Confused about 8 week training program for TT
Postby zill » Wed Feb 18, 2015 10:45 pm
It really emphases on interval training which is fair enough but what I'm really surprised about is that the only time where the program wants you to practice an actual TT effort on the course you will be competing is the week before the race. I would have thought you'd want as much exposure to the course and the TT effort on the course as part of the training?
What is the science behind this?
- Derny Driver
Re: Confused about 8 week training program for TT
Postby Derny Driver » Wed Feb 18, 2015 11:07 pm
Ride the course to study it, look for the smoothest part of the road surface (usually RH wheel track just near the centre line) and look for hazards, undulations, corners etc.
Its a mistake in my opinion to "practise" Time Trialling before the race. You just end up with the cough cough *triathlete mentality* of just tempo riding everywhere at 32kph.
(Disclaimer I was a triathlete once and am on Transitions)
On race day you want to be doing 38-40kph for the distance. So do some short intervals at that pace in training, say 4 or 5 minutes. Then back off and just ride easy.
On the day you will have the assistance of adrenaline and the excitement to enable you to ride nice and hard for the distance.
Use power or cough cough where's alex *heart rate* to measure your effort.
I used to TT at exactly 92% of maximum HR which is basically threshold.
Short intervals at speed are the way to go.
A full race simulated one 1 week out is pretty standard procedure but many people don't bother with it.
Its very hard to simulate a full TT by yourself in isolation.
Postby zill » Thu Feb 19, 2015 10:05 am
Also by doing shorter intervals on the course wouldn't that likely to lead you to over pace yourself in the race?
- Alex Simmons/RST
Postby Alex Simmons/RST » Thu Feb 19, 2015 11:13 am
What if the plan did require you to do practice runs on the race circuit but the venue was not local/readily accessible until just before race day?
Many courses are not actually rideable until race day due to traffic control.
- Xplora
Postby Xplora » Thu Feb 19, 2015 11:21 am
I like Friel's approach to pacing - if your target pace is 35kmh, push harder when it drops to 33, push real hard when it drops to 31 - and if it goes up to 37, ease off, and 39, stop pedalling. He uses a 10/20/30/40/50 protocol, but the principle works well. Pedal hard when you are going slow, and soft when you are going fast. You spend a lot of bikkies pushing against wind resistance.
Postby dalai47 » Thu Feb 19, 2015 4:18 pm
Too simplistic approach. Far too many variables to just say I'll stick to a speed. Even trying to stick to a power band is fraught with danger - did that for my first TT with power on a course I'd raced a number of years. Rode my slowest time on that course that day! I just use PE with the power only as the carrot to make me work harder if my power drops below a predetermined value.Xplora wrote:I like Friel's approach to pacing - if your target pace is 35kmh, push harder when it drops to 33, push real hard when it drops to 31 - and if it goes up to 37, ease off, and 39, stop pedalling. He uses a 10/20/30/40/50 protocol, but the principle works well.
If you can pre-ride the course fine, but not necessary. Really only more about knowing the best lines rather than speeds through a section. What if on the rehearsal ride you have a tailwind and on race day a headwind?
Zill. Do the intervals / know your body and learn from the results. Only way to improve at TT's is to race as many as possible.
- Derny Driver
Postby Derny Driver » Thu Feb 19, 2015 7:04 pm
Postby zill » Thu Feb 19, 2015 9:20 pm
Isn't the most common mistake to start out too hard and then "blow up" or "crack" or "pop" as they say?Derny Driver wrote:most people UNDER-PACEzill wrote:
Postby zill » Thu Feb 19, 2015 9:22 pm
Good point but at club level, most courses are not busy of traffic anyway.
Postby zill » Thu Feb 19, 2015 9:27 pm
What is PE?dalai47 wrote:Too simplistic approach. Far too many variables to just say I'll stick to a speed. Even trying to stick to a power band is fraught with danger - did that for my first TT with power on a course I'd raced a number of years. Rode my slowest time on that course that day! I just use PE with the power only as the carrot to make me work harder if my power drops below a predetermined value.Xplora wrote:I like Friel's approach to pacing - if your target pace is 35kmh, push harder when it drops to 33, push real hard when it drops to 31 - and if it goes up to 37, ease off, and 39, stop pedalling. He uses a 10/20/30/40/50 protocol, but the principle works well.
- Derny Driver
Postby Derny Driver » Thu Feb 19, 2015 10:50 pm
- Derny Driver
Postby Derny Driver » Thu Feb 19, 2015 10:51 pm
Perceived effort.zill wrote:
What is PE?
Postby zill » Thu Feb 19, 2015 11:44 pm
Derny Driver wrote:Perceived effort.zill wrote:
What is PE?
Ahh that makes sense. I think dalai has a good approach to the TT. When I focus on the power meter, I tend to push too hard and then crack before the finish in my practice TT. But then again I tend to aim for too high power numbers.
- Xplora
Postby Xplora » Fri Feb 20, 2015 12:35 am
- Alex Simmons/RST
Postby Alex Simmons/RST » Fri Feb 20, 2015 7:41 am
Perhaps, but how can a generic plan know that or that's the course you are going to ride?zill wrote:Alex Simmons/RST wrote:
My point is when you buy a generic plan, you can't expect it to be customised to your individual circumstance. That requires additional information and insight (and time to prepare it).
- Alex Simmons/RST
Postby Alex Simmons/RST » Fri Feb 20, 2015 7:46 am
I'd say you are both right.Derny Driver wrote:Not in my experience. Most people are too conservative.zill wrote:
Having done a lot of analytics on pacing, the most common mistake is starting too hard (opening 3-5 minutes) and then as a result not being able to go hard enough. Riders are often forced into being conservative.
But I definitely support what DD is saying. Finding the edge of the pacing cliff requires risk and a mental application that many either don't possess or don't train for. It's a special skill.
Postby zill » Fri Feb 20, 2015 9:38 am
As I'm just starting out, will give this generic plan a go and see how it goes. On your website http://www.rstsport.com/training/" onclick="window.open(this.href);return false; there are also some generic plans. What is the difference between TT Power Booster 1 and TT Power Booster 2 in terms of the training workouts? Say after I finish this program, should I go on to TT Power Booster 2 (I'm looking to do TT races on a monthly basis after my first one in 8 weeks)?Alex Simmons/RST wrote:Perhaps, but how can a generic plan know that or that's the course you are going to ride?zill wrote:Alex Simmons/RST wrote:
