hills - once you're into a steady climb then a velo just becomes a heavy bike. My DF is relatively light for a velo but still weighs 24kg. A RV would weigh 30-ish I'm guessing. Velo gearing is generally much wider ranging then road bikes for this exact reason. I currently run 61/33 front rings mated to a 11-40T cassette. Rolling hills are another thing all together, since a velo holds its speed on the downhill and carries its momentum up the hill so you are considerably faster. See this video here as an example (Rolling hills (AT) 2mins. Flats v long hills (AT) 7 min mark):
Here's another video that shows where velos are faster and where road bikes are faster over a 100km ride:
As a further comparison, I rode the Brisbane to Gold Coast 100km ride in 2017 and was the first finisher by several minutes despite the police escort continually slowing me down. I then rode home again, making 230km for the day. I did the same the next year but ride organisers told me I was too fast and so not to pass the lead group. I did a lot of coasting and riding the brakes down hills to finish with the lead 3 riders. I don't say this to brag, but just to point out the speed advantage of the velo over such a route. I am actually a relatively weak rider and 53 years old. Its only the speed and comfort advantages of the velo that make this possible.
I've been using my velomobile as a daily commuter for 9 years. I think its super practical, with weather protection, speed, safety and luggage. But you do need somewhere secure to park it etc. I often stop by the shops on my way home and pick up some groceries or wine or whatever, and have no problem leaving it unattended just outside the shops for short periods but I wouldn't leave it all day somewhere.
Ultimately its an expensive bike thats only a few minutes faster on most commutes, but its the fun factor for me too.
You need the right route for a velo too though. If your commute was full of stop start, lane splitting, jumping gutters, hairpins turns etc, then a road bike will be faster. But anything on longer open paths or roads, the velo is king
Postby zebee » Thu Oct 21, 2021 7:35 pm
What they are good for is looong rides and work on the flats and rolling hills.
A velo is a heavy bike so will be slower up hills than a roadbike. And probably slower up hills than an equal weight diamond frame. IF speed up hills is what you want don't get one. If your daily grind is a lot of climbing and tight corners and darting between cars don't get one.
If your commute is reasonable local roads with more flat than climb then do get one!
- TrikeTragic
Postby TrikeTragic » Sun Oct 24, 2021 2:20 pm
I concur with Rhubard and Zeebee. I ride a trike (a TW Bents / Flying Furniture 20-26) that weighs about 14 kg "bare" and about 18 kg with panier containing spare tubes, bike tools, wet weather gear etc. The Rotovelo is 32 kg unless you go the carbon fibre version....To put that in context, I'm 105-ish kg.....I've has the trike since 2006 and love it.Gwheel21 wrote: ↑Wed Oct 20, 2021 11:53 pmHi guys, just a quick question or few. Is it any harder to get a rotovelo up a hill than a normal bike? Does the body position hinder output much? Is it worthwhile trying to use one almost daily for the normal grind sorta stuff or are they good but cumbersome in daily practice?
Your questions:
Hills: Both Rhubard & Zeebee nail it: If you have momentum, on shorter hills you carry your speed due to the extra mass, but an upright would probably beat you to the top. On longer hills, it's not so much harder as just slower. You find a gear where you can spin comfortably, and enjoy the view. On the decent, you get quite a bit more speed than anyone on an upright, perhaps with the exception of a serious roadie tucked right down. I've done several Around the Bay rides and GVBRs, I find I'm around the same average pace as riders on decent hybrids.
Power: Mainly because you can't stand and drive into the pedals, you're pushing from the fixed position of the seat against your torso, you can't develop the same power as you can on an upright. I'd guess that difference reduces as pedal rpm increases. I've ridden the same routes on my trike and an upright, interestingly my average heart rate is about 10 or 12 bpm lower on the trike, and my time spent in the upper 25 % of heart rate is lower also. Maybe pumping the blood around is a reclining body is less work for the heart than one that's near vertical.
Ride environment: I live in more outer suburbia Melbourne and have easy access to quieter roads than the heavier traffic of inner suburbs. I have taken the trike into heavier traffic, as Zeebee commented, you cannot easily (or perhaps safely) split lanes or roll up the left hand side of stopped city traffic as you can on bikes. I have seen a Rotovelo in traffic near the CBD, he was having no trouble matching vehicle traffic speed on some undulating road, so clearly some felt OK with it!
