Giant P-SL1 tyres - worth keeping or upgrade?
- Mububban
Postby Mububban » Thu Sep 08, 2016 10:26 am
I'm paying off a new Giant Contend that comes with stock "Giant P-SL 1, Front and Rear Specific, 700x25, Folding" tyres. I'll be riding my bike on solo weekend rides and commuting (13km each way). Bike paths near me are bumpy and roads are average, not excellent and not horrible either. I'll never race nor likely do over 50km on a single ride, although one of those week long cycle touring holidays is on the bucket list.
I'm considering upgrading straight away to something rated for puncture protection, but has anyone got any feedback on the stock P-SL1 tyres?
- Derny Driver
Re: Giant P-SL1 tyres - worth keeping or upgrade?
Postby Derny Driver » Thu Sep 08, 2016 11:02 am
That would be a downgrade If you're throwing away the PSLRs can I have them?Mububban wrote: I'm considering upgrading straight away to something rated for puncture protection, but has anyone got any feedback on the stock P-SL1 tyres?
Why not just ride them until they wear out before putting on some nasty hard slippery gatorskins or whatever?
http://road.cc/content/review/62843-giant-p-slr1-tyre
Postby Velt » Thu Sep 08, 2016 11:32 am
- Mububban
Postby Mububban » Thu Sep 08, 2016 12:25 pm
Is there a difference between the P-SL1 listed on my bike, and the P-SLR1?Derny Driver wrote:That would be a downgrade If you're throwing away the PSLRs can I have them?Mububban wrote: I'm considering upgrading straight away to something rated for puncture protection, but has anyone got any feedback on the stock P-SL1 tyres?
- Duck!
Postby Duck! » Thu Sep 08, 2016 1:40 pm
Gators are one of the more rideable tyres in that sector. Yes they're harder and less grippy than supple race tyres, but they're considerably more compliant than most other durable offerings (I'm probably supposed to say nice things about Schwalbe because the shop I'm in sells them, but I just can't). You just don't want your first ride on them to be in the wet! Some combination of the tread compound and moulding release agent residue does make them a bit slipperier than others when very new, but they scrub in over a few rides. I've done many thousands of km on Gators, and can't recall the last time I had a puncture.Derny Driver wrote: Why not just ride them until they wear out before putting on some nasty hard slippery gatorskins or whatever?
- Derny Driver
Postby Derny Driver » Thu Sep 08, 2016 3:07 pm
- Mububban
Postby Mububban » Thu Sep 08, 2016 4:18 pm
Thanks Duck, I'll give the stock tyres a go and cross my fingers. And Gatorskins seem to get a lot of votes.Duck! wrote:The SLRs have a softer, grippier racing-oriented compound and a lighter casing. Faster, but less durable. The SLs are reasonable tyres; not fantastic, but not horrendous either. The early versions were a bit ordinary, but the current generation have improved. Ride them until they die, then replace with something that best suits your needs.
Last question then - folding vs wire bead for the (eventual) next set of tyres? Wire is heavier but has stronger sidewalls from what I've read?
- Duck!
Postby Duck! » Thu Sep 08, 2016 6:52 pm
Postby lunar_c » Fri Sep 09, 2016 11:58 am
The SL's are okay but definitely feel sluggish.
Postby hamishm » Mon Sep 12, 2016 10:16 am
Throw the Giants as far and as quickly as possible...
Postby Arlberg » Tue Sep 13, 2016 7:07 pm
What don't you like about Schwalbe tires? I'm thinking of the Schwalbe One clincher in particular which generally seems to get very good reviews.Duck! wrote:I'm probably supposed to say nice things about Schwalbe because the shop I'm in sells them, but I just can't).
- Duck!
Postby Duck! » Tue Sep 13, 2016 7:39 pm
- bychosis
Postby bychosis » Tue Sep 13, 2016 10:21 pm
Postby ironhanglider » Tue Sep 13, 2016 10:30 pm
Isn't that odd. I fitted tyre liners and got punctures from the liners!bychosis wrote:If you are worried about punctures $20ish for a set of tyre liners could help, and then you can run any tyre you like with having to look for puncture protected ones. I haven't had a puncture since fitting some Mr Tuffy liners in two bikes.
Cameron
- bychosis
Postby bychosis » Wed Sep 14, 2016 10:58 am
I have been told that sometimes where the tyre liners overlap you can get a wear point and cause an issue. I was told this while repairing a flat in a tube from one of my lined tyres, the hole wasn't in the linered area, was rim tape related. Part of my commute is along a steel fibre reinforced concrete pathway and prior to instally Mr Tuffys I was getting about one puncture per week from the metal fibres in the path. Since installing the liners a couple of years ago I haven't had a puncture from the fibres, but have pulled plenty of fibres from the tyres.ironhanglider wrote:Isn't that odd. I fitted tyre liners and got punctures from the liners!bychosis wrote:If you are worried about punctures $20ish for a set of tyre liners could help, and then you can run any tyre you like with having to look for puncture protected ones. I haven't had a puncture since fitting some Mr Tuffy liners in two bikes.
Cameron
Postby Bourney » Fri Sep 16, 2016 9:35 am
Granted I much prefer GP 4000's, but I figure I might as well get some use out of these, rather than throwing money to the wind straight away.
I do agree that in the wet they can get a bit slidey, but I wouldn't say it's horrendous.. then again I don't push that hard in the wet.
- Mububban
Postby Mububban » Fri Oct 14, 2016 4:20 pm
- Mububban
Postby Mububban » Sat Oct 22, 2016 11:15 pm
- Mububban
Postby Mububban » Tue Nov 01, 2016 10:43 pm
So, I just experienced this today. Coming downhill approaching a roundabout, a car turned without signalling rather than continuing on straight, and I had to jam the brakes on harder as I was only gently braking. The back locked up and slid, I wasn't going to stop in time and had to power on through before they turned. And that was in the dry.hamishm wrote:My Giant TCR Advanced came with these tyres. I had to brake reasonably hard while descending once and slid along the road quite nicely. So now I use these tyres on my trainer. I never had anything like it with years of riding on GP4000, GP4000s and GP4000s II.
Partly me not being cautious enough approaching the roundabout, but that was a mild pucker moment.
Postby chriso_29er » Wed Nov 02, 2016 8:35 am
- Duck!
Postby Duck! » Wed Nov 02, 2016 9:08 pm
Any tyre will do that in those circumstances; rear brakes are extremely ineffective in emergency situations (and barely effective at the best of times).Mububban wrote:
- Thoglette
Postby Thoglette » Thu Nov 03, 2016 1:27 am
...stop worrying.bychosis wrote:If you are worried about punctures
They'd have happened by now. Relax and enjoy the supple options.
- Thoglette
Postby Thoglette » Thu Nov 03, 2016 1:30 am
Derney Driver will be rolling his eyes at this point ("young folk of today" and all that)Mububban wrote:The back locked up and slid,
If you're stopping HARD the back brake is not doing anything at all. (It's called a "stoppie" when you get the back wheel off the ground - and yes, normal bicycles can and will do this)
- Mububban
Postby Mububban » Tue Nov 15, 2016 5:40 pm
I also found the P-SL1 tyre to be a real b!tch to get back on (did I mention how skinny I am?) and had to use some washing up liquid as lube to overcome the rubber's friction. Let's hope it's all okay and I get home with no more dramas.
- Howzat
Postby Howzat » Wed Nov 16, 2016 5:14 am
Gatorskins are intended as high km, long wearing tyres.
