Riding flat tyre. Still safe?
Postby vodafone_au » Mon Jan 29, 2018 5:10 pm
My question is, how do I know if my wheel (aluminium), tyre and tube are still safe to use. Also, should I better get a new tube (and tyre?) instead of using the puncture patch?
At present, I can't find anything suspicious. However, I'm a bit cautious since I did ride a bike for a while after the puncture (even at a slower speed) and I'm not sure whether there was any impact on my wheel (or tyre). In fact, I remember that my rim was hit by the ground at least 2-3 times during the flat-tyre riding.
The size of puncture could be small as I thought nothing was wrong when I re-inflated the wheel at home and pressed the bike and tyre few times. However, it eventually became flat again when I checked it again after few hours.
Thanks in advance for your kind advice!
- find_bruce
- Moderator
Re: Riding flat tyre
Postby find_bruce » Mon Jan 29, 2018 5:32 pm
Same with the tyre & tube - look for cracks & wear.
- Duck!
Re: Riding flat tyre. Still safe?
Postby Duck! » Mon Jan 29, 2018 9:43 pm
Postby Kronos » Tue Jan 30, 2018 12:28 am
I most definitely don't mean any disrespect, but next time Don't let your ego get in the way, it's not worth the cost of a new wheel.
- gorilla monsoon
Postby gorilla monsoon » Tue Jan 30, 2018 10:37 am
Postby march83 » Tue Jan 30, 2018 10:42 am
Postby human909 » Tue Jan 30, 2018 11:38 am
Agreed. In my experience everything should be A-OK with the tyre. If you are careful then you can avoid denting the rim. No surprises if there is further damage to the tube, but by the sound of it you got away with it even with the tube.Duck! wrote:The tube may have suffered additional pinch-punctures from riding while deflated. Inflate and thoroughly inspect for escaping air. Patch it if the hole/s are small, discard if there are big or numerous holes. The tyre will probably be OK, but again thoroughly inspect for anything that may have caused the initial puncture. If the rim hit bumps of any note, check for flat spots and dents in the sidewalls.
As far as the many wowser comments. No really. When did people start thinking bicycle components were made of tissue paper.
How do you figure that? The roundness of a wheel isn't particularly affected by this scenario. If badly treated then localised rim dents are definitely a risk, but out of roundness is a different cause and issue. If you are putting those forces into your rim with a flat I dare say you would be flying through the air as welll.Kronos wrote:You may have put the wheel out of round permanently
Keep your weight back and ride slowly. Not biggy. Not fun though... More fun rolling along at 10-15kph than walking a bike...gorilla monsoon wrote:I just want to know how you ride 7km on a flat tyre.
How have you made that assessment? Treads are highly flexible so aren't easily damaged by flexing. (HINT: The clue is in the name.)march83 wrote:Yeah, that's terminal. You've done sufficient damage to the tyre's threads that it can't be trusted. Bin it and move on. Chalk it up to the price of staying safe.
- A_P
Postby A_P » Tue Jan 30, 2018 11:42 am
me too... i have limped out of the forest with a rear flat on the MTB, but front flat, thats walkin .gorilla monsoon wrote:I just want to know how you ride 7km on a flat tyre.
Postby human909 » Tue Jan 30, 2018 11:47 am
Depends on how straight you are riding. A front has far less weight on it, particularly if you sit/stand up to lighten up the front. Sure your ability to steer is poor but you're limping along so all good. I suppose on a MTB with chunky tires your could probably limp fairly quickly with a flat rear a flat front in bumpy terrain does sound yucky.A_P wrote:me too... i have limped out of the forest with a rear flat on the MTB, but front flat, thats walkin .gorilla monsoon wrote:I just want to know how you ride 7km on a flat tyre.
- P!N20
Postby P!N20 » Tue Jan 30, 2018 11:47 am
Wheeliesgorilla monsoon wrote:I just want to know how you ride 7km on a flat tyre.