Cumbersome? Yep, heavier and bigger footprint than a bike. Don't handle stairs too well. On the other hand, free standing! A Rotovelo might be a tight fit through standard doorways. If you've got access to "end of trip" storage or parking at work, you just have to be able to manage security, and assess the entry / exit points etc.
BentCyclist
Postby John Lewis » Wed Jan 19, 2022 12:54 am
Drymer the manufacturer is going out of business.
I've been waiting for the store that closed due Covid to open as I needed a few replacement parts parts. Will be fun trying to find elsewhere I suspect.
Anyway here is a link to the news.
https://www.recumbent.news/2022/01/05/d ... -business/
And Sinner Bikes announcement.
https://www.sinnerbikes.com/en/
Postby Rhubarb » Wed Jan 19, 2022 7:54 am
Velomobiel.nl might also sell spares through their store.
Its a shame how things have turned out. I thought the Hilgo was pretty good actually but I think the Drymer service put a few people off. Harry seems to have carried the whole organisation for so long, but he can't do it on his own.
I wish you all the best.
Postby Bargo » Thu Jan 20, 2022 3:43 pm
- Bartek
Postby Bartek » Thu Jul 21, 2022 6:24 pm
KMX Viper
Trek 350
Postby skyblot » Thu Jul 21, 2022 9:52 pm
Postby Vicfarmer3 » Tue Aug 09, 2022 1:55 pm
Hi Bartek
I would be interested in some details of your mango. Be really interested if you were in Victoria.
Gerard
Postby Bargo » Fri Sep 16, 2022 4:03 pm
Postby Peter A » Tue Oct 25, 2022 8:46 am
Have a friend who is using a flashing tailight but would like to see him safer(?) with flag(s)?
- find_bruce
- Moderator
Postby find_bruce » Tue Oct 25, 2022 10:56 am
In most circumstances a velo is highly visible - if you ride with your friend you will notice that every tom, dick and harriet stops & gawps and or waves, kids yell excitedly.
At least in my experience the only time visibility is an issue is in traffic when a velo can completely disappear beside many vehicles - the problem is that I'm not sure that a flag at the back of the velo will cure that - it is unlikely to be high enough to be seen over an urban assault vehicle.
If it makes someone feel safer to have a flag I wouldn't try to talk them out of it - I used to tow my son on a wee hoo & I had a flag - it did no harm
Postby skyblot » Tue Oct 25, 2022 11:10 am
Flags are good for 2 things:find_bruce wrote: ↑Tue Oct 25, 2022 10:56 amAs far as I am aware there is no legal requirement for a flag anywhere in Australia.
Keeping Magpies away; and
Keeping away people who insist on telling you that you need a flag.
Flags have negligible effect on cars etc...
I'll agree they may have benefit while transiting through crowded shopping centre car parks, they can be one of the most frightening areas to ride through.
Postby Peter A » Tue Oct 25, 2022 4:08 pm
At car highway speeds the tail light certainly helps ID the "thing on the road" to a car driver, hope he stays safe.
Postby zebee » Tue Oct 25, 2022 8:22 pm
Flags seem to be useless unless quite large and those droop. The "spinner" things are a bit better but still have to be large.
The best so far is the kayak canopy which is a big orange canopy over the top of the trike at about sedan driver eye height. Very obvious and gives them a way to see how big the trike is.
I can't see the point of a flag for a velo. Why do they need to be seen from around cars? THe velo itself is big enough and obvious enough. A little flag doesn't say "hey, big cigar shaped thing here" it says "small fulttery thing, who knows what it is, not interesting, just ignore me".
Drivers have learned to ignore almost everything on the road and beside it because there are so many distractions. A flag only says "bike here' to other recumbent riders and they have already noticed.
- recumbenteer
Postby recumbenteer » Tue Jan 10, 2023 7:21 pm
https://www.instagram.com/p/CnK3HE2pYaj/
....and take the new kid out for a good time
Rotovelo Mk2 ...
"the Jaffa"?
Rotovelo Across Australia
