Helmet Cam study - drivers are usually responsible
WestcoastPete
Postby WestcoastPete » Mon Jan 30, 2012 2:17 pm
Here is an article about a study someone has done analyzing helmet cam footage from a cohort of 13 cyclists.
http://theconversation.edu.au/helmet-ca ... safer-3540
This is the most interesting part to me:
Marilyn Johnson, Research Fellow at Monash University wrote:In 87% of the events captured, the driver was responsible for the action that preceded the event. In 74% of those events, the driver cut the cyclist off, turning in front of the cyclist without either:
providing enough space
indicating effectively
a head check.
The footage showed that, rather than being focused on the cyclist they had just cut off, drivers were instead focused on other vehicles on the road.
If you take cyclists out of the equation, the behaviour of the recorded drivers was safe. Large-enough gaps were selected when entering and exiting parallel parking bays, lane changes were done safely, turns were done safely, and car doors were opened without endangering other road users.
Unfortunately, none of these behaviours were safe for cyclists.
Last edited by WestcoastPete on Mon Jan 30, 2012 2:45 pm, edited 2 times in total.
WestcoastPete
Re: Helmet Cam study - drivers are usually responsible
Postby WestcoastPete » Mon Jan 30, 2012 2:38 pm
I hadn't seen any data on it before, although I'd though this was the case. Even though the study wasn't very big, I'm still surprised at the 87% figure.
damhooligan
Postby damhooligan » Mon Jan 30, 2012 2:40 pm
WestcoastPete wrote:Here is an article about a study someone has done analyzing helmet cam footage from a cohort of 13 cyclists.
a head check.
Do you have a link ??
And do I misread this, or does it say, that when you ignore the fact they are not safe and responsible drivers (ie cutting cyclists off)
they are resonsible drivers ?? :shock:
why do you want to take cyclist out of the equation?, to what porpouse??
i dont get it.. :?
The dutch have one word to describe the aussie MHL, this word is ;
SCHIJNVEILIGHEID !!
WestcoastPete
Postby WestcoastPete » Mon Jan 30, 2012 2:47 pm
Whoops! Post edited with link added.
I guess they're saying that these drivers are just not considering cyclists, but they should be. The study recommends education of drivers in relation to interacting with cyclists because they're generally not behaving differently with cyclists now.
Postby find_bruce » Tue Jan 31, 2012 9:56 am
I suspect a study of motorcycle helmet cams would show similar results
In the dim dark recesses of what used to be my memory, I seem to recall a study that Ambulances with lights & sirens were more likely to be involved in SMIDY type accidents than fire trucks also with lights & sirens.
The theory goes something along the lines of how we perceive & prioritise danger - truck = big & scary = avoid, cyclists = meh.
Perhaps the solution is the Frill Neck Lizard Bike :)
sogood
Postby sogood » Tue Jan 31, 2012 10:02 am
Ummm... Major bias in a study like this. If the riders with helmet cam were responsible for 13% of the errors, then I wonder what would be the percentage if there were no recording?
Bianchi, Ridley, Tern, Montague and All things Apple :)
sogood
Postby sogood » Tue Jan 31, 2012 10:53 am
Oxford wrote:Agree, if you know you are being recorded, you're usually on your best behavior. But doesn't bely the fact that we do experience what this study has unveiled, but to what extent?
Agreed. The problem is that most of those who complain here are also "good" cyclists. Lots of rogue cyclist don't hang around this site. So again, the question is to what extent.
My take on this is that there are idiots in the society and they can be motorists or cyclists. Being a motorist or cyclist alone won't significantly change those fundamental personality traits.
Alex Simmons/RST
Postby Alex Simmons/RST » Tue Jan 31, 2012 11:02 am
sogood wrote:My take on this is that there are idiots in the society and they can be motorists or cyclists. Being a motorist or cyclist alone won't significantly change those fundamental personality traits.
Agree, however the consequences of one's idiotic actions can be considerably different when in a car vs on a bike (like the different amount of carnage one can do with a single shot gun vs an automatic weapon with multiple rounds).
But yes, such a study is terribly biased. Some element of blinding is required.
1. you need footage from cyclists that don't know they are recording
2. you need same type of footage from vehicles
sogood
Postby sogood » Tue Jan 31, 2012 11:11 am
Alex Simmons/RST wrote:Agree, however the consequences of one's idiotic actions can be considerably different when in a car vs on a bike (like the different amount of carnage one can do with a single shot gun vs an automatic weapon with multiple rounds).