Postby Kronos » Tue Jan 30, 2018 1:06 pm
Eventually if you keep riding on a rim like that you have a good possibility of wearing a nice little flat spot in your round rim making it entirely unusable forever. It's not really rocket science... Riding on concrete pavement/bitumen on alloy wheels is the equivalent of riding on a piece of sand paper. I don't need to figure the results I've seen them before. Eventually you're gonna wear straight through the tyre and be riding metal on concrete/bitumen. You wouldn't drive a car on a flat tyre, why is your bike any different? The only exception in this case is that there are now run flat tyres for cars, that's not the point other than to say the equivalent doesn't really exist for bikes.human909 wrote:How do you figure that? The roundness of a wheel isn't particularly affected by this scenario. If badly treated then localised rim dents are definitely a risk, but out of roundness is a different cause and issue. If you are putting those forces into your rim with a flat I dare say you would be flying through the air as welll.Kronos wrote:You may have put the wheel out of round permanently
Just walk or phone a friend.
Postby march83 » Tue Jan 30, 2018 2:19 pm
THREADS not treads... Tyres and their sidewalls aren't designed to be crushed between the rim and the road. At some point between 1km and say 100km (just to pull a number out of the air) of riding on a flat tyre the rim will have cut into and destroyed the sidewall of the tyre by damaging the THREADS in the carcass. I'm betting that the point is much closer to 1km than to 100km and that 7km is probably well beyond the point at which damage has occurred. Re-inflating the tyre may expose weak spots, or maybe it won't - maybe hitting a small bump mid corner at 70km/h exposes the weak spot. Either way, I think the tyre should go in the bin.human909 wrote:How have you made that assessment? Treads are highly flexible so aren't easily damaged by flexing. (HINT: The clue is in the name.)march83 wrote:Yeah, that's terminal. You've done sufficient damage to the tyre's threads that it can't be trusted. Bin it and move on. Chalk it up to the price of staying safe.
Postby fat and old » Tue Jan 30, 2018 2:53 pm
Yeah, we were poor in that area back then. Joe Dirt poor.
Postby Arbuckle23 » Tue Jan 30, 2018 3:45 pm
Luxury (in my best Yorkshire accent)fat and old wrote: Yeah, we were poor in that area back then. Joe Dirt poor.
- baabaa
Postby baabaa » Tue Jan 30, 2018 4:02 pm
If you rode the bike with a slow leak and made it home with some air in the tyre I would say all is good in terms of the rim and the tyre being safe but the tube may need a patch or a check of the value. Do a google on presta vs. schrader valves, pump up the tyre hard and give both a good gob of spit ( if you can find a drooling bloodhound dog even better....) or a few drops of water and detergent to see if you can get it blowing bubbles. Prestas types do need the little screw top thing snugged down and can loosen at a point which they know is the least expected.
Postby human909 » Tue Jan 30, 2018 4:16 pm
No it isn't but you are don't seem to be making sense. Even if you were wearing your rim (unlikely) because it is rolling not sliding, it would be even as the wheel turns so no flat spot.Kronos wrote:Eventually if you keep riding on a rim like that you have a good possibility of wearing a nice little flat spot in your round rim making it entirely unusable forever. It's not really rocket science...
Eventually our sun is going to die out too. In practice you need to do a lot of riding to wear through to metal on road and before then your really should have stopped. In my experience limping home has none of these 'eventually' problems.Kronos wrote: Riding on concrete pavement/bitumen on alloy wheels is the equivalent of riding on a piece of sand paper. I don't need to figure the results I've seen them before. Eventually you're gonna wear straight through the tyre and be riding metal on concrete/bitumen.
Yes I would if I had no other choice and it was safe to limp home.Kronos wrote:You wouldn't drive a car on a flat tyre, why is your bike any different?
That is a choice. I've chosen not to in the past and kept using the tyre and rim for years afterward (still am)....Kronos wrote:Just walk or phone a friend.
Sorry for the typo. Point still stands. The threads aren't going to get damaged but being crushed inside of ''rubber'. The are flexible. Sure if you CUT the threads then there is a good reason to be worried, but your would generally need penetration of the rubber to do so.march83 wrote:THREADS not treads...
