M4 Safety Alert Thread
- Bunged Knee
Re: M4 Safety Alert Thread
Postby Bunged Knee » Tue Nov 10, 2020 5:58 am
RMS had made a long diversion for cyclists on M4 again for time being between Pitt St Parramatta to Prospect HWY.
I don`t think that I might believe that it will be done by 6 weeks as it had stuffed the end time many times.
Postby tez001 » Wed Nov 11, 2020 7:48 pm
- Bunged Knee
Postby Bunged Knee » Thu Nov 12, 2020 1:28 am
Postby march83 » Thu Nov 12, 2020 7:42 am
Postby SteveTheTiger » Thu Dec 03, 2020 2:01 pm
Can a cyclist join the motorway at Hill Road, heading eastbound, and get through to Concord Road? If so, how, without using the 'mousehole' under Homebush Bay Drive?
Heading westbound, a separate cycleway has been provided to avoid having to cross the off and on-ramps for Homebush Bay Drive. But I don't see the same thing heading eastbound.
Did the government do the dodgy on us, again?
- find_bruce
- Moderator
Postby find_bruce » Thu Dec 03, 2020 3:19 pm
Curiously the RMS cycleway finder shows a path crossing Haslams Creek near the M4, which supposedly comes out here
If you follow the exit both google & RMS say the bike path goes through the bus tunnel under Homebush Bay Dr, BUT google showed in July 2020 that the gate was locked, which would mean you need to go all the way up to Underwood Rd & use that awful roundabout to come back along Homebush Bay Dr in order to rejoin the M4 path. If the gate is open, there is a new path that goes under the Homebush Bay Dr on-ramp & is an off road path up until Underwood Rd when what happens is a mystery.
Looks like I will need to go for a ride that way & see whats what
Postby JPB » Thu Dec 03, 2020 5:25 pm
- find_bruce
- Moderator
Postby find_bruce » Wed Dec 30, 2020 7:43 pm
On the plus side I discovered there is a new path up the western side of Powells creek, which takes you from Parramatta Rd through to Pomeroy St & from there connects to the existing path to Bicentennial Park. Doesn't look like any useful connections from Parramatta Rd & the park is probably a kid magnet at the usual times, but it might be useful. Looks to continue to the west but I ran out of time to explore further.
Postby zebee » Fri Jan 01, 2021 5:13 pm
Where does that start from at either end? I might take a look see. Usually I go from Pomeroy north along the western side of the creek to the bridge by the tennis court. There's now a path from the other side of Pomeroy rd along the creek? What sort of crossing of Pomeroy Rd is there?find_bruce wrote: ↑Wed Dec 30, 2020 7:43 pm
- find_bruce
- Moderator
Postby find_bruce » Fri Jan 01, 2021 7:54 pm
I was surprised to see the bridge was still there - I thought they were threatening to demolish it as part of waste connex - in any event they have removed all bar 1 of the bollards.
The Pommeroy St end cuts across the bowling greens of the old sports club, but no, there is no convenient way to cross Pommeroy St - best way is probably at the driveway for the old sports club
Postby jovan.s1987 » Thu Apr 15, 2021 3:12 pm
My question is - Any alternate route, which minimises my time on the M4? I'm finding the shoulder extremely dirty for most of the way, with the exception of that area around the M7.
Postby march83 » Thu Apr 15, 2021 3:54 pm
https://bit.ly/2Q7cVnZ
It's further and slower, but it's pretty safe, mostly quiet and clean. Busiest areas were around Sergeants / Carlyle in Minchinbury.
Depending on where in Penrith you need to get to you can continue down the GWH then head through the back of Kingswood, past the uni and the Penrith back streets (Derby, Lethbridge or Stafford)
EDIT, coming from Rydalmere, would it be safer, cleaner, easier to go to the M7 and then take the back roads from Rooty Hill to Penrith? I do that most days coming from the Hills and it's much more pleasant than the M4 commute I used to do back in the day...
Postby jovan.s1987 » Thu Apr 15, 2021 6:43 pm
Thanks for the info. I had actually been looking at the M7 option, but wasn't sure of the best way at getting there? I set out from Rydalmere a street away from Victoria Rd.march83 wrote: ↑Thu Apr 15, 2021 3:54 pmI used to do Rose Hill to lower mountains and did this for a while for the same reasons - too many flats on the M4:
Postby march83 » Thu Apr 15, 2021 7:24 pm
There are quiet back road that vaguely follow the train line from Parramatta to Rooty Hill, but you'd have to do some exploring. Strava's global heatmap is great for this sort of stuff.
Postby jovan.s1987 » Mon Apr 19, 2021 10:17 am
Postby jovan.s1987 » Mon Apr 19, 2021 12:39 pm
- g-boaf
Postby g-boaf » Mon Apr 19, 2021 12:46 pm
Parts of it have a cycleway, but it's a pretty stop start route that is slowed by plenty of traffic lights.jovan.s1987 wrote: ↑Mon Apr 19, 2021 12:39 pmInteresting. Used the route planner on Kamoot & it takes me up the transit way, alongside Old Winsdor Rd, up to the M7 cycle-way.
Certainly don't ride on the transitway - those bus drivers on that tway are very, very aggressive - and they go very fast too. There is a certain 50km/h zone in one part which we are certain many of them take at far more than 50km/h... Should get a speed camera set up there.
Postby jovan.s1987 » Mon Apr 19, 2021 3:31 pm
OK thanks, cross of that option in that case.g-boaf wrote: ↑Mon Apr 19, 2021 12:46 pmParts of it have a cycleway, but it's a pretty stop start route that is slowed by plenty of traffic lights.jovan.s1987 wrote: ↑Mon Apr 19, 2021 12:39 pmInteresting. Used the route planner on Kamoot & it takes me up the transit way, alongside Old Winsdor Rd, up to the M7 cycle-way.
Postby JPB » Sun Feb 19, 2023 5:43 pm
You can get through if you get off your bike and force your way through but be prepared to get a few scratches. I have reported it via Snap Send Solve so hopefully they will be cleared in the next few days.
Postby caneye » Tue Feb 28, 2023 11:12 am
As of last Sunday (26/2), the trees weren't cleared yet.JPB wrote: ↑Sun Feb 19, 2023 5:43 pmThere are a few trees down blocking the path alongside the M4 at Granville - End of Martha St, near the old speedway, following last nights storm.
- g-boaf
Postby g-boaf » Mon Apr 08, 2024 10:18 am
Anything other than a mountain bike will probably not get through there safely. I have reported it to Parramatta Council.
- find_bruce
- Moderator
Postby find_bruce » Mon Apr 08, 2024 11:46 am
- g-boaf
Postby g-boaf » Mon Apr 08, 2024 7:02 pm
Pretty well most of the paths right alongside the river in Parramatta itself are impassable with very deep mud covering them completely.find_bruce wrote: ↑Mon Apr 08, 2024 11:46 amThanks g-boaf - not surprising for mud following floods there, but good to have it confirmed. Let us know when it's cleaned up
It will take more than just blasting with high pressure water to clean it up. Also lots of damage from dropped tree branches.
- Retrobyte
Postby Retrobyte » Tue Apr 09, 2024 7:41 am
That's the good thing about the new Alfred St bridge - that low lying area prone to flooding between the wharf and Church St can be completely bypassed now.
Users browsing this forum: piledhigher2
