Throttle
Poider
Throttle
Postby Poider » Mon Oct 04, 2021 12:37 pm
Hello, Can a throttle be added to any e-bike?, I am buying the Earth T-Rex 650b Trekking, it has a mid drive motor.
Re: Throttle
Postby familyguy » Mon Oct 04, 2021 12:46 pm
Probably, with the right hacking and electronics genius. But they're not made that way. They're a pedal assist system, not a drive system.
Bear in mind the moment you add a throttle-type control probably renders it illegal for any public road or fire trail in Australia. Wiser heads here will know the precise laws.
Poider
Re: Throttle
Postby Poider » Mon Oct 04, 2021 5:28 pm
Thank you, I spend a bit of time on a friend's large property and usually we ride quad bikes or trail bikes, I am interested in taking my E-bike that step further and ride the trails on his land.
Rant coming....
(I know that I can ride my normal pushbike at 60kph with out a worry and as soon as I put on a motor to assist my asthmatic lungs to cope with pedalling that i suddenly become a danger to the public and can only ride at 25kph, I am aware of our dictatorial Governmental regulations that make absolutely no sense what such ever,)
Sorry, rant over
When I originally enquired about E bikes I was told they could have a throttle retro fitted, I am not after speed, just a bit more abity to rest on some of the longer hills
Re: Throttle
Postby find_bruce » Mon Oct 04, 2021 6:18 pm
Short story - if the controller is intended to operate by throttle, it will have a wire to plug into & its a simple job. The earth bike is a company branded motor, so unless you can buy a throttle from that company, the answer is probably not.
There are reports of mechanics refusing to service e-bikes that have been modified & you will have voided any warranty.
Any bike with throttle & 250w is not an e-bike anywhere in Australia - its an unregistered motorbike & if you are unlucky enough to get detected the fines for riding one anywhere in public generally exceed $2,000. In some states its a hoon offence which can see your bike seized.
If you want an electric motorbike to hoon around a mates property, it would be cheaper & easier to start with something designed for that
Poider
Re: Throttle
Postby Poider » Mon Oct 04, 2021 8:08 pm
No intention to Hoon around, I am in my 50's and have bad asthma, I enjoy the outdoors and would like to continue to enjoy them but as my health is starting to take it's toll, the bigger hills will be out of bounds, as I said I don't want extra speed, I am happy with 25kph, I just would like a little more assistance.
Re: Throttle
Postby RonK » Tue Oct 05, 2021 8:21 am
I'd be pretty dubious about buying that e-bike. It may be cheap, but it not a known brand and the description doesn't even state what assistance levels are provided.
The mainstream brands offer multiple levels of assistance. There is no need for a throttle, maximum power will be provided when the highest assistance level is selected.
Re: Throttle
Postby familyguy » Tue Oct 05, 2021 9:31 am
Therein lies the issue: intended use and capability are two separate things. Yet they sell cars capable of 200km/h+ for use on public roads, which serves your argument of needing more grunt for certain times. As a solution, could you get more assistance by lowering the gearing? You're not going to rip up a hill at 25km/h, but you'll get full assistance power to do it at 15km/h instead. Admittedly, I don't know a lot about how ebike motors work and apply force just yet.
Re: Throttle
Postby find_bruce » Tue Oct 05, 2021 1:13 pm
One of the advantages of using a pedal assist bike off road is that the 25km/h limit doesn't come into it.
Have you actually ridden a bike with 95nm of torque? You might be pleasantly surprised as to just how much assistance they provide, especially at low speeds
Poider
Re: Throttle
Postby Poider » Tue Oct 05, 2021 8:40 pm
This bike has 5 levels of assistance
I didn't think it was cheap, i see it as midrange price for what i want
Poider
Re: Throttle
Postby Poider » Tue Oct 05, 2021 8:43 pm
I haven't found one with 95nm, but I have ridden one with 60nm and the one I am buying is 85nm, i think it will be enough for what i want
Poider
Re: Throttle
Postby Poider » Thu Dec 16, 2021 8:42 pm
So I ended up getting an ET cycles F1000.
This bike has a 250W motor, 48v, 21AH, 1008WH Battery.
It has 8 gears and 6 levels of Pedal assist.
The Throttle if being used alone will only do 6kph but will do 25kph if used with the pedals.
I was adamant that I needed a bike with throttle , but I have now disabled the throttle as I do not need it.
This bike has done everything that I have asked of it, without a problem and I am now riding home for work.
Today I rode the 26.8 km home, the usual large hills and it was 30 degrees I was hot but only as much as anyone else wearing long pants and long shirt.
So far this bike has done my wife and I well, I will update this post if anything goes wrong.
Bunged Knee
Re: Throttle
Postby Bunged Knee » Thu Dec 16, 2021 9:03 pm
Poider wrote: So I ended up getting an ET cycles F1000.
BNA had done a review on this bike 2mths ago.
https://www.bicycles.net.au/2021/10/rev ... and-looks/
Thoglette
Re: Throttle
Postby Thoglette » Thu Dec 16, 2021 11:55 pm
Glad to hear it's all worked out well!
Mububban
Re: Throttle
Postby Mububban » Wed Feb 02, 2022 1:07 pm
Ebikes are the future if we want to get more people out of cars and onto bikes, and keep them riding into older age as well :)
Edit - the 6kmh "throttle" is a 'walk assist' mode rather than meant for riding. But it can be used to manoeuvre through tight spaces or around pedestrians when you're being slow and very careful.
I found it helpful to use as a kick start to get moving as it's a heavy bugger, and the motor won't kick in until it detects a certain amount of pedal rotation.
Happy riding.