Hell of alot of assumptions there. Speaking from experience I've had no issues.march83 wrote:I'm betting that the point is much closer to 1km than to 100km and that 7km is probably well beyond the point at which damage has occurred.
Postby Kronos » Tue Jan 30, 2018 4:26 pm
Err no... It isn't all equal Every time you brake you're putting a stopping load on a particular part of your rim. It isn't all equal. When you stop you have some inertia before you come to a full stop and at that point your motion is exerting force on a particular part of the rim.human909 wrote:No it isn't but you are don't seem to be making sense. Even if you were wearing your rim (unlikely) because it is rolling not sliding, it would be even as the wheel turns so no flat spot.Kronos wrote:Eventually if you keep riding on a rim like that you have a good possibility of wearing a nice little flat spot in your round rim making it entirely unusable forever. It's not really rocket science...
It's not like that either. By 7km I'm gonna have a fair idea that you will have run over something to put a hole in the canvas and your rim will continue to be worn through. Not only that, you're likely to wear the sidewall of your tyre also which is not designed to be worn through.human909 wrote:Eventually our sun is going to die out too. In practice you need to do a lot of riding to wear through to metal on road and before then your really should have stopped. In my experience limping home has none of these 'eventually' problems.Kronos wrote: Riding on concrete pavement/bitumen on alloy wheels is the equivalent of riding on a piece of sand paper. I don't need to figure the results I've seen them before. Eventually you're gonna wear straight through the tyre and be riding metal on concrete/bitumen.
Please go to your nearest department of transport and hand in your license and get off my road. You're a menace to society with that belief and endangering every other motorist on the road. Nah, you don't do that... you pull up and phone a friend, or walk.human909 wrote:Yes I would if I had no other choice and it was safe to limp home.Kronos wrote:You wouldn't drive a car on a flat tyre, why is your bike any different?
Just because you do it doesn't mean its a good practice. Assuming its a fully deflated tyre the practice is no good... Assuming a road bike tyre in the world of the average senses and average rim widths anything under 80psi can be dangerous. If your tyre stays above this pressure you're good to continue to ride for a slow leak as far as needs be to get home. Assuming an average mountain bike you could still ride on 20psi. However, not everything is average. In this case we assume the rider was riding on a flat tyre which is just not acceptable in any sense.human909 wrote:That is a choice. I've chosen not to in the past and kept using the tyre and rim for years afterward (still am)....Kronos wrote:Just walk or phone a friend.
K thnks bai...
Postby fat and old » Tue Jan 30, 2018 5:44 pm
Not really. Maybe if you're racing a crit, or bombing down Falls Ck? Otherwise, nah, it's ok to 45-50 at least. Based on 74KG rider, 23mm tyres on older Kysriums. I don't pump mine until they get to 60 or so. 90Kg, 25mm tyre on newer fulcrums. No racing or bombing down mountains. I'd guess that OP is more like me than Nibali (maybe not the weight....).Kronos wrote: Just because you do it doesn't mean its a good practice. Assuming its a fully deflated tyre the practice is no good... Assuming a road bike tyre in the world of the average senses and average rim widths anything under 80psi can be dangerous.
Better to sayIn this case we assume the rider was riding on a flat tyre which is just not acceptable in any sense.
In this case we assume the rider was riding on a flat tyre which isn't really the best thing to do, but hey....I wasn't there so who knows?
- Thoglette
Meanwhile, back in the ute
Postby Thoglette » Tue Jan 30, 2018 7:12 pm
Voda, did you have a completely fat tyre or an underinflated tyre (from a slow leak)? Your initial post suggests the latter*, in which case re-read Duck's post**.
* That would rather ruin the doom-and-flame-fest this thread has become.vodafone_au wrote: In fact, I remember that my rim was hit by the ground at least 2-3 times during the flat-tyre riding.
