With the IXON IQ Speed, riders can safely enjoy flooding the road with up to 50 LUX. The especially light, compact, IXON IQ Speed headlight weighs less than 100 grams.
Its special accu pack can be carried in the jersey or mounted on the frame and can power two lights if you require more light. And lets face it, more light the better!
The most remarkable feature of IQ-TEC is a newly-developed special reflector with integrated cooling system. The light comes from a high-powered LED that is used as an indirect light source. For this reason, the centre of the reflector remains free for “nothing but light”.
The overwhelming lighting experience is not only due to the high lux value pumping out 50 lux. If the IXON IQ Speed is installed as double headlight (only one accu pack!), the bike “burns” brightly through the night brilliantly illuminating the route with 100 lux for five hours or 10 hours at 50 lux. And can be switched down to the 10 lux to save battery life or in high lit areas.
Features:
2-position switch:
High-Power-Mode: 50 lux (10 hours)
City-Eco-Mode: 10 lux (50 hours)
Convenient and safe electronic system with more than 90 % efficiency
With electronically controlled charger, charging time approximately 6 hours only
Scope of supplies includes high capacity accumulator
With protection against total discharge in both operating modes
Weight: 85 g only (without accumulator)
Optional helmet brackets available
A second headlamp can be attached for double lighting capacity
Made by Busch & Müller in Germany and available from selective Bicycle shops in Australia such as St Kilda Cycles in Melbourne.