Agree, the outcome can be very different depending on whether one is on a 10kg bike or 2000kg SUV. But that's not a question of "responsibility".
Double blind won't be easy to implement. But the idea of mandatory in-vehicle camera is an interesting one, a bit similar to the recorder device they have in long-haul trucks. I am sure it'll leads to improved driver/rider behaviour but can also imagine the amount of community resistance.
Postby Aushiker » Tue Jan 31, 2012 6:00 pm
The analysis from what was stated at a safety forum does not support this at all ... that is the riders quickly dropped into their normal behaviour patterns as you would expect (including pervering I believe :)) and as I suspect most cyclists with helmet cams know. I know that sometimes I look back at my recordings and go whoops ... It would be helpful if MUARC would hurry up and get the research published so there could be informed commentary :)
Furhermore, from the link in the OP
We’ve since analysed each of those events, frame-by-frame.
a head check.
(my emphasis)
Note carefully what is being stated .... the cyclist doing the recording does NOT control or change the behaviour of the motorist. Extprolation of this finding is not something the researchers can be held responsible for :roll:
GraemeL
Postby GraemeL » Thu Feb 02, 2012 10:38 am
Oxford wrote:I actually tried an in car recorder a few years back. I was shocked at my own driving/behaviour and that's even after I had self modified knowing I was being recorded. I now drive differently (read better behaved) based on that experience. Knowing that someone else could be recording does make you behave differently.
I use my GoPro in the car, I have it mounted under the rear vision mirror. It has made me look at how I drive because the footage may be used in the event of an accident and also because others may also be using a camera in their cars.
Also in the event I am wrongly accused of speeding (I don't trust speed cameras) or running stop signs etc, at least I have something to prove otherwise.
If I had a dollar for every infringment I caught on camera I would be a happy man. Think of the revenue they could raise if people could send in footage once a week. If cameras became common place drivers attitudes would change, because they would never know when their stupidity would be caught on camera.
Graeme
sogood
Postby sogood » Thu Feb 02, 2012 11:06 am
GraemeL wrote:Also in the event I am wrongly accused of speeding (I don't trust speed cameras) or running stop signs etc, at least I have something to prove otherwise.
How will a GoPro camera be able to differentiate 60km/h vs 70km/h? Just curious as to how you can prove your innocence without something like a GPS or includes your speedo in the frame.
Mrfenejeans
Postby Mrfenejeans » Thu Feb 02, 2012 11:42 am
The selection of cyclists is a bit narrow being that of only commuter cyclists, people who cycle in traffic everyday.
I bet the results would be a lot different if you put cameras on all sorts of cyclists from roadies , recreational cyclists, BMX riders and god forbid the L.A. style brake-less fixie bike riders . More often than not when i see cyclists doing stupid things it is typically not the Road cyclist nor the commuter cyclist.
sogood
Postby sogood » Thu Feb 02, 2012 12:05 pm
Oxford wrote:you can use the footage to time the passing of specific objects and the distance between them like the old style amphometers.
distance/time=speed
Considered that, but the error would be significant I suspect. Differentiating 100 and 60km/h it'd be ok, but for 60 vs 65 or 70km/h? I am not sure. I was wondering if there was a GPS coupling or something similar.
Alex Simmons/RST
Postby Alex Simmons/RST » Thu Feb 02, 2012 12:27 pm
distance/time=speed
some cameras are gps enabled. but gps speed is not always reliable in any case. on average, sure but not for second by second data.
sogood
Postby sogood » Thu Feb 02, 2012 12:36 pm
Alex Simmons/RST wrote:some cameras are gps enabled. but gps speed is not always reliable in any case. on average, sure but not for second by second data.
Agreed. But it would be a better reference if one needs to contest these cases.
zero
Postby zero » Thu Feb 02, 2012 12:49 pm
It won't, but realistically I wouldn't care much about a 10 over. I would care deeply about a 70 over, and handheld lasers have been known to make royal screwups of motorcycle speed measurements, and police/prosecutors have been known to fight it in court even when its plainly clear they stuffed up. Its also easy to place a cam to see ahead and speedo on a motorcycle.
zero
Postby zero » Thu Feb 02, 2012 12:54 pm
distance/time=speed
This is good for a gross average, its not going to disprove 10 over at a specific point of measurement or short distance. The basic problem is unless the object being used is a road marking and a wheel is in shot, then its difficult not to introduce some error in judging that the vehicle is a known distance away from an object.