** It's always a good idea to re-read Duck's posts.
Postby vodafone_au » Tue Jan 30, 2018 8:16 pm
Thanks for the suggestion. I just found the tube only costs like $10 from 99 which isn't much. But I'll see what I can do with my brand-new puncture repair kit.Duck! wrote:The tube may have suffered additional pinch-punctures from riding while deflated.
uhm... just like a man? Tyre wasn't completely flat (maybe at least 30psi were remaining out of 120psi) so I was able to ride it to my home.gorilla monsoon wrote:I just want to know how you ride 7km on a flat tyre.
No bang or a hiss. I didn't even notice it until I felt something a bit weird and pressed the tyre with my fingers. And no, there is no drooling bloodhound dog around me but I just tried what you advised and I haven't found anything suspicious on my presta valve.baabaa wrote:Did you hear a small bang or a hiss? If not it could just be a leaking tyre valve.
Thanks for the suggestions. I guess it was the "slow leak". I just reinflated it (120psi) and only a small difference was found when I checked it again after an hour.Thoglette wrote:Voda, did you have a completely fat tyre or an underinflated tyre (from a slow leak)? Your initial post suggests the latter*, in which case re-read Duck's post**. .
I've never replaced my tube myself but I reckon probably now is the time. I'll try to inspect everything carefully according to everyone's advice and see whether I have some handyman skill. Then, I'll probably visit my LBS and buy some CO2 and an extra tube.
Postby Kronos » Tue Jan 30, 2018 9:56 pm
Postby human909 » Tue Jan 30, 2018 11:44 pm
Kronos. You are not making much sense and honestly you are making things up as you go.Kronos wrote:K thnks bai...
As somebody who HAS ridden home on a completely flat tyre I can tell you that most of what you describe do not occur. Your rims are more than strong enough, nor are they subject to abrasion. You are simply rolling on rubber covered metal. Naturally you have minimal capability to absorb bumps so even your odd raised pavement joint presents rim danger. But you are LIMPING your bike home so you are paying attention to that sort of stuff.
As far as braking goes... Why would you brake on a flat tyre while limping your bike home? Capable braking and cornering go out the window which is no surprise at all. But again that isn't what you'd be doing.
Huh? What motorists on the road? "If I had to" sort of implies there are not other motorists on the road. Being stuck in a remote place might mean a 50km walk, it might mean a 200km walk. And what part of 'safe' and 'limp' don't you understand?Kronos wrote:You're a menace to society with that belief and endangering every other motorist on the road.
Postby Kronos » Tue Jan 30, 2018 11:55 pm
- gorilla monsoon
Postby gorilla monsoon » Thu Feb 01, 2018 10:35 am
So the tyre has gone from being completely flat in your first post to having 30psi in it in your last post? Big difference there, pick one. Maybe you should have mentioned that in the first place.vodafone_au wrote:uhm... just like a man? Tyre wasn't completely flat (maybe at least 30psi were remaining out of 120psi) so I was able to ride it to my home.gorilla monsoon wrote:I just want to know how you ride 7km on a flat tyre.
Postby vodafone_au » Thu Feb 01, 2018 10:22 pm
gorilla monsoon wrote:So the tyre has gone from being completely flat in your first post to having 30psi in it in your last post? Big difference there, pick one. Maybe you should have mentioned that in the first place.vodafone_au wrote:uhm... just like a man? Tyre wasn't completely flat (maybe at least 30psi were remaining out of 120psi) so I was able to ride it to my home.gorilla monsoon wrote:I just want to know how you ride 7km on a flat tyre.
I believe there was "some" air inside the tube although it was really minimal (could be not even close to 30psi).
Sorry if I made you (or anyone) confused
*Update: I checked the wheel, tube and tire today and found a small cut on my tyre and tube. Besides the small cut, there's no visible damage to the tyre and rim (although I later accidentally damaged the tyre from inside while I was trying to remove the tyre from the wheel). Replaced the tube (puncture patch didn't work...) and everything seems okay for now.
Users browsing this forum: Andy01
